My speakers and subwoofer continues to fade in and out when I play music
  • 27,725 Answers
The speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Posted on May 25, 2011
Dwarf 360 omni directional sound manual
how do i get the music to play do i have to download anything to the speaker there is music on the sd card but wont play
Aug 30, 2012 | Mighty Dwarf Black Authentic Vibration...
My aiwa surround sound subwoofer is not working. I can here bass when I touch my finger to its cord however. Just isn't working when I play music.
Hi,You did not give make and model of your Receiver !!!
Was it working before or you have just connected it to the receiver..? All surround receivers have a surround Sound Setup procedure that either Activate or Deactivate the Subwoofer..So,pls check your Sound set up and speaker Connectiions on the back of Ampl?f?er.
If problem continues pls let me know with more detailed description.
Hope this helps! Take care and please Remember to rate/vote us
to continue for Helping out the Community :)
Thanks
Aug 21, 2011 | Audio Players & Recorders
The song will be playing and then the sub will just stop completely but the music will continue on the speakers. also it looks like the light that says the amp is on is turning on and off or at least...
first check too see if the ground , is grounded correctly, next be sure rca jacks working right next check the sub for cracks on top side run the sub by it self no other speakers to see if its the sub or if the out puts or blown thanks hope i help
Sep 27, 2010 | Car Audio & Video
15 subwoofers play in an out
the voice coil connected to speaker terminal of your speaker is partially cut but when the speaker has a music it will sound on and off....it will located in cone of your speaker..wire cutoff but sudently connected but when you apply a music ..on and off music will be heared..
May 25, 2010 | Car Audio & Video
Subwoofer will not play with other speakers
Hello
It looks like you have posted this before. Unfortunately, I don't know what you have tried so I may be repeating some of your earlier troubleshooting.
The subwoofer needs its own power supply to function properly. if it isn't getting enough power, the sub will not work at all.
On the back of the unit, you should see a green LED when the power is turned on. Is this light on all of the time of does it fade / flicker? This would indicate the power supply is going bad and you need to replace it.
http://forums.creative.com/t5/Speaker-Systems/GigaWorks-S750-power-problems-green-LED-faded-and-flickering/td-p/547311;jsessionid=9B7C9D2D939336148A9036D7E7D18A12
Apr 30, 2010 | Creative Labs Gigaworks S750 Computer...
Ive got a prob with my xplod subwoofers, Any info???
It's your amp. unplug the rca's and that should narrow it down for you.One at a time. If it sounds like a bass drumroll, then like i said, it's the amp.
Sep 05, 2009 | Sony Xplode P5 Turbo Subwoofers Car...
Back rear speaker wont play when singled out. more details inside
I would suggest you mdisconnect the rear speakers from the amp, take a 9volt battery and click te speakers on at a time. If proble duplicated, the you have the left speaker tied to the right somewhere.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jan 26, 2009 | Clarion EQS746 Equalizer - 7-Band In-Dash...
Subwoofers not working on Logitech R-20 speakers; worked until recently
There must be a control on subwoofer, like a volume control. Turn it and check it. Also check the connections.
Jul 17, 2008 | Logitech R-20 Computer Speakers
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
