Question about Frigidaire FMV145K Microwave Oven
My frigidaire gallery over range microwave died. I just replaced the fuse and checked the breakers but this still didnt fix the problem and the microwave remains totally dead. What else could be the problem?
  • Frigidaire Master
  • 9,047 Answers
It may be a blown thermal cutout / thermostat on either the magnetron or oven cavity.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range grille and control panel assembly in under 5 minutes. Then you can access most of it for testing and part replacement.
Posted on May 26, 2011
Frigidaire microwave
Check fuse inside microwave oven (usually 8-10-12 A) on power supply board or main board, depending on model.
Dado
Aug 10, 2014 | Electrolux Frigidaire Gallery 30" 1.7 cu....
FGMV205K cover removal
Good Afternoon Friend,
I understand that you want to know how to remove the cover on your Frigidaire microwave, model# FGMV205K. There are two different covers that you are able to remove for access to two different light bulbs.
If you are trying to change the Microwave Oven Light for inside your microwave:
    1)To replace light bulb, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
    2)Remove the louver by removing the three Hood Louver Screws.
    3)Push in the upper tabs and pull the louver away from your appliance.
    4)Remove the light bulb and replace with a new 20 watt light bulb. DO NOT USE BULB LARGER THAN 20 WATTS.
    5)Close the Oven Light Cover by carefully pushing into place. Push the louver back into place (engaging both the bottom and top tabs) and change to hood Louver Screws.
    If you are trying to change the light bulbs underneath your Microwave:
      1)To replace light bulbs, first disconnect power to your microwave oven at the circuit breaker panel or by unplugging it.
      2)To open Light Cover, remove the screw on the light cover.
      3)Replace the light bulbs with new 20 watt light bulbs. DO NOT USE BULBS LARGER THAN 20 WATTS.
      4)Close the Light Cover and secure with screw removed at step 2.
      If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
      -Best Regards-
      WP
Jun 07, 2014 | Frigidaire Gallery FGMV205K 2.0 cu. ft....
My microwave shows nothing on display and will not turn on
see this causes and fix it. God bless you
First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
Sep 27, 2012 | Maytag Appliances Over-the-Range Microwave...
My fridgidaire microwave just completely lost all power out of the blue. Could it be a blown fuse in the microwave itself?
It very well could be a blown fuse. I assume you checked power at the plug and checked the breaker. Also I assume and over the range micro. To get to the fuse you need remove the grille above the door then you should see a screw holding the control panel in place. Remove that screw and tip the panel out and you should see the fuse ( sometimes two) just inside the cabinet. remember to unplug or turn off the breaker before doing any repairs. you can goto - http://www.searspartsdirect.com/partsdirect/index.action - to find a parts breakdown and order parts. Good Luck
Mar 14, 2011 | Frigidaire Microwave Ovens
Lost Power in Frigidaire Microwave
without getting inside it , i would tend to believe its the inline fuse just beyond the wire harness.
Oct 03, 2009 | Frigidaire PLMV169DC Microwave Oven
Microwave shorted out when metal grease filter contacted inside
It might be that the internal power fuse of the MW may have blown. You may have to just replace that fuse if possible. Other wise the electronics (most likely a circuit board) may have been blown.
Jun 29, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
We had sevseral boiling pots going underneath the over the range microwave without the exhaust fan on while also cooking in the microwave, we saw sparks in the microwave and it went dead. now nothing...
The main power fuse inside the MW may have been blown from the steam shorting out the circuitry. If so this fuse probably can be replaced. Lowes has replacement fuses.
Jun 13, 2009 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
Frigidaire microwave gallery series turntable is not turning
This co. has one for $19.99
http://microwaveglasstrays.com/shop/microwave-turntable-motor-st16fe-ex73saaa3-p-214.html
I am also looking elsewhere
Mar 04, 2009 | Frigidaire FMT116E1B Microwave Oven
Frigidaire FMV145K Microwave Oven Logo
239 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
