Question about SanDisk Sansa e250 MP3 Player
My sandisk says,"not enough space
  • 343 Answers
"You need to format your device, the best recommendation is to place it into MSC mode. This is the Sansa's mass storage mode and it allows the device to be treated as a drive. Go to the settings menu and find USB Mode. There are two choices, MSC and MTP. Choose MSC. MTP is for music transfer using a media player software like Windows Media Player. If you don't have a way to set MSC mode with a menu on the device, engage the 'hold' switch, and while holding down the left or right button (others report also using the center button), plug the device into the USB connector. Make sure the USB is already plugged into the computer. You shouldn't need to do this with a standard e250; the menu should work. After you have connected the device in MSC mode, right click My Computer and choose Manage from the menu. Find Disk Management and select it. The disks should be numbered, starting with 0 for the C: drive. You should see a drive that says SANSA E250, or something similar. Write down the type of file system if it is shown. Most e250's says FAT32. Some are FAT, but check to be sure. There will be two partitions on the disk. The larger of the two is for your music files. The smaller is for when the device goes into "hibernation" - it's so you'll be back to the exact same song when it powers back on. Right click the larger partition and choose Format from the menu. You will see the format dialog. Set the volume label to SANSA E250 (I believe that's your device type), set the file system to what you wrote down earlier (do NOT choose NTFS!) and leave the Allocation unit size at "Default." Do not check either of the two check boxes. Click on OK. Keep an eye on the partition in Disk Management and you will see the percent complete. When it's done, look in the System Tray (by the date and time). You should see an icon for safely removing hardware. Double-click it to bring up the safely remove hardware dialog. Click on the USB drive representing your Sansa device and click Stop. Another dialog will come up and you'll have to do this again. Close the dialog when the device has stopped. The device will restart and initialize the music database. You're done! Now change to MTP mode and sync the device and add your songs back in. Whenever you are in MSC mode, ALWAYS stop the device as I described in the paragraph above. That way you won't corrupt the drive."
Thanks for using FixYa
Posted on May 26, 2011
(Sansa 2.0 GB e250R) Player shows an empty database...
DO YOU GO TO YOUR COMPUTER ICON ON YOUR COMPUTER AND THEN PLUG IN YOUR SANDISK SANSA AND THEN DRAG YOUR SONGS TO IT BECAUSE THAT IS WHAT I DID AND IT WORKED
Apr 15, 2009 | SanDisk Sansa e260 MP3 Player
Not enough space?
Format the player from the Sansa itself - directions are in the manual - and reload songs onto the player.
Jan 02, 2009 | SanDisk Sansa e250 MP3 Player
Says not enough space when there is nothing in the mp3.
just format it then put all music in again or just sync
Nov 10, 2008 | SanDisk Sansa e250 MP3 Player
Sansa
Reformat the player - see my "tips and tricks" on how to format an mp3 player for details
Jun 07, 2008 | SanDisk Sansa e250 MP3 Player
No Song ..? O.o
Sounds like something nasty got on there. Try setting USB Mode to MSC (mass storage class) and running virus and spyware scans on the device as a disk drive.
May 29, 2008 | SanDisk Sansa e250 MP3 Player
Sansa m230
The Music DB refers to the Music Database, or the Artist, Album, and Song info.
The error means your device is too full. It needs some free space on the device to create this information.
Connect your device to the PC and manually delete some files from it in My Computer>Device Name (m240)>MUSIC Folder.
It needs 6MB of free space, so you may need to delete several songs.
Disconnect the device from the PC, it should restart and you should be ok. If the message continues, keep deleting files until its gone,
Best of Luck.
Nov 15, 2007 | SanDisk Sansa m240 MP3 Player
Everything is wiped out and so is the radio! Please help !!
The Music DB refers to the information (i.e. - Artist, Album, etc.).
The device need you to free up 6MB so it can create this.
Connect the device to the PC and delete several songs until you have at least 6MB free.
Disconnect it, restart, and youre all set.
Best of Luck.
Nov 03, 2007 | SanDisk Sansa m230 MP3 Player
PLEASE HELP I CAN"T LIVE WITH OUT MY SANSA
"Please free 6MB for music DB" means that there is not enough MEMORY for the MUSIC DataBase. Therefore, you cannot see the music on your device.
To resolve this, you need to delete music until your device is less than 6MB of being full.
Generally 10 to 15 songs should do the trick.
Best of Luck,
Oct 31, 2007 | SanDisk Sansa e200 MP3 Player
My sansa wouldn't work
The device needs 6MB free for each GB of music.
Delete about 10 or 15 songs and you should be all set.
Best of Luck.
Oct 30, 2007 | SanDisk Sansa e200 MP3 Player
My sansa is messed up
It is referring to the "database", or the menus on the device. (i.e. - songs titles, music, artists) It needs at least 6MB of free space on the device to create this. If you freed up what you think is 6MB, it may not be enough. Even though you have a 2GB player, there is only 1.85 of usable space on it. So try deleting some more tracks. If not, format the device and start over. Right click on the device in My Computer and select format. Best of Luck.
Sep 14, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
176 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
