Question about Dishwashers
Wash time stuck; can't change it - Dishwashers
  • 3 Answers
Brand? Model?
Posted on May 26, 2011
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
DD603 top draw cycle getting stuck on 73min??????
Normally if you started the rinse cycle with water already in the base of the dishwasher it will immediately go into circulating the water through the wash arms. Do you hear the wash arms running when the washer is stuck at 11mins? Also when the washer is stuck at 73 mins are the wash arms running all the time or do you hear the pump operate at some stage?
If you have the dishwasher manual available make sure the water pressure setting is at HI or LO depending on your rated mains water pressure.
Apr 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
I have azanussi zwf1437w washing machine. The drum has become stuck and won't turn and can't be turned by hand. There are no socks etc stuck between the inner and outer drum that I can see.
Well, I hate to tell you, but the drum will have to be looked at and that means opening the machine up. It probably dislodged from its mounts from excess vibration caused by unbalanced loads in the drum.
Jan 15, 2013 | Zanussi Washing Machines
Digital timer stuck on 10 min.won't start the spin cycle
I know this isn't the solution you were hoping for but here is the manual for your machine:
http://www.samsung.com/ca/consumer/home-appliances/washers-dryers/washers/WF203ANW/XAC-supportforward
You say it rotates L & R...do you mean it agitates but the timer isn't advancing?
Dec 30, 2012 | Samsung WF203ANW Front Load Washer
Whirlpool Ultimate Care II is not draing properly and water is flooding out during spin cycle.
remove the hose up where it connects to the tub and see if there isn't anything stuck there,you could still have something stuck between the tubs and it usually will end up here or you could have a damaged pump from the piece of towel you pulled out of it or there's another piece still up in between the tubs and hopefully you'll find it at the hole where the drain hose is.
Jan 22, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
We have a Bosch washing machine E-nr wet2820GB / 13 FD 8101 0017. Recently it has started making an unusual, very loud 'crunching' noise during the wash cycle, it then stops on 'main wash',...
There is a clutch that gets dry and sticks it has to be greased from time to time.
It sounds like the clutch cannot slide on the spline and is causing the issue at hand.
Aug 01, 2011 | Washing Machines
Dishwashers Logo
29 people viewed this question
Top Dishwashers Experts
