Question about Garden
My lawn mower won't start it is a Troy-Bilt TB260. I had turned it over a few days ago after mowing to clear out a clog and didn't realize I had leaked all the gas and oil out. I replaced the oil and gas today but it still wont start. I cannot find my owner's manual either.
SOURCE: Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Posted on Mar 21, 2009
#1 Taper
  • 1040 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
  • 59 Answers
SOURCE: troy bilt mower not idling very much...
turn the high screw on the carb to the left just a little
Posted on Jun 23, 2009
  • 127 Answers
SOURCE: HOW DO I GET A MANUAL FOR LAWN MOWER AND ENGINE?
please double check model # and let me know
after the g sholud be a #then 11
13AN77KG_11
Posted on Jun 30, 2009
  • 202 Answers
SOURCE: I have a Troy bilt 17hp 42 inch cut ride on lawn
yes they have a charging system, not like a car but a charging system one the less. as i said before either under or around the flywheel. some newer mowers also have an electronic regulator.
Posted on Jul 31, 2009
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Troy Bilt Lawn Tractor won't turn left - still turns right
hi, mam i want to solve this prolem try contact or text this number 0927642929 / ( 032) 5127262
Sep 11, 2012 | Troy Bilt 175HP Manual 42" Riding Mower
Troy-bilt 550 series mower won't start. I've only used it twice.
does it crank over?did you leave the blades on?are you pushing on the brake pedal
May 25, 2012 | Troy Garden
My 50" troy bilt zero
All riding mowers have a seat safety, blade engage safety and a brake clutch safety, some mowers have a reverse mowing safety. Seat under the seat, blade and brake you will have to check the linkages underneath, and if there is a reverse mowing one I have seen them near the shifter handle right under the fender.
Aug 23, 2011 | Garden
Own a Troy Bilt self-propelled model #12A-466-M011 for a year now. It worked great when first got it. Now it will not clear the grass underneath so cuts off every 15 feet and have to manually clear grass...
I had the same problem with my Troy-Bilt self propelled lawn mower. You have to use the grass catcher if your grass is high. Also, I mowed wet grass and it made my belt slip off the pulley and created a new problem, somowing wet grass is definitely not a good idea.
Aug 01, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Rope on mower won't pull.
due to the ethanol and additives in todays fuel it can also be your carborator. one of the intakes may be clogged and all gummed up.
Jun 10, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy bilt mower won't stay running to cut lawn
Jim
May 29, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
146 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
