Print unable 32 turn power off and then on again
    Novelist:
    Champion:
  • 256 Answers
Check all of your drum units and toner cartridges for uneven wear, or damage.Are you using genuine cartridges, or aftermarket refilled toner cartridges.Some refilled toners can cause problems like this,
Posted on May 26, 2011
"print unable" "turn the power off and then back on again."
Sorry it took 2 days, just checked. Unit display should also give you a number after the print unable message. This should point us in the right direction. Will check this site again Monday morning.
Jun 18, 2014 | Brother MFC-9130CW Wireless Color...
I have brother DCP 7055 it shows print unable 71 error pls suggest
I have brother DCP 7055 it shows print unable 72 & some time it show 71 error pls suggest
Dec 18, 2012 | Brother Dcp-7055 Laser Print Copy Scan...
Print unable 32
This is not just a density sensor, this is a plastic cover over it that is getting stuck. There is a piece of soft rubber attached to the solenoid that is getting very sticky over time. Removing this rubber and stretching solenoid return spring corrects the issue. Search web for the service manual and follow chapter 8 to disassemble the printer correctly - takes less than 10 minutes to do it
Aug 29, 2011 | Brother HL-4040CN Laser Printer
Print unable 32 error message
The message "Print Unable 32" or "Machine Error 32" will appear on the LCD display if paper or labels are stuck inside the printer or drum unit.
Follow the below link to fix Print unable 32 error message on Brother MFC-9840CDW Laser Printer
http://tinyurl.com/print32
All the Best...
Dec 09, 2010 | Brother MFC-9840CDW Laser Printer
Brother HL-4070CDW error reads print unable 32 turn off power and restart, but won't print. I am unable to print anything.
Same thing on my printer. The density sensor door was sticking open against the springloaded solenoid. Simply remove the power supply assembly from the back of the printer (search for the service manual online; it has instructions under section 14 on how to do this; make sure to disconnect the four large red wires and the three connectors on the right hand side of the unit before pulling it out). Find the little solenoid on it that pulls the density sensor door open and you will see it will stick to the tape on the solenoid (bad design on Brother's part). Use alcohol to remove the sticky stuff from the solenoid and the sensor door and you can put some small single sided sticky tape back onto the solenoid to act as a cushion. Then double check the sensor door opens and close without sticking by manually moving it open and letting it go. If it goes back to closed without sticking, you are good to go. Re-assemble everything and your printer is fixed!
Sep 20, 2010 | Brother HL-4070CDW Printer
I have a MFC-9440CN Brother printer. It displays Print Unable 32. What is the problem?
http://www.youtube.com/watch?v=6Bob34TLrPQ&sns=em This YouTube video shows how to fix this problem with a small piece of tape! Save the 100 bucks.
Feb 06, 2010 | Brother MFC-9440CN Laser Printer
Print unable 32 ?
Print unable 32 is dirt or scratch on the transfer belt assembly. There's a timing mark on the belt that a sensor must read. If the belt is damaged, you will need a new one.
Aug 06, 2009 | Brother MFC-9840CDW Laser Printer
My Brother MFC-235C shows print unable 32 read user manual but I dont have a manual
This will also appear if there is either a mechanical issue or just a problem with a sensor possibly software.
1) The way to resolve this issue is to make sure there is no paper in between the rollers or on top of the print heads (if applicable).
2) If there is no paper the you will need to hard reset the printer which will restore to manufacuter settings and reset software.
Hold down the Menu botton while plugging in the power cable. The display should read "Maintenance." let go of the menu button and then punch in 91. The display should read "Param Init." The unit will beep once. Then type 99. The unit will exit maintenance mode.
This only works for maybe 30% of the time.
3) If this does not work then : Refer to Manufacturer or return the item.
IF PRINTER DOES NOT HAVE A MENU BUTTON:
1)Turn the printer power switch OFF. Check that the front cover is closed.
2)Turn the printer power switch ON while holding down the GO button until the Toner, Drum and Paper LEDS are lit.
3)Release the GO button. All LEDs will be off.
4)Press the GO button 8 times. The Ready LED will flash briefly while the printer is reset. After the printer is reset the READY LED will be lit.
Feb 19, 2009 | Office Equipment & Supplies
44 people viewed this question
k24674
jasbo
jasbo
