Question about Sanyo VHR-H647 VHS VCR
My VHS tapes have great sound, but there are white flashes going from left to right. Have tried tape on other machines and work fine. What do I do next?
  • Sanyo Master
  • 5,056 Answers
Take the top off and clean the video heads with Servisol Video 40 which you can get online, image below. You can use cotton buds for the hard to get to areas.
Posted on May 27, 2011
I have a couple VHS-C tapes that drag
This may be caused by a faulty adapter. 1. try playing in the camera. 2. try a different tape. 3. try a different adapter.99% this is a problem with the adapter or the tape. It really sounds like the tape isn't turning freely, which can be caused by a brake sticking, or spindle in the tape or adapter.
Mar 16, 2012 | Televison & Video
I have 1 VHS tape that will not stay in machine. As soon as I push the tape in it pops right out.
I assume all the other VHS tapes work fine, there must be some sort of glitch in the case. I suggest taking the VHS case apart and leave the tapes in the spools, now very carefully transport the spools and tape to new VHS casing and see if that will solve your problem, and remember to make sure that all the parts are present and in the right location, that should get you up and running unless the tape has excessive ware.
Jan 10, 2011 | Zenith VR4206HF VHS VCR
OUr Samsung SCL 810 Hi-8 Camcorder is flashing Lemg-Eject in yellow, but won't eject a tape. We know it is old, but we're trying to transfer all the tapes to other media so we won't lose them and now the...
I had a similar problem with a Cannon Optura PI and had to send it in. It was better, but I still have problems on occasion. If your intent is to transfer all the tapes to media, I would suggest purchasing Toshiba's DVD Video Recorder/Video Cassette Recorder. Model: DVR620KU. I use a VHS-C Cassette Adapter to play my VHS-C tapes in and the dubbed them to a DVD. Works great. Unfortunately, there is no 8mm/VHS Adapters, since 8mm, Hi8, miniDV are different formats with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with past or current VHS technology. Your best bet would to borrow a HI-8 Camcorder and then dub your tapes to DVD's using the Toshiba machine. Here is a link to the Toshiba machine. http://www.testfreaks.com/dvd-players-recorders/toshiba-dvr620/
Good luck
Dec 28, 2010 | Samsung SC-L810 Camcorder
My JVC DR-MV150B plays prerecorded VHS tapes fine.
Try opening the front hatch of the tape by pressing the small, square button on the right or left (short) side of the tape. Check the black tape inside for any marks, dirt, scratches, tears, etc. If the tape is fine then your unit needs to be cleaned with a tape cleaner available at any electronics specialty or retail store. Good luck to you!
Jan 02, 2010 | JVC DR-MV150B DVD Recorder/VCR
How to repair Panasonic VCR Combo PV-D4742 which flutters at playback. DVD unit works fine.
your videoplayer(vhs) heads are dirty, use a vhs cleaning tape, buy from your local music store, or ask them where to get one, or your the videotapes you are using are worn, try other newer less used tapes if they work fine then the tapes your trying to play are worn, otherwise dirty play heads are the problem.
Jul 01, 2009 | Emerson EWD2203 DVD Player/VCR
TV recorder wont record from TV. All cables work and are plugged in
WHAT "" system needs to be calibrated and then configured ""........""It works fine otherwise""
Disconnect the VCR from anything. place a vhs tape with information [picture of something you don't want any more or a vhs tape that you want erased] in the machine. The tape at the back left TAB must be covered to promit recording. turn machine on,shub the tape in, press record. if after a time and you REWIND, and the begining is blanked of picture information...........the recorder [VHS] is working. looking to see the cables and how they are connected.
Nov 10, 2008 | LG Televison & Video
VHS tape was playing . After stoping does not play. Other tape will play
The idler wheel (that only drives the tape in play or scan modes) is slipping too much (very common problem). Try verify this by putting the tape in play then immediately press the fast fwd or rewind buttons to scan the tape. On older machines, the idlers used rubber friction tires - on newer ones, a clutch. Either replace the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
Jan 20, 2008 | Televison & Video
Machine won't stay on
Hi I'm not familiar with your model, but what it sounds like is a bad "end sensor" on your machine. There are photo sensors on either side of the cassette basket which is what holds the tape in the machine. There is a light source that ends up inside the cassette when loaded, which shines both left and right. There is a section of clear tape inside the cassette at both the beginning and end of the tape. When the sensor on the left side sees light through the clear tape, the VCR knows you have reached the end and goes into rewind, when it sees light on the left side, it knows you have reached the beginning of the tape, and stops rewinding. This sensor is also used in some models to sense when you insert a tape in the basket. In that case, if the right side end sensor goes bad, the VCR always thinks you are trying to load a tape, so it doesn't want to give them up, and when you rewind, it never senses the beginning of the tape, so it will shut down when it reaches the beginning, and could even snap the tape. I'm 99% positive that is what is wrong with your VCR, it is an easy fix, but unfortunately, you won't likely find a repair shop that will sell you the proper sensor. I hope this helps in some way. Good Luck!
Jan 13, 2007 | JVC HR-A592U S-VHS VCR
Flashing '2' or '1' or '4' when I try and play a tape
The idler on your machine needs to be changed and also the drum head of your machine needs to be clean.tape head cleaners can be bought from any electronic shop.the idler must be changed by qualified techn
Jan 22, 2007 | Philips VR540 VHS VCR
Televison & Video Logo
61 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
