Question about Speed Ceiling Fan 3-speed Switch By Westinghouse 77075
77020 fan switch dont turn off. i need a diagram please...
  • Speed Master
  • 5,245 Answers
Copy following link for wiring 3-speed fan switches
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#3-speed
Posted on Jun 30, 2012
2 Suggested Answers
  • 24 Answers
SOURCE: I bought a westinghouse 77020
The BLUE wire is for a light. The red is the "traveler" and the black is power.
Did you use the blue wire without a light? If you did, you wired it hot, full time.
Posted on Feb 08, 2011
I need a fan belt diagram, please.
If you go to autozone they have those for most cars and a lot of other diagrams and install directions
Mar 26, 2015 | Cars & Trucks
Light switch by westinghouse 77020
Copy following link for general assistance wiring 4-wire ceiling fan switch:
Jul 16, 2012 | Westinghouse Electric Ceiling Fan 3-way...
Radiator resivoir is cracked and fans not running and i need to replace the radiator and or run a toggle switch for the fan relay switch if the wiring is bad
It may already have a blown head gasket. The max pressure on the cooling system in normal conditions is 18psi.
How do you know the fan or fans are ok ? The computer signals the relay to turn the fans on if the engine temp reaches 220 degrees or you turn on the a/c. If the temp sensor does not have coolant to tell it the engine temp, the fans won't come on.
As for a toggle switch, you would need a relay mounted close to the fans because they will pull too much current thru only a switch.
Jun 27, 2012 | 1995 Dodge Neon
I own a 98 lincoln town car exec ser. I replaced the radiator fan and nothing is working. I bought a fan relay and dont have a clue where it goes. Also i was told a coolant switch will turn my fan on. can...
Your guessing an want to replace parts that you have no idea if it will fix your problem . There is no coolant switch , There is a coolant temp. sensor that is a input to the PCM - engine computer . When the PCM see's the temp is over 212 degrees it energizes the low speed cooling fan relay ,when it gets to over 233 degrees it will energize the hi speed cooling relay . Rather then replacing parts , leaning how to read wiring diagrams an using a DVOM - digital volt ohm meter an test the electrical circuits ... Your best bet , take it to a qualified repair shop .
Feb 22, 2018 | 1998 Lincoln Town Car
I bought a westinghouse 77020 pull chain switch and only two speeds work and fan will not shut off
Jan 27, 2011 | Westinghouse Electric Ceiling Fan 3-way...
I have an Emerson CF705AW with a broken speed switch Dealer sold me a Westinghouse #77021 Now I get these speeds: High, low,low,off - No medium speed Wouls switch # 77020 be correct? I nered a...
Ah.
A simple Capacitor based speed control. How many places do you have to put wires on your switch? You may have mis-wired the switch, or you have the wrong switch.
How it all works is... When you turn the fan to High, or position 1 on the switch (there's L 1 2 and 3) the power goes from 1, to the capacitor, but does not go through the capacitor, but instead goes through the second (probably gray) wire directly to the reversing switch in the switch housing. When you switch to medium (or 2) both 2 and 3 positions on the switch are supposed to be sending power through both capacitors inside of the black box. Basically, you have two capacitors, when you go to medium, both are wired in parallel to each other, but on low, only one is in the circuit. Basically, the switch you have, or have mis-wired, is putting only one capacitor in the circuit at the time on medium and low positions.
Also, do not worry, so long as you only mess with these 4 wires, you cannot blow anything up, However! When you disconnect power from the fan, BE SURE that the fan is "On" when you turn the power off to ensure the capacitor discharges as you can get a very very nasty shock from the bare wires.
Sep 07, 2010 | Emerson Fans CF705AW 52" Northwind Ceiling
Turn signals dont work 2000 sportster
Hi Johnnymeshel, always check fuses and bulbs first, you could have a faulty turn signal module or a bad turn signal button/switch, remove it from the switch housing and check for continuity, check your wiring and connections from the turn signal switch to the turn signal module with a testlite. Make sure all wires are not worn or pinched and connector pins are not corroded, broken, or loose. For a free wiring diagram please visit the website below:
Harley Davidson Wiring Diagrams and Schematics
Jul 16, 2010 | 2000 Harley Davidson XL 1200 C Sportster...
Fan blower stopped working
Hi Retta_roche,
This circuit is controlled through the switch. In the high position,it by-passes the blower resistor.So if the blower is off in the high position, and the fuse is good, you need to check the switch,blower motor or the wiring.Since the switch physically feels different,start there. Pull the switch and ground pin #4 blk/org wire with the key on. If the fan works,the switch is bad. You need to check the connector at the blower motor for evidence of a burn. If you find the connector burned,you will need to replace the motor and the connector. I am sending the wiring diagram to help you. If you need anything else,drop me a line. Thanks,Chuck d442985.gif
May 16, 2010 | 2000 Ford Focus
Westinghouse 3-way fan switch can not be turn off.....
I had a similar problem. A replacement Westinghouse 3-4 wire 3-speed replacement switch from Home Depot, part # 77020, is a multi-pole that did not work with my ceiling fan. There was no "off" position. I found the correct replacement switch, sold under the "Harbor Breeze" name, part # 033905, which is a single pole switch, at Lowe's, at a better price!
Feb 15, 2009 | Westinghouse Electric Ceiling Fan 3-way...
3 speed fan switch
Zing Ear ze208s switches are NOT all the same - the actual switch wafer on the back varies significantly. Some are single-pole making contact with 1, 2, 3 one at a time, others make contact in combinations. Like L123 for high, L1&2 for medium, and L1&3 for low. The number stamped in the center of the back may indicate the difference. I have one with a "4" that is one-pole at a time, and another that is a "21" and makes multiple contacts at a time.
Nov 18, 2007 | Westinghouse Turbo Swirl 78145 Ceiling Fan
Speed Ceiling Fan 3-speed Switch By Westinghouse 77075 Logo
926 people viewed this question
Top Speed Electrical Supplies Experts
Craig Butler
Craig Butler
epangan29
 Generator Guru...
Generator Guru...
Are you a Speed Electrical Supply Expert? Answer questions, earn points and help others
