Question about Crosley Dryers
Crosley #CDE650O5W - dryer will heat and motor will run, but inside tub will not turn . If manually turned, it will turn in a reverse direction, but not forward. If turned on electrically, it will not spin
    President:
  • 3,074 Answers
Belt or capacitor, either way you will need take the dryer apart. Good Luck Tim
Posted on May 26, 2011
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
My Crosley dryer will heat up but it wont spin
Do you hear the motor running? If so, then it's likely the belt or motor coupling is broken, or has somehow come disconnected.
If the motor's not running, then it needs to be checked by a technician.
Jun 30, 2014 | Crosley Dryers
What direction does a waterway hot tub motor turn
The only way a motor will run backwards is if the motor gets wired wrong.
all motors turn clockwise.
Rod
US Parts Center
888-521-6183
Jan 03, 2013 | Pool & Spa
My Crosley electric dryer will not turn on at all.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 18, 2011 | Crosley CDE6000 Electric Dryer
Crosley dryer model # cde22b6v. Timer switch works but dryer will not turn or heat. I checked connections. Belt is good. Motor turns free. What do you think I need to check?
door switch, bypass by taping the wires together. here are some other things to check:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Mar 30, 2011 | Crosley CDE6000 Electric Dryer
Good Afternoon, My dryer will turn on heat up but after a few mins it will stop turning and the timer will still be on. I can unplug it to reset and turn it back on and again the same thing. I have a model...
Seems to me like you have a motor going out or maybe a wheel or idler that is binding the tub. Can you turn the tub easily by hand? Replacing the motor is not too difficult. The blower is reversed threads. Here's a nice video of a motor replacement.
If your motor bearings are dry you can try adding oil to them and sometimes get a a little more life out the motor I have a pictoral HERE
I have a manual and more repair photos and videos HERE
Dec 27, 2010 | Maytag Dryers
I have heat and exhaust but the dryer won't spin
heatman101
Jun 13, 2010 | Crosley CDE6000 Electric Dryer
My Crosley dryer not drying
You will have to ensure the tub belt is not broken or off the motor pulley. Also, you may have a bad push to start switch or door closed switch. Open door and manual hold in door switch and have someone to push the start button if there is any sound or attempt to start these switchs are most likely good and your problem is with the belt. Hope this helps God Bless
Sep 18, 2009 | Crosley CDE6000 Electric Dryer
Dryer will not turn
There is a belt like a fan belt that goes around the outer tub and onto a pulley that turns the tub, it may have slipped off, you should be able to take the top off of the dryer to check it.
Mar 19, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
64 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
charles
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
