Question about Compaq Computers & Internet
I have a compaq 7020 and everything is plugged in right but when I turn on monitor the green light comes on but blinks and turns off. Why??
  • Compaq Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
hope this helps
Posted on May 26, 2011
I had a Compaq FP 7020 (Carbon, Silver) 17 in. Flat Panel LCD Monitor with power green led on but no video . I tried to connect to different known good boot desktops , problem sill existed . What component...
It sounds like the screen is bad. A quick search with the model number and "LCD Screen" will show you that it would be cheaper to purchase a new monitor.
If it was the back light it would be an easier repair. But you are saying it does not come on at all so that is telling me the screen itself is bad.
Hope this helps! Please rate my answer :) Thanks!
Jun 12, 2011 | Compaq FP 7020 17" Flat Panel LCD Monitor
I unplug my pc and put it back after a few hrs then plug it back but there was only a blinking green light it does not turn on or off i tried everything like plug off and plug it on still the same i tried...
check the back of the power supply and make sure the voltage selector is set properly. try to switch it back and forth to the correct voltage. Swap the power cord with the monitor. Switch it on again. If the blinking green still comes up, press and hold the power button for about 5 seconds and see how it goes. If this does not work, disconnect all removable items and cables inside the system including power connection and connect them all and test the system again. Hope this helps
Nov 13, 2010 | HP Compaq Presario SR1230NX (PJ518AA) PC...
I turn on the monitor and Compaq 7020 comes on the screen in color for about 2 seconds then goes black. The computer is on and everything is plugged in correctly
use a flahlight see if you can see an image faintly in the screen, if so the backlight is failing. if not, check your VGA or DVI cable connection on both ends. sometimes there is more than one port on the back of the computer, try the other port if you have two of them,
Aug 27, 2010 | Compaq FP 7020 17" Flat Panel LCD Monitor
I have a shap lcd computer monitor and when i plug it into my computer and turn the power on, the little green power light comes on, screens back. and after 5-10 seconds the light turns orange and blinks...
It could be your monitor is fine. It simply goes to a cycle when its turned on and does not detect any signal coming from your CPU, it simply goes on standby mode (hence the darker image and orange/blinking light.) have you checked the computer (CPU) part?
Dec 04, 2008 | Computers & Internet
Moniter won't turn on/power light blinks green
Yeah, I called Dell yesterday, and they said it was a problem that I could not fix myself. Whether that's true or not, I don't know, but my monitor was still under warranty, so they shipped me a replacement right away. I already got it this morning.
FYI: Their monitors carry a three year warranty.
Oct 28, 2008 | Dell E176FP 17" LCD Monitor
Compaq presario sr1115cl wont power up
dont u dare ever use 220 line on thes eon usa power u blow it ever time u turn it on at 220 v dont u dare do that not no reset switch erther u must now buy new power supllly ok
Oct 12, 2008 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
OSD LOCKED in Compaq LCD 17" Model No. 7020
I had this problem with a different model. try this.
. turn off the monitor.
. press and hold the Menu key while you turn on the monitor again.
Jul 21, 2008 | Compaq FP 7020 17" Flat Panel LCD Monitor
Remove the power supply after everything is unplugged and take it to your nearest electronics store. They should have a tester there. This is probably the problem.
Jul 01, 2008 | HP Compaq Presario SR1420nx...
Computers & Internet Logo
59 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
