Question about Singer Sewing Machines
Singer sewing industrial model 20 U top and bottom thread not sewing together
  • 415 Answers
There are three things that most often contribute to not stitching properly: top tension, bottom tension and the needle.
If the top tension is too loose it can not draw the bobbin thread up. If the bobbin tension is too tight it can't come up either but in that case it usually breaks the thread. If the needle is in wrong or is the wrong size or type it also won't make the stitch.
Even when you think all those things are correct the best thing to do is unthread the machine and rethread it again checking the tension when you do. Then pull out the bobbin and check that it is pulling out with enough tension but not too much. Make sure the bobbin is inserted correctly. You should hear/feel a slight click when it's in proper place.
Try swapping the needle.
If you've done all these things and it's not sewing at all then there's the possibility that the machine itself has a problem but most often it is from one of those three things.
Posted on May 26, 2011
Singer 2273
Install a brand new needle (make sure it is compatible with the thread and fabric). Remove the top thread from the machine. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct. Set the top tension to the midway point and retest your machine. Tweak the top tension until the top and bobbin threads meet in the middle of the fabric.
AVOID old or bargain bin thread.
http://www.servicethread.com/blog/stop-industrial-sewing-thread-breaks
Sewing Machine Thread Keeps Breaking
https://www.sewhere.com/why-is-my-thread-breaking-how-to-avoid-thread-breakage-at-your-sewing-machine
Why is my thread breaking
Mar 20, 2018 | Singer Sewing Machines
How to thread the singer 20u33? The tension assembly is new, don't know where the wire is sposed to be...
When you thread the top thread, the thread will drop down on the right side of the tension mechanism and go around the bottom (clockwise) and up the left side. Grab the thread somewhere above the tension mechanism with your right hand and then pull the toward the right (as though you are going to close the circle around the tension disk. The thread should pull on the metal wire (spring) and your thread should pop into the correct position of the tension disk. When you release the thread, the wire spring should pop back to the left. Then you will continue threading through the remaining thread guides and the take-up lever.
Here's a service manual for your machine (in case you need one):
Singer 20U31 Service Manual
Threading video:
Threading Singer 20U 20 33 industrial sewing machine
Singer 20U Industrial Sewing Machine Tutorial
Bobbin winding on the Singer 20 33 or 20U
this video shows threading the tension disk:
How to Thread Singer Industrial Sewing Machine
Aug 11, 2017 | Singer Sewing Machines
How do I fix my singer.
the problem most likely is thread tension possibly on the upper thread
It is not pulling the thread up from the bottom allowing the bottom thread to become tangled
Apr 30, 2015 | Singer Sewing Machines
Threading instructions
There are manuals for several of the submodels of the Singer 81 class here: http://parts.singerco.com/IPinstManuals/
Apr 25, 2014 | Singer Sewing Machines
Manual for singer 195KI industrial plain machine
How do you thread up and wind thread onto a industrial singer sewing machine model 195KI
Feb 05, 2013 | Sewing Machines
Bottom thread lose on my Singer Confidence 7467 model
try adjusting the top thread tension one letter or number higher
till the stitch looks good
Jul 23, 2012 | Singer Confidence 7467 Mechanical Sewing...
My top stich is tight,but bottom is loose of my singer sewing machine.
Think in opposites... the top stitch is formed by the bottom thread tension and the bottom of the stitch by the top. So either the bobbin thread is too tight or the top thread is too loose. Check the bobbin thread first as that is the one most overlook. It should come out of the bobbin without having to yank it hard but it should have a little resistance.
Mar 22, 2011 | SINGER 7470 Sewing Machine
Singer industrial tacking machine model 269W8 Having tension problem because of the tension discs....threads get stuck in there no matter how I try to adjust it...and right now I am having that...
Maybe, you can try, rethread, now with the presser foot up, pull on the top thread, it should pull smoothly, then lower the presser foot, pull on the top thread again, it should barely move. This sometimes will seat the thread in the tension discs. Hope it works for you, otherwise you will have to have it serviced by a professional
Nov 23, 2010 | Singer Sewing Machines
Stitch is uneven, not straight, and tension off on top and bottom
on my industrial machine this was caused by the wrong size needle. the length was off just a fraction. just an idea, in case you bought generic needles or something.
Nov 24, 2008 | Singer 3116 Simple
Sewing Machines Logo
24 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
