Question about General Electric WSSH300G Front Load Washer
GE WSSH300G Front Load Washer drains, but won't spin. Repairman wanted $340 to replace a door latch. ???
    Problem Solver:
  • 9 Answers
Door latch for that model I chrge labor and materials minmum charge is 180 ... its easy to replace ..2 minutes done...
Posted on May 27, 2011
  • 65 Answers
The unit has 2 motors the one that turns the drum and the one that drains the water. If the door is not latching properly the unit can drain but for safety reasons it will not spin. That being said your GE washer was actually produced by frigidaire and although the door lock assy for the GE part #WH10X10003 retails for $159.66 the frigidaire door lock assy retails for $74.49 and is an exact match. So either your repairman does not know he can buy the same part for a lesser price, or he really wants to make some money. Either way the part is not to hard to install if you need help.
Posted on May 26, 2011
  • 731 Answers
All I can say is the Door catch Part # WHX10X10004 is $9.29 from Sears
Item # 214 on this diagram
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Washer-Parts/Model-WSSH300G1WW/0432/0153200/G0804234/00002?blt=06&prst=&shdMod=
Frigidaire CRTR9300ASO won't spin replaced door latch switch and still does not work
Hi bitemejohne - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. Since you have already replaced the door lock assembly then the washer may be experiencing other issues. It could possibly have a faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Mar 09, 2013 | Frigidaire GLTF2940ES Front Load Washer
Door latch wont unlock LG WM2455 Front Load Washer
You can also gain access from the back by removing the back panel...The top on this washer can also be removed..Remove the dispenser cover...Take a putty knife..Insert it in between the top cover and the cabinet ..Push in the tabs located 4 inches in from the sides.
Oct 20, 2012 | LG WM2455 Front Load Washer
My GE washer #WDSR2080DEWW washer won't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | GE WDSR2080D Top Load Washer
Ge washer won't let water spin out
heatman101
Aug 11, 2011 | GE 3.2 Cu. Ft. 6-Cycle Super Capacity...
GE Washer will wash but won't drain?
heatman101
Jul 24, 2011 | GE Washing Machines
My machine is not draining properly GE WSSH300G0WW front load washer
Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
Close the door completely. The washer will not operate if the door is not securely closed.
I hope the above helps.
Take care.
Jan 10, 2011 | General Electric WSSH300G Front Load...
WATER WON'T DRAIN
Check the drain line , maybe plugged with a sock or drain line could be kinked
Jul 25, 2009 | General Electric WSSH300G Front Load...
GE washer not draining
You should have one. Get down low, and look at the kickplate. You should see screws just below the main front panel of the machine.
best regards, --W/D--
Jul 25, 2009 | GE Washing Machines
GE Front Loader Washer
Door latch is sending false signal to control board,first replace the door latch.
May 26, 2008 | GE WSXH208A Front Load Washer
General Electric WSSH300G Front Load Washer Logo
794 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
