Our 83 yr old hot water heating system has started moaning just as it ends the heating cycle. sometimes it can moan for more than 35 seconds! Any ideas?
  • louguy792 May 25, 2011
    The boiler is only 15 years old and was cleaned and serviced 2 yrs ago. The sound seems to come from the manifold of pipes just above the furnace before they run across the open ceiling of the basement
  • 43,501 Answers
The moaning is something moving as the heater cools after it shuts down... it could be a pipe moving through a tight spot in a partition or just a couple of parts of the boiler rubbing together...finding the exact source could be very difficult...
Try to pin down where the noise is coming from and see if you can readjust something to decrease the friction that is causing it.
If the sound is coming internally from tthe boiler then the noise is because of a build up of over heated mineral inside the boiler. The boiler will build up mud and mineral over the years and then the burners superheat it as it trys to heat the water...
In this case the noise is an indication that the mineral build up is getting to serious levels and that the boiler may fail soon because the mineral will insulation the boiler casting from the water and there overheat and fatigue, causing it to crack....
Cleaning a boiler out that is this far built up is impossible is most cases...you should make plans to replace it soon.
heatman101
Posted on May 25, 2011
  • D. Floyd Kolb
    D. Floyd Kolb May 26, 2011
    The pipes are moving slightly asthey cntract and cool ...nothing to worry about just annoying ...if you can get something between the pipe hanger and the pipe to stop the noise
Moaning sound from front drivers side
sound like wheel bearing if car in motion.moaning while vechicle sitting still could be power steering pump or water pump bearing going bad.alternator with bad bearing cause moaning noise.
Dec 28, 2012 | 2005 GMC Envoy Xl
I have a GXSF27EO1 water softener serial # LF102017B that makes a strange moaning sound frequently and I don't know what causes it, can you help me? Thank you, Don Kneebone Email donk98926@hotmail.com
That typically means the softener is in a regeneration cycle. When the valve is switching cycles it quite frequently will have the noise you describe. The regeneration cycle should be set for 2am.
RJ
Mar 09, 2011 | General Electric GE SmartWater Household...
My bryant heat pump installed in 2008 makes a loud squealing / moaning sound during heat mode,it is a 3 ton,i keep it 66 degrees tring to save money my bill was still 196.00,it goes in to emergency heat...
Sounds like a normal defrost cycle. Watch it next time it does it. The outside fan stops, there will be a 'swishing sound'. That is the reversing valve changing over. Then you may see some water vapor rising up fromt he condenser, the emergency heat light illuminates on the thermostat. All of this is normal. The colder it is- the more you will notice it. Some heat pumps ARE louder than others during the defrost cycle. Have your a/c man check the charge ont he system just to make sure, though.
Other than that - let it run. You should have at least a 5 if not 10 year parts warranty.
Jan 26, 2011 | Heating & Cooling
GE Profile Dryer. Sometimes fails to heat or just air dries.
Cold solder joints on blower motor coils. Needs re-soldered. I suggest finding a buddy who knows how to take the dryer apart and knows how to solder. Luckily for me, I know how to do all of that, I had the same problem you have.
Oct 19, 2009 | GE Profile Harmony DPGT750EC Electric...
My 94 park ave. moans when the a/c compressor activates. a/c other wise works fine.
Doesit moan all the time it's on or just as it starts. If it continues to moan then an orfice tube may be partly clogged. If just as it starts and goes away it's just the freon getting moving in an old car. the compressor has lots of miles and the seals are leaking interanlly in the compressor you say it's still cooling but if this is the case it won't for long. Sometimes the air motors in the dash move to the AC mode and they make noise as they move but should stop makings noise soon after startup
Aug 28, 2009 | 1994 Buick Park Avenue
In 4WD i'm hearing a moaning sort of noise
four wheel drive is not meant for pavement, your front end is geared faster than the rear so it will pull you. if you used your four wheel on any good traction area you may have damaged the clutch discs in the transfer case
Mar 04, 2009 | 2004 Chevrolet TrailBlazer
Condensor sounds like it moans for a couple of seconds instead
Hello aeruslady1,
Do you mean the compressor? I'm sure you do. The condenser is the hot refrigerant line that comes off of the compressor.
It just sounds like you have an old compressor. I have seen them make noises for years before they take a dump. If it continues to run loud even after it starts however, then you may need to clean the condenser coil or replace the condenser fan motor. Another thing that might make it run loud is some refrigerant lines may be rubbing against something. This can be remedied by bending the lines.
Hopefully this helps.
Sincerely,
shays5415
Dec 03, 2008 | Refrigerators
Moaning sound in front end
Try rotating tires. If it gets better or worse, its probably the tires.
Nov 20, 2008 | 2003 GMC Yukon
GE ESS25XGMC WW Side by Side
its possible that your water tank has frozen up, try turning the refrig off and leave the doors open for about 10-15 mins and try it again. if that works just reset temp controls a little lower..
Dec 15, 2007 | GE GSH25JFR Side by Side Refrigerator
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
