Question about Bionaire BT210RT Tower Fan
Has a burning smell
I lost the manuel. the fan has a burning smell. it is less than a year old
should I throw it out? or can it be fixed.
Thanks for your help
[email protected]
  • 4311101 Aug 16, 2008
    Thanks I will search online for the manuel
  • july23 Sep 20, 2008
    Dis-assembled the fan and the resistor R1 was getting hot showing some burn mark on the pc board. Control unit works but motor fan will not run. just went off by itself one day.
    Ray
  • 981 Answers
That depends on what's burning! Unplug it and search online for the manual for that thing, or call Bionaire's help line once you look that up.
If you can safely do it, and are unworried about warrantee conditions, open it out and find out what was burning and what caused it to burn; for example, note the scorchy motor and/or control components and remove the cat toy out of the fan blade. At this point you get to observe and perhaps test whether the motor (or transformer, etc.) was burnt to ruin or can still run with care and reassembly.
Posted on Aug 16, 2008
6ya staff
SOURCE:
My dehumidifier smells like its burning when I turn it on. It is about 5 years old, does this mean I need a new one?
Judy, the fan motor or the compressor motor may be failing. It's cheaper and less of a hassle, to replace a 5 year old unit, than it is to repair it.
Hope this helped you.
Jun 02, 2011 | Whirlpool AD25BSR Dehumidifier
I have a vornado 733 floor fan that has suddenly stopped working after my 2-year old shoved some small, soft toys into it. fan blades spin freely when moved by hand, but the unit appears to be completely...
I would check the line fuse to see if it is blown. It is located in the plug under the sliding access cover. Slide it towards the cord to open. If the fuse is good and you have it less than 5 years, you might be able to get the company to fix it for free since it has a 5 year warranty. 1800 234 0604. Hope this helps you.
Apr 13, 2011 | Dryers
Vehicle smelled like burning brake fluid when backing out of a parking space. battery light came on. vehicle acted fine, didnt lose power or anything. tranny is 4 years old, engine is 4 years old. both the...
Is the alternator and/or all accessories turning when the engine is running?One may be seized and the belt is sliding across it producing a burning smell.
Jul 01, 2017 | 1988 Pontiac Grand Prix
Fan smells like it burned up and wont come back on only 3 years old
If it smelled burned then it is burned. Do not put you and your family at risk by trying to fix this fan. I strongly recommend you buy a new one. you will find some real nice ones starting at $60.
Jun 14, 2010 | Hampton Bay 24750 Huntington III Ceiling...
We have a model # PSW26SGNA BS. Think it was a motor, made loud noise like a fork stuck in a fan, popped and burnt oil smell. Only 7 years old. Any ideas?
Sounds very bad. I believe the compressor shorted out if you smelled oil. You need to unplug now and let me help you see if it is just that. Sometimes when compressors burn out they blow a hole out the side where the wires go in. If fan then something came loose and stopped fan and the smell of electrical windings will be almost the same. Trying to run compressor if it will run will cause a fire.Tell me do you want my help? Thanks Sea Breeze
Apr 09, 2010 | GE Refrigerators
Burned electrical smell from the freezer compartment
I would check the defrost thermostat usually a button type switch with 2 wires on it mounted to the freezer coil. Size depends on type ; 1 type is about quarter size, 1 is about dime size, and electronic sensor (not had one burn out but the board could smell like your description but I believe these are not in the freezer section).
I have had these cook out and smell up the freezer section before. And if they go out guess what it wont defrost either. If your fan motor goes out it might smell and wont cool all over but the frost should be minimal.
Also a bad defrost heater could make a smelly situation it is usually a black rod or aluminum colored and the rubber ends can burn and make a smell.
If you find its the heater, I would replace the defrost thermostat as well. Its suppose to cut off the heater before it gets too hot.
If this helps you find your problem please rate me as high as possible if not please post back with more information as to what you did find. Thanks for using fix ya and good luck.
Mar 29, 2009 | Kenmore Refrigerators
My sharp microwave is under 6 months old. I was
It may be a shorted high voltage diode.
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
Feb 28, 2009 | Sharp R-1610 Microwave Oven
Burning
A guess: either there is something in the fans, stuck in the tubes or the belt is being held in position by debris causing it to burn.
Nov 14, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Burned taste
Descaling often removes bad tastes and smells.
To order descaler or Saeco parts for your espresso machine please visit www.cerinicoffee.com
Dec 12, 2007 | Saeco Classico Espresso Machine
Vibrating and noisy Kirby
Power off the vacuum.
Unplug the power cord from the wall.
Remove the head or hose attachment.
Look at the fan and make sure all the fins on the fan are there.
If part of one or more is missing it will cause the fan to wobble and shake.
Oct 18, 2007 | Kirby G4 Bagged Upright Vacuum
Bionaire BT210RT Tower Fan Logo
818 people viewed this question
Top Bionaire Dryers Experts
Jerry Greenberg
Jerry Greenberg
Kardoc
Are you a Bionaire Dryer Expert? Answer questions, earn points and help others
