Question about Panasonic MC-V7367 Bagged Upright Vacuum
I Have a Panasonic MC-V7367 upright vacuum. After a short period of time while vacuuming it shuts off when pulling the vacuum backwards. I have to waite a minute before I can restart again. This happens over and over while trying to vacuum an aera. Any suggestions on how to fix this problem?
  • 1462 Answers
SOURCE: no suction in vacuum on a Panasonic MC-V7355
the device is a bypass which allows some air flow when there is a blockage. you have a blockage somewhere i suspect hence no suction. check all hoses carefully. take off the base and check the air duct away from the brush roll
Posted on May 03, 2007
reddevil6
  • 1673 Answers
SOURCE: panasonic MC-V7395 Belt overheating/snapping
With a belt on, make sure that the motor spindle is sitting straight and not being pulled down towars the brush roll. If it is then hte motor cover will have to be replaced, which may not be available anymore. Another is make sure that the brush roll spins freely and not froze up. Also make sure that where the brush roll sits in the slots, that it hasn't over heated there and damaged the noozle.
Posted on Jan 05, 2008
reddevil6
  • 1673 Answers
SOURCE: not enough suction for Panasonic MC-V5716 upright
Probably not the motor protector, its function is shut off the motor if it overheats. Most likely you have a clog or partial clog in the inlet down by the brush roll, or it is in the hose. But if the motor is running, and suction is low, with no clogs, then maybe the motor is running at a slower speed and will have to be replaced.
Posted on Feb 13, 2008
  • 389 Answers
SOURCE: Filters for panasonic vacuum cleaner MC-E468
Hi! Sometimes really hard to remember which of these models is which, so please forgive me if this is not a complete solution.  I'm pretty sure you will find there are two filters.  The first is a foam filter, and is located at the bottom of the bag compartment.  It pulls out to the front, and is washable (of course it must be completely dry before re-use).  The second (and here I'm on less secure ground) is a HEPA filter, and is located behind a removable panel on the front of the bag compartment door.  The HEPA filter is not washable, but rarely if ever needs to be changed unless the machine has been used for vacuuming a lot of extremely fine dust. I hope this helps, and I value your feedback. Please remember to rate my response.  Good luck!
Posted on Feb 24, 2009
Vac Belts
  • 701 Answers
SOURCE: What belt does the Panasonic MC-V7380 Vacuum take?
Here is a link to the belts you need for your model and the manual which has instructions:
Panasonic MC-V7380 Belts and Manual
Posted on Dec 13, 2009
HOW TO CHANGE A BELT ON A MC-V7305
Make sure vacuum is unplugged. Lay. Vacuum upside down and remove Bottom plate. Pull brushroll from nozzle housing, pull metal end caps from brush and remove any hair and debris. Put new belt around motor shaft then around brushroll. Put one hand on each side of belt and pull brushroll to stretch belt far enough to drop brushroll into position. Make sure brush spins freely. Install bottom plate. Make sure brushroll turns freely, if not, make sure bottom plate is not restricting the belt before you turn the vacuum on. Repeat the process in 6 months. You may be surprised to see how much a belt stretches and loses elasticity after it's been on your vacuum for 6 months.
Feb 08, 2015 | Panasonic Vacuums
Why does my Vacuum shut off!
Has this happened numerous times? If so, and the filters (all filters) are thoroughly cleaned then its possible the thermal protection circuit could be worn out in the motor. If not, it could be an assortment of other issues. Could you please provide more info?
Jun 17, 2014 | Panasonic MC-V7312 Bagged Upright Vacuum
Panasonic optiflow upright vaccum
Hello, Put the vac on its side and remove the screws holding the cover plate on. This exposes the beater bar and belt on the side. Pull the beater bar out and take the belt off. Reverse this to put the belt back in place.
May 30, 2014 | Panasonic MC-UG323 OptiFlow Upright Vacuum...
Panasonic Replace Belt MC-5127
The Panasonic MC-5100 Series takes this belt here:
Panasonic MC-5127 Replacement Belts
Dec 20, 2009 | Vacuums
Panasonic Vacuum MC-E450UK
Panasonic MC-E 450UK upright vacuum cleaner.
Just had this problem myself...........easy to get at it when you know how.
Panasonic UK wouldn't help me so I spent some time working it out..........here it is.
Remove the hose from its mounting storage at the rear (called hose clip) where the main body of the vacuum cleaner meets the base of the handle assembly. Remove the screw at the rear of the handle assembly which is behind where the hose 'was' situated and is located inside the deep recess.
Using the soft part of your clenched hand as a hammer, knock the base of the handle assembly at the front and it will slide backwards off the main body of the vacuum cleaner. Don't be scared, give it a thump and keep moving it backwards with a few more knocks.
Next remove the two screws at the front which hold the mains cable and on/off switch cover in place.
Finally looking from the rear once more, lift the plastic 'lug' at the top of the cover and which is part of the cover. This will now allow you to release the cover and pull it forward.
There you go! Told you it was easy!
Watch out for the funny little spring at the front behind the cover in the tiny plastic tube where it connects to the small rubber tubing as it could possibly try to escape.
You now have complete access in order to cut the intermittent part of the cable out and remove it from the 'choc' block.
Happy fixing!!
Jack.
Apr 07, 2008 | Vacuums
Not enough suction for Panasonic MC-V5716 upright
Nov 04, 2007 | Panasonic MC-V5716 Upright Vacuum
Vacuums Logo
Top Panasonic Vacuums Experts
jasbo
jasbo
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
