Question about Kenmore 23812 Progressive PowerMate Bagged Canister Vacuum
I am wanting to know how to remove the power cord wheel assembly. I ordered an entire new assembly and I am trying to replace it.
  • 710 Answers
HI smarger,
First, remove the hood and tool compartment covers. At each corner of the cover, by the cord retract button, is a screw. Remove these two screws. Pull the button off. It is difficult to remove but just keep pulling until it's out.
Under the button there are 2 more screws. Remove these and you can take off the cover to expose the cord reel.
There are 2 screws on the back of the bracket that hold the reel onto the bracket.
Good luck.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Posted on May 26, 2011
I need to know the correct position of the rear wheel assembly and spring to istall in a electrolux renaissance power nozzle model#n106a in the base.Is this power nozzle refered to as PN5,6 or7? I also...
any Aerus deler will have the plate go to aerusonline.com they have dealer listing in your area. Beware they will try to sell you a new one. Part should be around $10 you may want them to put that axle and spring and cover on it is hard to do. A hint though for a DYI the spring barb goes in a little square hole in the weel channel. Good luck .
Apr 03, 2014 | Electrolux Guardian Bagged Canister Vacuum
How do I take about my Dyson DC11 to replace the retractable power cord assembly
While it doesn't require a collection bag, a Dyson-brand vacuum cleaner can still suffer the problems of wear and tear that are prone to any vacuum cleaner--for example, a frayed power cord. If the power cord of your Dyson vacuum cleaner has become frayed, change it immediately to avoid a dangerous electrical mishap. You will need a replacement cord from an electronics service center, along with a few common household tools. You do not need electrical skills to complete the task.
Follow this steps on how to replaced the power cord assembly:
1 Unplug the Dyson vacuum cleaner's power plug from the wall outlet. Press the button on the top front of the plastic collection cover. Lift the cover off the front of the vacuum cleaner and place it aside.
  • 2 Trace the power cord to where it enters the back bottom of the vacuum cleaner. Remove the screws from the panel surrounding the power cord with a Phillips screwdriver. Remove the panel. Aim the beam of a flashlight inside the compartment so that you can see where the wires at the end of the power cord wrap around two screws on the motor assembly. Loosen these screws with a Phillips jeweler's screwdriver.
  • 3 Pull the power cord out of the compartment and dispose of it properly. Strip a 1/2 inch of insulation from the ends of the two wires of the replacement power cord. Run the wires into the compartment along the path of the original power cord--pushing the wires into the grooves inside the compartment.
  • 4 Tie a knot on the cord on the inside of the compartment to prevent the cord from being pulled out.
  • 5 Wrap the exposed end of each wire of the power cord around the loosened screws. Tighten the screws. Replace the panel and reattach the screws. Stand the vacuum cleaner right side up. Place the bottom of the plastic collection cover into the bottom front slot on the vacuum cleaner. Push the cover back on the front of the vacuum cleaner.
  • Jul 13, 2011 | Vacuums
    I have an Electrolux Guardian Canister vacuum. The power cord was damaged but the cord winder still works fine. I have ordered a replacement cord and need to know how to remove the old cord and install...
    I strongly suggest allowing a qualified service tech at an authorized Aerus Electrolux store take care of this. The disassembly and reassembly of the tank and cordwinder are tricky and complicated and incorrect reassembly can cause serious problems. Even to the extent of permanently damaging your vacuum, or worse, result in a shock hazard or fire.
    May 24, 2011 | Electrolux Guardian Bagged Canister Vacuum
    How to replace the power switch on a Kirby G4
    This repair requires extensive disassembly. First remove the handle, bag assembly, and switch "scuff" plate. To remove the switch plate, remove the screw at the bottom, and the upper screw that secures the cord. Insert a screwdriver into the rectangular slot in the plastic and pop it off. The cord must also be removed. One screw holds the cord cover to the lower motor shell. Remove the screw and push with a flat screwdriver on the back of the cover to unlatch it. Next remove the upper motor shell ( 4 screws ). The next piece to come off is the switch button. Pry upward on it's attaching lugs to free it, pull it upward far enough to disconnect it from the switch rod. The power drive assembly is next to go. Three screws on the bottom of the motor unit hold it in. DO NOT remove the center screw beneath the shift lever. The drive pedal must be in DRIVE for removal. The transmission drops down to get it out ( you may have to wiggle and pull on it to free it). Next the headlight frame assembly must be removed. You will see 2 screws at the rear, and 2 long screws in front which also secure the fan housing. After removing the screws, the headlight frame can be removed. Be careful to note the proper location of all wires! The right carbon brush assembly must be removed to allow the switch to slide back for removal. It is held in place by 1 screw and a tab on it's holder. Two screws hold the switch itself in place. One is on a tab on top of the switch, and the other is on the right bottom of the lower motor shell. The lower screw also serves as a motor mount screw. The switch can now be removed by inserting a small screwdriver along it's front edge and prying it backwards. It is wise to clear dust and lint from the motor contacts prior to re-assembly. Be sure the terminals on the field coil have not gotten bent before putting the new switch in place. Snap the new switch in place and replace the screws. It is easiest to replace the wires in this order:
    1- Holding the headlight assembly off to the right, install the lower headlight wire.
    2- Next connect the wire from the left carbon brush to the upper switch terminal.
    3- Connect the upper headlight wire.
    4- Gently replace the right carbon brush assembly, secure it with it's screw ( do not overtighten ) , and connect it's wire to the lower switch terminal.
    After the switch is in, install the headlight frame screws, transmission and belt, and switch button in reverse order. Be sure the shift arm on the left side of the drive unit engages the slot or pin on the handle pivot assembly. The cover and trim pieces can now be re-installed.
    Feb 16, 2011 | Kirby G4 Bagged Upright Vacuum
    I need to replace the power cord.
    You need to remove the handle and the front housing then you'll see where the connections meet. Then you should able to get it off and replace it.
    Jul 29, 2009 | Kenmore 31912 Progressive Direct Drive...
    Hoover s3639 vacuum...cord does not rewind
    I had the same problem with my Hoover s3639. The cord rewinder started squeaking, and retracted less and less of the cord each time, until it finally stopped retracting the cord at all. Here is what I did. I hope it will work for you as well. Open the covered tool storage and remove the tools. You should see three screws. Unscrew the screws. Remove the cover. You should see the motor for the vacuum and the cord rewinder. Between the vacuum motor and the white wheel where the cord is, you should see two brass wheels that turn into each other in order to operate the cord rewinder. Spray a small amount WD-40 between the two brass wheels. This should solve your problem.
    Dec 29, 2008 | Hoover S3639 WindTunnel Bagged Canister...
    Change cord on electrolux EL5020
    In order to get to the cord that is disconnected you need to remove the screws that hold on the frame(the red shell). You will need to remove the "fenders" that are near the wheels. In order to remove the fenders get a flat tip screwdriver and pry up on the front part of the fender, there are three clips holding the left one on and two holding the fender near the cord. You will need to remove the left wheel (the wheel farthest from the cord). After you remove all the exterior screws and the four screws under the brissels the shell should be able to be removed. Next you will need to pull the cord all the way out and there will be a clear clip, use a flat tip screwdriver and release the clip in order to remove the clear piece that holds the power cord electrical ends. Reattach the clips of the power cord and be sure when you put the clear piece back in that the two contacts are not bending. You will need to use a screwdriver to guide the electrical clips back into place. I didn't count the screws there is a lot of them. I hope this helps you
    Sep 20, 2008 | Electrolux EL5020 Vacuum
    Miele s558 Silver Moon
    It is not generally necessary to replace the entire cord reel, although occasionally it is.
    Here's the quick and easy DIY way to make your cord reel work again: you will need a #2 phillips head screwdriver, any flat head screwdriver, a pair of scissors, and a zip-tie.
    First, remove the bag compartment lid by gently prying the hinge parts inward with the flathead screwdriver until you can lift it free. Remove bag and exhaust filter, and then remove the two screws holding the rear control panel on. Lift the front of the control panel upward until you hear a horrible unpleasant crunching noise. You didn't break it.
    Lift that free, and remove all screws from the top of the main housing. (I believe there are 6 or so... but I can't remember off the top of my head.) The housing should then lift free.
    You should now be able to see your cord reel. see if it wiggles back and forth along the central axle. If it does, you'll want to place the zip tie around the side of the axle which is away from the large round copper contacts which look almost like leaf springs. This will ensure that the contacts make electrical contact again. Cut off the excess zip-tie.
    When putting the parts all back together, it is essentially a reverse of the disassembly, but be sure that you thread the cord through the hole in the back of the housing before you attempt to screw the housing down, or you will be very sad; both because you'll have to disassemble it again, and because you'll probably jack up your cord and have to replace the reel, which is what we're trying to avoid.
    Test machine. If it works: party. If not, you will have to replace the cord reel.
    For further clarification on the process, contact me.
    Good luck,
    -R
    Aug 17, 2008 | Miele s558 Silver Moon Vacuum
    How do you take the DC11 apart?
    Unplug the unit from any power first.
    To get the unit apart you have to Carefully pry off the wheels from both sides of the unit to allow access to another 4 torx screws. Use a longer flat blade screw driver and insert this between the wheel and the body of the vacum as close to the wheels center of rotation as much as possible. This should allow you open the clamshell like case. Once inside you can test the power switch and connections. My switch tested good but there is a problem with the power cord that I am trying to determine.
    I am trying to replace the cord but the cord reel assembly and cord seems tighly integrated so I may end up buying the replacement power cord assembly if it is available for purchase to the general public and not only service centers. I will try the plug into the wall assembly first as it is easier to replace.
    Good luck
    Jan 03, 2008 | Dyson DC11 All Floors Bagless Canister...
    Won't Turn On
    Mine was a simple fix. Hope yours is too.
    You need to take the unit apart to get to the cord reel. If you don't know how to take your unit apart, here are some instructions on how to take apart most of the Miele canister units.
    http://www.sannerud.com/house/miele.html
    Once it is apart, you will need to take out the cord reel. There is a small rubber hose which needs to be removed on the outermost part of the reel. Then there is one small silver screw that you must remove as well. One these two items have been removed, carefully lift the entire cord reel assembly upwards. When you are doing this, ensure that you are also lifting the black and white wiring along with the reel - just make sure that you're not yanking it and possibly breaking the connectors off. As you lift the entire reel assembly out, you can also remove the white wiring harness which connects to the main switches on the vacuum.
    Now, here is the trickiest part - not really that tricky if you are good with your hands.
    First, make sure that the cord is retracted fully. Then, start pulling the white plastic cord reel away from the black plastic assembly about 1 inch or so. Between the black assembly and the white reel, you'll notice a copper-like metal spring which is attached to the white reel. Make sure that as you are removing the white reel further, that you are maintaining visibility with the copper-like spring. DO NOT LET THE SPRING OUT OF ITS OWN WHITE REEL (the spring has its own reel which is difficult to wind up again, so be very careful!).
    Make sure that the spring is fully retracted at this time. If it is not, wind the reel so that the spring is not wound up anymore around the white reel. Carefully slip the spring out of the white reel and leave the spring as-is ensuring that it does not unwind itself out of its own reel.
    Now that you have the white reel off the black assembly, inspect the inside of the inner part of the white reel. You'll see two copper rings with 'wings' on them. These wings transfer power to the vacuum. There may be some grease (black) which you should wipe off with a paper towel. Also wipe the metal rings on the black assembly which touch these 'wings'. (the wings touch the metal rings to send constant power to the motor. The wings are there so that as you wind and unwind the power cord from the vacuum, there is always constant contact with the metal rings on the black assembly.
    Now, carefully pull the wings up and out. If you can picture it in your head, what you're doing is ensuring that there is a good contact between the copper wings and the metal rings on the black assembly. Do this for all 4 wings on both the inner and outer copper rings within the white reel. Make sure that the 4 pads are clean and grease/dirt free.
    Once you've done this, it's time to put the white reel back on the black assembly. Do everything you did earlier, but in reverse.
    Carefully take the copper spring and align it to the white reel - you'll see a specific slot where the spring slides and grabs onto on the white reel. You'll probably have to place the white reel slightly onto the black assembly rod in order to achieve this - again, you must be good with your hands to do this without breaking anything.
    Once the copper spring is attached to the white reel, press the rest of the white reel onto the black assembly. HINT: turn the white reel slightly so that you're applying some tension on the spring - this will make sure that the spring doesn't fall out of the white reel.
    Reassemble the cord reel assembly (black and white parts) back into the vacuum. Make sure that the black and white power cables are out of the way. Once seated, wrap the black and white cables around the assembly and reseat the white wiring harness. Reapply the black rubber tube to the cord reel assembly and replace the silver screw to hold the entire harness down.
    Close the vacuum casing, replace the control panel (power and cord buttons). Close the unit, plug it in, and power it on!
    If it worked for you, congrats! If it didn't, sorry, you've got a much bigger problem with your unit.
    Dec 23, 2007 | Miele S514 Solaris Turbo Plus Vacuum
    Open Questions:
    Kenmore 23812 Progressive PowerMate Bagged Canister Vacuum Logo
    228 people viewed this question
    Top Kenmore Vacuums Experts
    Chris Nomland
    Chris Nomland
    Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
