Question about Boston Acoustics TVee Model Two TV Speakers
Can program up volume but not down or mute - Boston Acoustics TVee Model Two TV Speakers
    Problem Solver:
  • 14 Answers
To program the down button, after step 1 of the programing sequence, you must press the down button of the speaker system and then press the down button on the remote four times. This goes for the other buttons (i.e. after step 1 of the programing sequence, press the mute button on the speaker system and then press the mute button on the remote four times).This is a weak point in the programing instructions.
Posted on Feb 20, 2013
The mute button does not mute the tv
Follow the instructions on the back of the Shaw remote control to program the remote to be compatible with your TV.
Once you have done that, the volume up/down/mute controls on the remote will work.
Sep 28, 2013 | shaw.ca
Suddenlink tivo apex tv code
Hi- My name is Shannon and I am with Suddenlink. The SL-TiVo remote can be programmed to control the TV and one other A/V device using these steps:
1)
From TiVo Central, select Settings & Messages > Settings > Remote, CableCARD, & Devices > Remote Control.
2) Highlight Part 1: TV power, volume, and mute and press SELECT.
3) The DVR displays a list of television brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your TV brand and then press SELECT.
4) The TV Remote Codes screen appears. Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the TV.
5) If also programming to control volume & mute on an A/V receiver for surround sound; Highlight Part 2: A/V volume and mute and press SELECT.
6) The DVR displays a list of audio/video receiver brands. Use the UP ARROW and DOWN ARROW buttons and the CHAN DOWN and CHAN UP buttons on the TiVo remote to highlight your receiver brand and then press SELECT.
7) The AV Remote Codes screen appears.
Follow the instructions on this screen to enter a code into your remote control. If the first code does not work, repeat the instructions to enter the second remote control code, and so forth, until you find a code that works. The remote is now programmed to operate the receiver.
The TiVo remote will now turn the TV on/off and switch inputs and adjust the volume and mute the audio on the receiver.
If you have any questions, feel free to email me at shannon-AT-suddenlink-DOT-com. Thanks!
Nov 23, 2012 | Televison & Video
No sound system
Check in the Device Manager to make sure none of the audio sound drivers have a problem.
Check and make sure you have the volume turned up and not muted. There are keys on the keyboard that will turn the volume up or down and will also mute the sound.
If you have the megaphone at the bottom right by the time, double click on it and make sure the volume is turned up and not muted.
Click Start/Control Panel and check the Audio Sound properties
Click Start/Programs/Accessories/Entertainment and check the Audio Sound Properties.
Apr 07, 2012 | Sony Computers & Internet
Trying to synch my remote to the new tvee model 25 sound bar and can't get the orange lights.
I had this same problem and it was due to their instructions which do not adequately explain the setup procedure.
On my own, I was successful in programming volume up but that was all. I assumed that for volume down I would hold the power button and the VOLUME DOWN button and wait for the flashing light just as I had for volume up. Problem is, you never get a flashing light.
Today, I spoke with a rep from Boston Acoustics who patiently explained that step one of the instructions has to be done the same way each time as it is the step that puts the soundbar into programming mode.
It is only at step 2 that things change.
The solution is to hold the power button and the Volume Up button every time in order to get the system into programming mode. Once the light is flashing, in order to program Volume Down, you then hold the Volume Down button until the light goes solid. Once the light goes solid, then press the volume down button on your remote 4 times slowly. Works like a charm.
Works the same way to program the mute button. Follow step one to get the unit in programming mode. Once the light is flashing, hold down only the mute button until the light goes solid. When the light goes solid, press the mute button slowly 4 times.
OBTW, this was programmed with a Logitech Harmony 650 remote unit.
Sep 05, 2011 | Boston Acoustics Audio Players & Recorders
Have a BA TVee 25 Soundbar. Only able to program Volume Up on my remote. Cannot program Volume Down or Mute. Nothing happens except to turn the Soundbar off and on. Don't tell me to follow...
Jul 26, 2011 | Boston Acoustics TVee Model Two TV...
Got the Boston Tvee 25 and was able to program the volume up ok, but not able to program the volume down or mute functions. The process is the same but ive tried 100 times with no luck! Any help?
Jun 05, 2011 | Boston Acoustics TVee Model Two TV...
How to use the webcam
Camera Assistant Software:
a. On the taskbar double-click the Camera Assistant Software icon , or from the Windows® Start menu, point to All Programs, Camera Assistant Software, and then click Camera Assistant Software. The Camera Assistant Toolbar location briefly displays on the desktop.
b. On the Camera Assistant Toolbar, click the Start Camera button and click on the icons on the software.
NOTE: If you are not hearing the audio portion of the video you created, try the following: Verify that you do not have the audio capture muted. An X appears on the Mute button when Mute is selected.
Click the Functions button, and then click the Audio tab. In the Audio Output section, verify that the Digital Mic is selected from the Audio Device drop down list, and then click Apply. In the Audio Volume section, use the slider bar to increase the volume level. Verify that the notebook's volume is not muted. Pressing the Fn+End keys mutes the volume. Pressing the keys a second time restores the volume. Increase the notebook volume level by pressing the Fn+PgUp keys
Jul 03, 2010 | Acer Aspire 4720 Notebook
How do i use my webcam
Increase the notebook volume level by pressing the Fn+PgUp keys.
May 21, 2010 | E-Machines M2350 Notebook
Dvd rom will play cd with sound it will play dvd with/out sound
Well the good news then is that its not a hardware problem, it is most likely one of the issues below:
1- Vista muted the player that you are using: Launch the player and then at the bottom right corner by the time click on the volume control and select mixer. It should list all the programs you have open. In vista you can mute a selected program, make sure all programs are not muted
2- The volume control is turned down on the Toshiba laptop: On Toshiba laptops there is a volume dial control located either on the front or around the sides, make sure that it is not turned down. play a song and try adjusting it both ways
3- Conflict with another Video/Audio Player : Un-install any newly added media software.
Apr 14, 2010 | Computers & Internet
Directv AV1 switch Volume Problem
Did you try all the codes listed. Some work certain functions such as power but not volume. Did the installer leave a phone number where he could be reached other than directv toll free number? Did you receive the same remote as the original. Directv has two remote that are identical in appearance but one is rf capable and the other is infared. The RF remote has backlit keys and is compatible with just about any device.
Aug 03, 2008 | Universal Remote Control DIRECTV Universal...
Boston Acoustics TVee Model Two TV Speakers Logo
255 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
