Question about GE PTC22MFM Top Freezer Refrigerator
I have a GE PTC22MFMBLCC Top Freezer Refrigerator. I recently noted that the water line that dispenses the water to the ice tray has a drip leak. The drip starts at the back end of the tube. Now my freezer retains and freezes most of the water. How can I replace the water "tube" line, or is it repairable? Thank you for your time.
  • 63 Answers
The water valve is bad it is in the back under the frig. go to appliacepartszone.com put in the model # it is easy to repace just unplus the frig first
Posted on Oct 14, 2011
Ice maker drips water into freezer.Makes ice but doesn't shut off when full.
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
Aug 6, 2015 - If the ice maker doesn't make ice but you can see the arm swing intomotion and you hear a ... 4Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, ... If your ice maker keeps making ice, even when it is full:.
Refrigerator's Ice Maker Leaking Water ' ThriftyFun
www.thriftyfun.com/tf37813274.tip.html
If your refrigerator ice maker is leaking water, the first step is to locate the source. ... Its not the ice maker - in the floor of the freezer is a small drain that lets the ... I shutthe water supply off but water dispenser still leaks even though no ... My side by side refrigerator leaks water into the ice bin when filling the ice tray with water .
Dec 26, 2015 | Refrigerators
On our GE refrigerator, water leaks out of the bottom of the frame for the water/ice dispenser and down the front of the freezer side door. What could be causing this?
Did you just recently change your water filter? you need to flush 3 gallons of water out of it when changing the filter. if there is air in the line it'll drip constantly. If your ice door isnt closing all the way and properly sealing that also could be a source of water dripping. do you have a low of "Snowy" frost inside your freezer door at the ice dispenser shute?
Aug 05, 2013 | Refrigerators
The water dispenser in my refrigerator ice maker is leaking
if you have recently changed your filter, had the water turned off, or disconnected from the ref this is a common problem. you have air in your water line. fill 5-6 large cups of water or until it stops spurting and your drip should go away
Apr 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking into refrigerator section from freezer
The drain trough is clogged under the coils behind the freezer wall and also there should be a "p" trap on the back that is connected to the drain tube running to the bottom. Remove trap by turning and pulling being careful not to break the neck. You should be able to blow any debris out. Good luck. Blow don't ****. lol
Feb 13, 2010 | GE Refrigerators
Ice maker leaks water
The GE Icemaker has a center bottom plunger that drives the ice cube discharge tray up and down. If that center plunger oring has failed the ice maker will leak in a drip drip drip fashion. If it only leaks once every cube cycle then it is overflowing when filling. This can be corrected 2 ways. One is to turn of the water supply line and disconnet the water line on the back of the unit. Place the hose into a large bowl of some kiind and then have someone open the valve until the flow is full and then reduce that flow about 50 percent. Remember how many turns it took to get that flow and shut off the water supply line. Then reconnect the line and turn on the water the number of turns you counted when shutting off the water. The PROPER way of setting the water flow timing is to frome the front cover of the ice maker and turn the adjustment screw in the DECREASE direction. My suspicions are that the plunger o-ring is leaking. It costs nearly as much to have the service call to replace the o-ring as it does to replace the ice maker. Your choice but I would replace the icemaker if the plunger is leaking. (mid-bottom point of ice maker) Just note that once a leak occurs in the plunger area if the plunger has corroded the new o-ring will wear out rapidly.
Jan 03, 2010 | GE Profile Stainless Bottom-Freezer...
Rust ruining door at lower corners of ice/water dispenser.
when you dispense ice or water, you are allowing the drip tray to overfill and the water builds underneath the tray until the water reaches the point were it will leak down the front of the door. the water will rust the panel beyond repair. you will have to replace the whole door at this point. hope this helps.
Oct 20, 2009 | GE GSS22JEM Side by Side Refrigerator
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
The feeder tube for the ice maker freezes and water leaks inside
First we have to determine if the problem is a faulty water valve. Reason: faulty water valve can continue to supply water even after the IM or door dispenser is finished calling for water causing a drip feed freeze up problem, or water overflow condition in the ice maker (IM). Another common cause is unrelated, but caused by a blocked drain line often resulting in thick ice build up on the bottom of the freezer, water dripping onto the floor, or water dripping into the refrigerator (top freezer mount models only) and freezing near the lights or damper ducts after defrost. Fix for this problem is to remove evap panel and clear freezer drain line with hot water or compressed air. If this is not the case, and water is dripping out of IM supply line, remove IM H20 supply line from IM at back of appliance and see if the water seems to drip out, if so, replace the water valve. If water doesn't drip out at all, replace IM, or IM module depending on the model of refrigerator that you have as contacts in the IM are also responsible for calling for H20 supply. You will have no more problems after this.
Jun 17, 2009 | GE GSS20IEP Side by Side Refrigerator
Frige has water dripping in from freezer
Hi, Check the door seal.
Ice is often caused by warm, moist air getting into the freezer and condensating, then freezing.
Jun 25, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Ice maker is leaking into the tray where the ice is dispensed causing the ice to become embedded into the tray
there is a screw in the ice maker unit that can adjust the water level open the ice maker whit cover and you should see it but turn it gently little by little each time...and see how much you getting :) very EZ good luck
Jun 06, 2008 | GE PDS22SIS Bottom Freezer Refrigerator
GE PTC22MFM Top Freezer Refrigerator Logo
242 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
