I cannot print a label and always get the message "Smart Label Printer is not detected on USB port."
  • r_carter7679 Jun 07, 2011
    We were able to solve the Seiko Label Printer 450 Problem by first uninstalling the software that came on a disc with the Seiko printer. After uninstalling the program, we downloaded from the Seiko Printer site the most recent update on the web [Version 7.0 as I recall], After installing this we used the “Mircosoft Driver Updater” software to search the web for an update/fix and to install it. After that the 450 printer was detected by the software and actually printed.
    Hope our solution will go to help some other poor soul. In this instance, the Tech Support folks at Seiko in Laguna Beach, which are open 24/7 incidentally, said because we were using Fusion UVware (permitting us to run Windows 7 on a MacBook Pro) they could not duplicate the problem and believed that the Seiko software was just incompatible with a virtual machine. We were able later to import our old address labels file by exporting to a *.CVS file on our XP machine (saving to a Flash Drive) and then importing it in our Mac's software. The import didn't come out perfect but about 95% of the information was transferred with some labels showing some imperfections that were not difficult to fix when next used.
    - Ralph Carter, 6-7-11
  • 148 Answers
SOURCE: I get 2 labels(1 with data and 1 blank)for every label printed
THE LABEL SENSOR IS NOT SENSING THE BEGINNING OF THE NEXT LABEL
Clean the photo eye that senses the label gap with a q tip and alchol
Open side door release print head and remove label stock you will see small photo eye clean
put printer in manual mode( switch 1 on to and 1 on botom on
turn printer on it should advance one label and hit skip it should advance another
put back in computer mode
should work now if it still skips check yur label desigh=n software and label mode (continuous or sense label)
Best of luck to you
Posted on Jan 04, 2009
SOURCE: TLP 2844 skips 15-16 labels then prints intended label
It sounds like they may need to set their "Q" values for the labels they are using.   If that isn't it, we may need more info - are they using Zebra brand or custom labels?
To start with, I would ask them to try adding these "Q" value commands: q456 Q152,24
If that doesn't work, then maybe they can provide the other info mentioned above so we can understand the problem better.
Posted on Jan 05, 2009
SOURCE: Smart Label Printer 240
Check your labels. Are there black "sensor marks" on the back of each label? That's apparently how the printer lines itself up.
Posted on Apr 02, 2009
  • 31 Answers
SOURCE: I have a zebra TLP 3844-Z printer. My printer
Sounds like it is set to do a label length check at power on. Go into your printer preferences and set it to "do nothing" on power up.
Posted on Jun 27, 2009
  • 32 Answers
SOURCE: the Zebra 2443 printer is feeding out 13 to 14
It sounds like the printer is not calibrated. This procedure is in the users guide. Make sure both labels and ribbon are loaded correctly and then perform this procedure. If you do not have the manual or still have issues, email me at hilster1968@gmail.com for the procedure.
Posted on Oct 27, 2009
What in the world!! I have the Smart Label Printer 450, it is not advancing the label, and the power button is flashing. It will not print a label at all at this point, and when it will end up printing a...
Unfortunately, this is usually an indication that the label roll in the printer are too old. This action is by design, compatible labels should have a black rectangle on the reverse side and the Smart Label printer uses the black rectangle to orient the label. This means your Smart Label doesn't think its wasting labels, it's just trying to run through what it considers to be unsuitable labels as fast as it can. If you're only printing one label at a time you can recover some labels by correctly the label's line up after each label you print but there's nothing you can do so that your printer will properly advance its current labels.
Remove the current roll, open a new boxed label roll, remove a sealed roll, cut open the sealed plastic, remove fresh label roll and load it in your Label Printer. Power the label printer back on and press the label advance button, it should correctly line up.
May 08, 2014 | Seiko Smart Label 240 Thermal Printer
Can Cymo lables be used in the Smart Label Printer 100
If you mean Dymo labels and if the Dymo labels have a black rectangle on the reverse and if the labels aren't to wide, then the labels should work. You may run into problems with the Label printer advancing too far after printing; unfortunately, you will have to manually re-align the label after printing
Feb 13, 2014 | Seiko Smart Label Printer 100 Thermal
After printing a label it advances too far wasting the next label
This is usually an indication that the label roll in the printer are too old. This action is by design, compatible labels should have a black rectangle on the reverse side and the Smart Label printer uses the black rectangle to orient the label. Remove the current roll, open a new boxed label roll, remove a sealed roll, cut open the sealed plastic, remove fresh label roll and load it in your Label Printer. Power the label printer back on and press the label advance button, it should correctly line up.
Jan 03, 2014 | Seiko Instruments Smart Label 450 Thermal...
Hi there I just got a new computer and try to copy the old smart label printer over, but when I try to print the label out, I got a message says.." SLP print manager can not start" What I...
when you say uyou copied the old printer over I assume you actually reinstalled the Printing Application from scratch?
You cannot just copy the seiko directry over, t doesnt load the .dll files
reinstall the application
biffo
Sep 08, 2011 | Seiko Smart 440 Thermal Label Printer
Received error message can't initialize port
I have fixed this temporarily by going into Device Manager, finding Com Port 1, right clicking on it to disable it (you get a warning message), then immediately re-enabling it (right clicking on it and selecting 'enable'). This fixes the problem until the next reboot. Still looking for a permanent fix.
Feb 02, 2010 | Seiko Smart Label Printer Pro Thermal
I have a zebra 110XiIII Plus 300 DPI printer that is randomly printing blank reciepts. It's connected to the computer via a USB cable. There is no rhyme or reason to the blank printing, just does it...
This is usually caused by the sensors being dirty or the printer needing calibrated. Blow off the media and ribbon sensors and also do a manual calibration. If it is still skipping after this then it is software related.
Jun 11, 2009 | Zebra 110Xi III Plus Thermal Printer
Printer working fine - when it stopped printing in mid of alabel♠
If reinstalling the drivers doesn't work... sadly I think it's time for a new one..!
Mar 30, 2017 | Seiko Instruments Smart Label Printer 430...
Delete it from Control Panel, unplug the USB cable, then reinstall the softwre.
Jan 05, 2009 | Seiko Instruments Smart Label Printer 430...
S4m is not printing
zebra s4m barcode printer ,suppose if i print 10 Labels only 2 Label come out balance 8 in memory .then printer comes pause, disply showing paper out /ribbon in/please help me....
Dec 30, 2008 | Zebra S4M Thermal Label Printer
Failed to print using Intermec Easycoder pc4 label printer
If you have another USB port asidefrom the oneyou are using now try to transfer your printer cable. Make sure your USB port is firmly connected to the motherboard. Follow the USB connectors and check if these are well fitted and not loose.Apply pressureon the endsto set the connectors.
May 12, 2008 | Intermec EasyCoder PC4 Label Printer
296 people viewed this question
k24674
jasbo
jasbo
