Question about LG LMV1630ST Microwave Oven
Replacing a door latch & spring on an LG microwave
  • LG Master
  • 9,047 Answers
We have the service manual and have uploaded it to our site here to help you.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Normally You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screw(s) you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Posted on May 26, 2011
Tip
Maytag MMV4205 door won't stay shut.
After tearing apart my microwave, I found a little spring broke off the latches. Open the door to the microwave, pop off the plastic piece that the latches on the door go through. You will see a spring behind the latch. If the spring is not connected to the latch it won't operate properly. The spring was held onto the latch with a tiny plastic piece that broke off. An easy solution instead of buying a new latch is to heat up one side of the spring without burning yourself and melt it through the latch piece where it was originally connected then put everything back together.
Hope this helps,
Pillarair
on Jul 21, 2009 | Maytag MMV4205 Microwave Oven
I took my microwave apart to fix the broke spring in the door & put everything back exactly the way it was &it wo nt do anything ??????
Bad luck. Are you sure you mounted everything everythinh exactly the way it was? No pieces missing or left over?
Best procedure is to that a photo of each step.
My adivec: Do it agaim carefulley. I no luck, look for a repair service
Maybe you can fine a video tutorial for your Microvwve in youtube?
Something like this
Broken microwave door
Samsung Microwave Door Latch Spring Repair when your door won latch closed
Over The Range Microwave Oven Door Repair Help
Repair Replace bad Door Switch Mechanisms on Whirlpool Microwave
and there are come more
Oct 28, 2015 | In Microwave Ovens
Door won't latch & lite stays on . door hooks like spring fell off them.
Good Afternoon Friend,
I understand that you are having trouble with your Frigidaire microwave, model# FMV156DC, and the door not latching which leaves the light on inside the appliance. I also see that it looks like a spring fell off the door hook. For safety reasons, when dealing with microwaves, I don't suggest trying to repair them yourselves. I suggest contacting your local authorized technician for further assistance. They will be able to better assist in making sure your microwave is repaired correctly and there are no safety issues. Hope this is helpful.
-Best Regards-
WP
May 23, 2014 | Frigidaire FMV156DC Microwave Oven
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
Door Spring
Door Latch
Door Hook
Button Spring
Button
Handle Actuator
Apr 02, 2013 | Microwave Ovens
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
Replacing a latch spring on a sharp r-1480 microwave
THE RELEASE BOTTEN ON SOME MODELS CAN BE TANEN OFF AND THE SPRING IS RIGHT BEHINDPRY OUT OF GROOVES PUT IN SPRING ANGALIGN BOTTEN UP AND REPLACE
Dec 07, 2008 | Sharp R-1480 Microwave Oven
Need door assembly diagram to replace door latch & spring on Panasonic microwave model nn-t964sf
While I don't have that model's diagram, normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can order Panasonic parts here.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 23, 2008 | Microwave Ovens
The door will not latch
The latch head (with hooklike projections) have a spring to keep it pulled down. If the latch head can be easily pushed up and falls back freely, then the monting tab on the back of the latch head is broken and it will have to be glued or replaced. The new part is better. To get to the door screws inside, you have to remove the choke cover, as shown in the photo. You can order parts for Sharp models from Tritronics at http://www.wehaveparts.com.
Aug 31, 2007 | Sharp R-1480 Microwave Oven
LG LMV1630ST Microwave Oven Logo
164 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Devabhakthuni...
Devabhakthuni...
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
