Question about Nikon Cameras
How do I use the rear curtain sync on my d90 - Nikon Cameras
    Sergeant:
    Champion:
  • 214 Answers
Hi You might need this information. I could write but online informations are very helpful and save time. http://www.digital-photography-school.com/slow-sync-flash
thanks and best regard!
Posted on May 26, 2011
Shutter Curtain Doesnt Reset Mirror
If your shutter curtain doesnt close, it may be out of Sync with the shutter button. My Minolta x700 had this problem. My camera guy fixed it for me with a couple of tinker moves. Contact your nearest camera repair shop (if available) and ask how much it would be to fix the Sync between depressing the shutter button and the curtain. it may just be some grime that has it stuck.
Mar 18, 2014 | Minolta X-700 35mm SLR Camera
Nikon D40. How do i force the flash to work in daylight?
First, you have to be in one of the PSAM modes; in the other modes the camera decides whether it needs the flash and in daylight it will decide there's enough light without it. So, after turning the model dial to one of the PSAM positions, press the flash button on the front of the camera to pop up the flash. In these modes the camera will fire the flash if it's popped up, and not if it's down.
To change the flash mode, hold down the flash button (after it's popped up) and turn the command dial. Depending on the chosen exposure mode, your choices may include Fill flash, Red-eye reduction, Rear-curtain sync, Slow sync, Rear-curtain plus red-eye reduction, and Rear-curtain plus slow sync. Refer to the "Flash Mode" section of the manual for full details.
Jul 30, 2011 | Nikon D40x Digital Camera
I have a canon 40d and a canon 580 ex, i need to set up the 2nd curtain sync, how do i do it ? respond here or email to mqlimax@gmail.com
There is a button with three arrows pointing to the right on your 580EX. Press this until the 3 arrows appear on your flash LCD. That is second curtain sync. The other function of that button is for High Speed Sync
Jan 08, 2011 | Canon SPEEDLITE 580EX TTL Flash
Slow sync flash - nikon d40
Set the exposure mode to Manual (M) or Shutter-priority (S) and specify the shutter speed yourself. You'll have to set it sufficiently slow in order to see any difference between front- and rear-curtain.
Mar 02, 2010 | Nikon D40 Digital Camera
60ct4 for nikon d90 how to use
Hi Vilas,
All of those cables will not do. Your Nikon D90 has no PC Socket. Buy a NIKON AS-15 and then just hook Flash Sync Cable to AS-15.
atdlee@netzero.com
Jan 28, 2010 | Metz Mecablitz 60CT4 TTL Flash
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    Nikon D90 rear curtain sync will shoot flash twice
    That is most likely the TTL preflash and should not show up in your final exposure.
    Try setting the flash control to manual (e2 under the Bracketing/Flash menu). That should give you only the one flash at the end.
    Aaron Gum
    Mar 06, 2009 | Nikon D90 Digital Camera with 18-105mm...
    Digital rebel XS - flash delay
    Your camera is set to syncronize the flash on the second shutter curtain. Check your custom functions/custom settings, and disable it. It's called "second curtain sync" or "2nd curtain sync". Nikon call it "Rear Sync".
    Hope this helps,
    /Chris
    Jan 16, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
    Flash shot
    Turn the button to the M position, press Menu button to go to the Rec. Menu
    Then click the down button to select Flash sync and change between 1st curtain and 2nd curtain with left and right buttons.
    Hit Menu key again to exit the menu
    Feb 10, 2008 | Canon PowerShot G6 Digital Camera
    Nikon d80 continuous mode
    This can be that the flash sync speed of the camera is not correct. There may not be enough exposure from the flash to the subject during the opened curtain (shutter) sequence.
    Jerry G.
    Nov 29, 2007 | Nikon Speedlight SB-600 TTL Flash
    Cameras Logo
    140 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Jeff Marcus
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
