Question about Kenmore 60502 Microwave Oven
Kenmore microwave model #565.60502990..........the microwave comes on when the door is opened!
  • Kenmore Master
  • 9,047 Answers
First you need to determine when that happens if it's actually heating, or if it's just the fan and turntable coming on. (I suspect the latter).
You can test it by putting in a cup of cold water and letting it run (with yourself standing to the side of the microwave) for about 30 seconds.
Then unplug the microwave and check the water for warmth.
If it IS heating, then you probably have a control board issue and we can help you here.
If it is NOT heating, as I suspect, then I think it is a door switch or switch mount issue.
See these files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
Posted on May 26, 2011
Kenmore microwave model 401.85053010 just stopped working because door will not shut and lock. Does the main board have a safety interlock tie-in for the door?
Most Microwaves have anywhere between 3 and 5 switches to monitor if the door is open or closed. They have to act in proper sequence too. It is a safery feature so you can not run it with the door open.
Aug 18, 2017 | Kenmore Microwave Ovens
I have a Kenmore Elite Microwave Model 721.7915. When opening the door to put an item in, the microwave automatically starts without closing the door or pressing any functions. I have tried unplugging...
The door latch is a safety interlock that prevents your microwave oven from doing what it is doing. The latch has failed and has to be replaced.
Dec 19, 2014 | Kenmore Microwave Ovens
Kenmore microwave model 721 loose door
Loose bottom hinge - slide the microwave to the edge of the counter, and look at the bottom hinge - you may have to remove something to see clearly. Its likely you are missing a screw or the screws have worked themselves loose.
Jan 20, 2014 | Kenmore 62702 Microwave Oven
Kenmore elite microwave model 721.79203010 problems
I'd check to make sure you don't have a door switch that isn't functioning properly. Also, might be a control panel or control panel interface issue.
Mar 18, 2013 | Microwave Ovens
Our Kenmore Microwave Hood combo model # 401.88529011 door sticks and is very hard to open off and on
Possible that the door lock is jammed, it can also be due to jamming of the door switch or the plastic lock being stuck on.
You need to remove the front panel , and reset the door assembly.
Jan 25, 2013 | Kenmore Microwave Ovens
Why does my Kenmore model 721.63352300 turn on when door is opened ?
The most likely cause is a defective door switch, there are usually a few to protect critical area's of the microwave oven, if you have a digital meter I can walk you through the testing stage.
Sep 02, 2012 | Kenmore 63252 Microwave Oven
WERE IS MODEL NUMBER ON KEMNORE RANGE?
The model numbers on most Kenmore ranges will be located on a nameplate along the oven door, or lower drawer opening. Some models may have this information on the back of the operator console.
If this question is in reference to a microwave oven, the model number will be located along the oven door opening, or inside the oven cavity along the upper portion on either the left or right hand side.
If you need further assistance, please let me know. I hope this helps you.
Oct 06, 2010 | Kenmore Microwave Ovens
Kenmore microwave 80404400 no power
This is typical of the 20 amp fuse blown. It can blow due to slamming the door or even opening the door to quickly while it is running. It could also blow if there is a failure of one of the door interlock switches. This fuse is ceramic and looks similar to a cylinder automotive fuse and is located behind the control panel on this model.
Apr 20, 2010 | Kenmore 80412 Microwave Oven
We need to change the door on our microwave. We have the new door, but can't find anything in the manual about removing the old door. It is a Frigidaire Gallery series above range microwave. Any...
The door should come off fairly easily. All you have to do on MOST microwave ovens is open the door all the way and lift straight up at the hinges. The door will come off the hinge pins.
On some models, there may be a small hinge pin on the top hinge that you remove, then lift up.
You may have to remove the grill panel above the door (if equipped) to allow for clearance for the door to come off.
If you have questions, please let me know. I hope you find this helpful.
Sep 05, 2009 | Kenmore 62622 Microwave Oven
Replacing microwave oven door
The door should simply come off by opening it all to way and lifting straight up at the hinges, The door will lift off the hinge pins. On some models you may have to remove the upper grill above the door (if equipped). If you still have questions, please let me know. I hope this helps you.
Jul 02, 2009 | Microwave Ovens
Microwave Ovens Logo
94 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
