Mitsubishi model ck35402 vertical collasp do you have a mitsubishi tech tip on this problem
  • 2,326 Answers
IC401 (LA7838) could be defective. If you do not find the LA7838 you can replace it with NTE7039.
Good Luck.
Posted on Aug 16, 2008
Mitsubishi 72" Model VS70705. Picture
The picture rolling up and down is caused by the vertical oscillator running off frequency. Usually caused by a Capicator that has burnt out and started leaking and causing the frequency to be off. Static sounds like weak signal, however the vertical oscillator could be corrupting the picture. If you are not a trained TV Technician don't try to fix it yourself. There's a lot of junk back there and knowing where the vertical oscillator section is located and which capacitor is bad will require a tech manual or a 'Sam's Photofacts' to hunt it down. dhgill1949
Jun 04, 2011 | Mitsubishi Televison & Video
Mitsubishi ws-55313 vertical hold problem with tv
This set does not have a vertical hold control etc---try to explain what the set is doing or not doing so I or another expert can help you.
SD TECH
May 18, 2011 | Mitsubishi WS-55313 55" Rear Projection...
Dim display. Lamp change did not help
Most likely the light tunnel has collasped and will have to be replaced by a tech. Save you old lamp because it is probably still good. The light tunnel being collasped is obstructing the light but also not focusing the light into the engine as designed.
Nov 12, 2010 | InFocus Proxima DP1000X Multimedia...
Mitsubishi #35401 has only a white horizontal line across the middle of a dark screen. Please tell me the likeliest few parts to suspect. Thanks, RenThelp@aol.com, or 1 800 662 6231
Sounds like Vertical collaspe, Problem is in your Verical circuit
I need you to look on back of TV for correct Model number WD?
Thank You.
Feb 17, 2010 | Mitsubishi Televison & Video
Vertical lines on Mitsubishi 62" DLP
the DM and/or the FMT board are going bad. the chassis needs to be rebuilt. check out www.tv-techs.com
Jan 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi model #VS-4543
2 THINGS CAUSES THIS PROBLEM ON THESE --- THE BLUE PICTURE TUBE HAS LEAKED FLUID ON THE CIRCUIT BOARDS ,,,THAT 'S BAD
AND SOMETIMES ,WHEN THE VERTICAL CIRCUIT GOES OFF ,,THE SCREEN WON'T LIGHT UP ,,,THAT NORMAL ,,,KEEPS FROM DAMANGING OTHER PARTS
U NEED A TECH TUNICA
Oct 29, 2008 | Mitsubishi VS-45607 45" Rear Projection...
1998 TV worth repairing?
sound like a vertical collaspe vertical chip...might be more..the fact you still have sound is good.. not all is lost. but technician will have to determine if further damage has occured
Dec 08, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi VS-60705 - picture flutters vertically and horizontally
This sounds like one of the 9 volt regulators on the small signal board is going bad, supplying less than 8 volts. I have seen this is several of those sets. The IC needs to be replaced and if you do not have experience in servicing projection TV's then I suggest letting a qualified tech handle it for you.
Jul 09, 2007 | Mitsubishi VS-60705 60" Rear Projection...
Televison & Video Logo
126 people viewed this question
Top Televison & Video Experts
