Question about Norelco T970 Beard Trimmer
My Norelco T970 beard trimmer battery no longer charges. What replacement battery do I get and how do I replace the battery?
2 Suggested Answers
SOURCE: How to open case on Norelco T-3000 beard trimmer
Remove the bottom screw. Next, the on/off slide switch has to be lifted off carefully with a small flat screw driver. Its kept in place with a small spring steel clamp. After you've removed it lift off the steel clamp and remove the slide mechanism by carefully twisting it out of position. Once that's done it will twist open easily.
Posted on Dec 24, 2010
Battery not holding charge very long
I've written up a complete step-by-step tutorial on how to replace the battery on a Remington MB-300 Beard trimmer: John Fixes Stuff How to Replace the Batteries in Remington MB 300 Beard...
Apr 06, 2014 | Remington MB-300 Beard Trimmer
On off switch not working
Might be a silly question but are you trying to turn it on whilst the charger is connected to the shaver? Most (if not all) of the Phillips rechargeable shavers will only operate without the charger connected so as to avoid connection to the mains whilst in a bathroom etc.
Dec 19, 2013 | Philips Norelco Qt4050 Vacuum Beard...
How do I replace the battery on my Norelco D-finer D350?
try checking on placement of the batteries where it is screwed outside. you unscrew it and open the cover then change the batteries.. you can also sneak into the manual for sure..
Apr 28, 2011 | Norelco D-Finer D350 Beard Trimmer
Jul 25, 2009 | Norelco Health & Beauty
How do I change the Battery in My Norelco T3000 Beard Trimer
Remove Phillips head screw at bottom of trimmer. Separate body in two being careful to notice how on/off switch is assembled. Unsolder the ni-cad battery from circuit board. Install new ni-cad battery of the same physical size that has solder tabs on it and solder it to the circuit board. I used a ni-hi (nickle metel hydride) instead of ni-cad which had different charging requirements so I limit charge time to no more than 16 hours for a discharged battery. It had been working fine for over a year. Don't forget to apply a few drops of light oil to the cutting blades to extend cutting life. Replacement blades are about $30.00
Jul 06, 2009 | Norelco T770 Beard Trimmer
DOES NOT CHARGE
If you still have it I have one I dropped. The body is still fine, and the batteries charge. A piece broke off inside the cutting blades. Let me know if I can help. Thank You, Jeff
Jan 15, 2009 | Norelco G270 Beard Trimmer
Battery Replacement for Remington PG-300 Beard Trimmer
Hi
The manual will give you info on the battery that is inside the trimmer.If you can get to the battery then buy same TYPE or similar to the original---VOLTAGE/CURRENT RATING/CHARGING etc and size, connection
Hope this helps
Jay
Nov 17, 2007 | Remington Titanium Precision PG-300 Beard...
Norelco T970 Beard Trimmer Logo
136 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
