Question about Sony KP-53S75 53" Rear Projection Television
Sony kp-53s75 My TV will not turn on. The LCD light flashes 4 times. I checked the fuse and that is ok. Can you offer any solutions?? Also where can you find a diagram of the "guts" to indicate what is what??
  • 927 Answers
Good Day, cheriejesse;
There are many things in this Model that can cause this problem. So I would recommend that you call an Authorized Service Dealer to come to your home & give an estimate.
The most common problem though is the IHVT.
Good Luck, big IRISH.
Posted on Aug 16, 2008
Our sharp LC-37D6U does not turn on. The opc/dl light keeps flashing green X3 then every second or so. and the blue power button flashes also. What might we have to do to solve the problem? thank you
The main tv Tuner signal board it is dead or it have problems,but tv still usable.Tries push the remote power switch off/on again everytimes OPC/Power LEDS lights flashes.Have to do this maybe 3 or 4 times for the tv to have a lite up LCD screen panel backlight to make the tv Tuner signal board to work again,for the tv to work.If still have same problems after 3 or 4 times power switch pushes off/on still have OPC/Power LEDS lights flashes.Mean the main tv Tuner signal board it is dead and can not be trying to save it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv Tuner signal board for the replacement.This solution 100% will work,if ur tv main Tuner signal board still have life left in it.I do this every few days out of a week for my 46" Sharp Aquo LCD tv set,tv it work all the times.
Jun 12, 2011 | Sharp LC-37D6U 37 in. LCD Television
TV won't turn on with remote or manual, and standby timer light flashes
The flashing timer light blinks out a code, where it flashes some number of times, pauses, then repeats. The code indicates what fault is keeping the set from coming on. Unfortunately, all the codes tend to mean that there is some electronic problem with the TV. Unless you have some electronic servicing skills and the necessary equipment to troubleshoot the problem, you'll need to have set checked by a professional. For any code there can be many causes, so I can't offer any other advice.
This might be a good time to check sale prices on LCD sets. Let a technician check the set and give an estimate for the repair, then decide.
Jun 08, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Heard a pop. Checked and had to replace the lamp. Now when turned on the power-standby flashes green, then flashes red, but TV never comes on.
How many times red light flashing?
This is an error code and red flashing count indicates a particular problem in specific section of tv, please count how many times red light flashing after 3 seconds long pause and post here to suggest a solution.
Thanks.
May 28, 2011 | Sony KDF-E50A10 50 in. LCD HDTV
Plud the tv in and a click sound is heard like the tv is turning on but in 10 or 15 seconds green light goes off and a red light starts to flash. It flashes 4 times per cycle.
You may have the bad capacitor issue others have had in the power supply. Google your model number and the words "replace capacitors" for the solution. There is also a Youtube video. Also, check the fuses.
Sep 13, 2010 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I have a Sony KDL-40V2500 LCD 1080P TV there is no picture the
A 4 flash shutdown indicates a backlight problem. It can be acused by a bad backlight inverter board (the backlight power supply) or by a defective backlight in the panel. There are fuses on the backlight inverter board called "picofuses" which will need to be checked in order to isolate the problem to the board or the panel. If the fuses are good, you have to replace the panel (very expensive!). If the fuses are opne, most likely the back light inverter board has failed.
Nov 25, 2008 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
TV won't turn on and red light flashes 6 times.
MINE DID THAT AND IT WAS THE THERMOSTAT FOR THE BULB
Jul 14, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
TV won't switch on: Power light is flashing 4 times
your problem is usualy cause by the lcd drive board.
Sep 12, 2007 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Clicks but crt does not turn on
The Tv clicks and CRT comes on for a second before it goes into the protection shutdown. The LED flashes 6 times and sometimes 7 times. I checked the voltage accross IC501 as suggested in other posts and one of the votages is higher thatn it should be. thesymptom for the 6 LEd flashes suggest overscurrent and bad IC 504. I don't know how to meassure the voltage on the IC504 however as it has 4 prongs instead of three. My question is if there is something that may be causing this. Please help! I can offer you the Service manual for the KV series TV in return... you seem to be a techanical person so answer is purely technical. Clicks but crt does not turn on 1 check whether power supply out put is ok.by disconnecting h/output 2 if it is ok check hor. section that is eht is ok or not as without eht crt will not glow. check crt supply &loose connection in crt base. regards thanks
Sep 11, 2007 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony KP-53S75 53" Rear Projection Television Logo
95 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
