Question about Vacuums
Have an Edwards "speedivac" vacuum pump model ES50. When I let it run , after about 2 hours the air in the shed is an oily mist.(Looks like a fog has moved into the shed). Any sugestions please
Seals but won't draw all the air out. Seals fine
That could be a bad foam seal not completing suction, A piece of debris that got sucked into vacuum line and or in pump, or in some cases a crack in a elbow or pump housing.
Jan 22, 2016 | FoodSaver Vacuum Sealer Kit V3460
Model 3750-D. Why does the hose get plugged after vacuuming a carpet area of about 10 X 12?
1. The hose may be partially clogged when you start
2. The hose may be collapsing
3. The carpet may be shedding excessively
4. You may have an animal in residence that sheds excessively
5. The actual clogging may occur where the hose discharges into the bag or container
Aug 10, 2015 | Bissell Vacuums
The eureka model # 4703D does not **** although the motor is running
The vacuum cleaner probably is clogged. Look especially in the opening behind the roller and follow the path to the bag/container. If you have a pet that sheds, you can clog a vacuum quickly
Dec 29, 2012 | Eureka Capture Upright Vacuum Vacuum
My Hoover Steam Vac model f5915-900 no longer heats the floor to reduce drying time. I have cleaned the bottom of the machine where it says "heated cleaning." Anything else I can try? Thanks.
The SteamVac blows warm air from the motor into the carpet to help loosen oily types of soil. If the motor is running, the air will be exhausted. This system is not meant to reduce drying time, but only to enhance cleaning.
Jun 07, 2011 | Hoover Vacuums
Aquamate basin pump does not work. Used it 3 times, stored it for a year and pump does not work. Looks like a reliability issue. Is this product defective for everybody? I saw an ebay listing for the...
Hmmm............ looks like the impeller is already stuck from a year w/o using it!
I suggest if u could open it and spray some penetrating oil on the bushing of the pump motror and the impeller, force the motor to turn manually to set it's rotor FREE. or just POUR some penetrating( I usually use BRAKE FLUiD ) oil in the pump and let it seat for a couple of days.
If don't have a knowhow in opening and repairing such machine, u coud bring it to ur tecnician or service center to fix that up!
Hope that helps u out!
Dec 02, 2010 | Rainbow E series Canister Wet/Dry Vacuum
How do I hook up my Kirby Ultimate G for upholstery shampooing?
Hooking up the foaming device simply blows foam into the job. Here is a shortcut which I find more convenient on my G4 tools. If you have the rotary upholstery shampoo kit, you can just attach the rotary tool to your hose. Then mix your kirby suds into a household spray mist bottle. If you happen to have a mist bottle with a screen on the intake straw it will foam your suds not quite as well as the kirby device, but this way you can store the suds in the spray bottle for future quick use.
kirby suds are designed to be used as foam not liquid so a foamer in the spray bottle helps the process. You do not want to soak the furniture, just apply a light mist and scrub with the air driven shampoo tool on the hose. Then allow to dry and vacuum 24 hours later.
Sep 10, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Washing cloth bag
Yes, you can even wash it with soap -- rinse thoroughly.
May 07, 2009 | Vacuums
Nothing inn the canister after using,suctione working,bottom roller working,no air leaks from hoses.Also when running awhile it shuts off by itself,have to wait awhile to use again
I'm not sure what vacuum you have, but that sounds like a blockage to me. Thermal shut off kicks in, shutting the motor down, to prevent damage from overheating. After waiting like 1 hour it probably comes back on. Make sure hose, filters, bag (if any) is clean. All "airways" of vacuums need to be clear of any blockages, since airflow is what makes vacuums work.
Apr 18, 2009 | Vacuums
Power Consumption Refridgerators
I have a 10KW stik welder/generator. I have no problem running a large freezer and 2 fridges except for the startup current draw. I have a $300 transfer switch connected to a 60amp sub panel with current meters on each leg. I have to watch the current draw and turn on & off breakers. I do have to play the "green acres" game because I have the water heater, well pump, and kit ckt all connected as well. Coffee machine, toaster, oil furnace, microwave all have to take turns as well as the water heater(4500WATTS). Cost was about$3500 in 2001 and $600 for a generator shed. lots of my labor. Last time we lost power it payed for itself. 28 hours without a generator would have been a trip to a hotel and lots of spoiled food to dump. hot shower and coffee anytime a big +
Nov 20, 2007 | Vacuums
Vacuums Logo
157 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
