Question about Garden
I have a Honda GX 160 5.5 Power washer Model Number: CM2403. What kind of oil should i be using in the engine?
    President:
  • 1,545 Answers
If it has a Briggs engine then use SAE 30 oil. If you run synthetic (which I highly recommend), then SAE 30 or muti-viscosity oil like 10W-30 can be used, but if using conventional oil, only SAE30.
Posted on May 25, 2011
Needs oil change ; what is correct oil to use ?
Typically they use a 10w30 oil in the engine and a non-detergent SAE30 oil in the pump portion.
May 06, 2014 | Honda Garden
I have a Honda GX 240 engine mounted on a walk behind mower. The bearings in the shaft that connects the drive belt to the blade seized. I replaced the bearings in the shaft and the blade turns freely but...
Remove the spark plug and make sure that oil did not enter into the cylinder. Oil in the cylinder will feel like engine is siezed. With plug remove and engine will not turn suspect more serious problems. If the rod is siezed due to low oil, it can be replace by removing the sump. No big deal and could be nice project. Before you take anything apart, check that the cable to the safety stop is actually releasing. This could also make you think that the engine is siezed.
Oct 13, 2011 | Honda 8 HP Engine
Honda GX 160 under 30 hrs from new, is running poorly
try removing the float bowl on the carburator and cleaning, sounds like needle valve is partially stopped up
Aug 02, 2010 | Honda Horizontal OHV Engine for Non Pumps ...
Looking for manual for honda pressure washer,its a GX 340 11.0 HP that I can view online without buying so I can find the part and part number
Go to this page:
http://www.jackssmallengines.com/help.cfm
You must have your exact engine model number listed on the side of the engine crankcase near the lower mount and oil plug.
Thanks for choosing FiXya.
Kelly
Jun 23, 2010 | Honda Pressure Washer PSI 3000
I have a GX Honda 160 5.5 and cant get the soap suds to work
Are you using a soap nozzel? If not the soap injector will not work.
Jan 25, 2010 | Simpson WB4200 Water Blaster 4200 Psi Cold...
I have a honda gx 160 5.5 pressure washer. It's hard to start
do a full service on it , new spark plug /air filter foam , full oil change , also chane the oil in the pump end , carefully remove the carb bowl and remove any dirt/rust/water etc
ive seen gx160 engines last 10 years no problem and those were hire machines
hope this helps if it does please vote
Nov 13, 2009 | Computers & Internet
Honda GX 160 quits running at variable times.
a coil wire may be shorting so look for damage on them!
you can sleeve them or a quality electrical tape will be ok for temp measure ok
Cheers Rob.
Jul 28, 2009 | Garden
Timing a 13 hp GX 390 Honda engine
I believe it is either one but if you are not sure, stick a screw driver in an see if it comes out with oil on it. Does one not have an oil level stick attached to the cap?
Jun 18, 2009 | Honda Pressure Washer PSI 3000
I have NorthStar 2000 psi pressure washer with a
1999 campbell hausfield 1800 psi--2.2gpm. weak pressure at the nozzle. water sprays out, but with the pressure of a garden hose.
Mar 20, 2009 | Garden
I can't find an oil drain plug on a honda 5.5hp engine.gvc 160.
The engine drain plug is on the main (square) base part of the cylinder block. I think it is 10mm. There is a compression washer to seal it aswell so it might need a bit of extra pressure to start it undoing. This should drain your block almost completely.
For diagrams go here, you will need the engine serial number and prefix.
http://www.honda-engines-eu.com/en/welcome.html
For manuals go here,
http://www.honda-engines.com/Engines_owners_manuals/own.htm
Nov 13, 2008 | Garden
Garden Logo
79 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
