Question about Canon ImageCLASS MF4350d Laser All-in-One Printer
When trying to print certain PDFs it says DATA ERROR CHECK PRINTER on the screen of the printer not on the computer.
  • 731 Answers
When printing the document try "print as image"
Posted on May 26, 2011
Try reinstalling the printer software... with the disc that came with the printer... delete the old print driver then reinstall the software using the disk that came with the printer
May 03, 2014 | Canon imageCLASS MF4270 All-In-One Laser...
Tip
Diagnose Quicken printing problems
Quicken printing problem mainly happens due to problems with printers. Check whether your printer is turned on properly or not. If turned on, check ink status and cartridges. If everything is fine, go to control panel of your computer, and open Printer dialogue box. Check settings and find whether printing machine has been detected by your computer or not. If printer is not detected, restart your system to get rid of the error. Printing data files of Quicken Customer Support also shows errors, when you try to printed non-updated version of data file. Updating data file will resolve the issues with precision. For more assistance, call customer support team of Quicken.
Quicken Customer Service 1 800 406 3148 Care Number
on Jun 14, 2016 | Miscellaneous
I have a canon MF 8350 cdn and when i try to print certain documents such as pdfs or excel sheets the printer prints out a couple pages then gives the error "check paper size" even though it is...
Check paper size refers to the fact your documents are for say and A4 sheet of paper but your drivers properties are set to letter size. Go into the drivers printing preferences and set the paper size to the correct value. All should work fine now.
Jun 01, 2011 | Canon MF8350Cdn AllInOne Laser Printer
A sheet prints sometimes with this: ERROR: syntaxerror OFFENDING COMMAND STACK: In one flow we get this error and in other flow it works fine. Any help on this will be greatly appreciated.
This is a Postscript error. You may be using a Postscript driver on the printer. Or else you are printing PDFs which are not true Postscript. likely made by a postscript "compatible" software.
Try loading a PCL driver for the printer. This will work just as well if not better than a postscript driver. You may find it faster.
Check lexmark website under support andd downloads for an alternative driver for the printer, also considering your operating system.
If you are printing PDFs or postscript files, the PCL driver may help there also.
May 23, 2011 | Lexmark T644 Laser Printer
I can,t getmy printer to print from the computer. I have try everything.
What OS are you using? Check that you have the correct (latest) driver for your printer available here: http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=1138346& Select your OS and click Next. Uninstall the old driver and disconnect the data cable (for directly connected printers) before installing the driver. For those Windows OS versions that include the driver with the OS, if the driver isn't automatically, check Windows Update for new updates (check for Optional Updates).
Are you getting any error messages (flashing lights on the unit)? Paper jams or low ink could be the problem.
Since the printer is a USB printer, try a new USB cable or a different USB port on the computer. Try a direct connection if you use a print server or USB hub. Check that the USB ports are working with a known good device. (For Windows, check if the USB ports are active. They can be turned off for security or power savings. The first is under the Device Manager (also check the driver status for the USB itself); the second is part of the Advanced Settings from the Screen Saver.)
Are the print jobs going to the queue and staying there? What is the printer status? For Windows, see the Devices and Printers Control Panel (older versions of Windows gave Printers and Faxes, IIRC). Try clearing the print jobs. For Windows, you can force this to empty by stopping and restarting the print spooler. Use the Command Prompt (for Vista and Win7 right click and choose Run as Administrator) Start > All Programs > Accessories > Command Prompt.
Type "net stop spooler" at the first prompt without the quotes followed by enter. Type Y if you get a warning about stopping the Fax Service. On the next line, type "net start spooler" again without the quotes and then hit enter. When you get a third prompt, restart the computer. Then check your printer queue. (You could do only the first step and then restart; however, you will need to go for a coffee break after the restart.)
Once the queue is empty, try a new print job. Next try resetting the printer. Unplug the printer (from both the computer and the outlet) and remove the data cable (from both the computer and the printer). Wait a short while and then reconnect everything. Try printing again.
Try printing a different type of file from another program. For example, PDFs sometimes won't print from Adobe Reader. This could result from a damaged PDF, a problem with Adobe Reader or something else. You can try using the Advanced Printer Properties (click the box when you select which printer you want to print to) and try printing the document as an image. Also try printing the same document from another computer/printer (transfer it to external media if you use another computer to minimize additional file transfer damage).
I hope this helps.
(BTW if you use a Mac, do not delete jobs from the Print Queue. Instead press Cancel at the printer. Otherwise, your computer may lose the connection to the printer.)
Nov 22, 2010 | HP Officejet 4315v All-In-One InkJet...
Network Printing Issue. I'm running 2008 Domain Controller 2003 File and Print Server. Cisco 3560G switches No 3rd Party print management software User workstations are all Windows Xp Pro SP2 Printers are...
DNS errors then? can you map to the printer via hostname too? Are you sure you're not using SP3? When we upgraded to SP3, we had to use the new drivers. Try new drivers.Have you tried just rebuilding your print server? try sharing the printer off your computer in the data center and try t print to that. When you ping the data center from the user's computer... what is the delay?
Oct 13, 2009 | HP LaserJet 4250n Printer
Zebra p330i just says downloading data
The reason in incorrectly established drivers, or in the printer. Better certainly to give to repair.
http://conditioner2009.bravehost.com/
Aug 08, 2009 | Zebra Eltron P310 Thermal Printer
Hp laserjet 4650n
Hi 123sha:
49.XXXX
PRINTER ERROR
To continue
turn off then on
A critical firmware error has
occurred that caused the
processor on the formatter
to abort operation. This type
of error can be caused by
invalid print commands,
corrupt data, or invalid
operations. In some cases,
electrical noise in the cable
can corrupt data during
transmission to the printer.
Other causes include poorquality
parallel cables, poorconnections,
or home-grown
programs. On rare
occasions, the formatter is at
fault, which is usually
indicated by a 79 Service
Error.
1 Press CANCEL JOB to
clear the print job from
the printer memory.
2 Turn the printer off and
then on.
3 Try printing a job from a
different software
program. If the job
prints, go back to the
first program and try
printing a different file. If
the message appears
only with a certain
software program or
print job, contact the
software vendor for
assistance.
4 If the message persists
with different software
programs and print jobs,
disconnect all of the
cables to the printer that
connect it to the network
or computer.
5 Turn the printer off.
6 Remove all memory
DIMMs or third-party
DIMMs from the printer.
7 Remove all EIO devices
from the printer.
8 Turn the printer on.
9 If the error no longer
exists, install each
DIMM and EIO device
one at a time, making
sure to turn the printer
off and on again as you
install each device.
10 Replace a DIMM or EIO
device if you determine
that it causes the error.
Try new network card
pdouglasss
Jun 18, 2008 | HP LaserJet 4650 Color Printer Manual...
Canon i965 flashing amber light
Hi nnub1,
You might try unplugging the printer from electrical source and try unplugging your data cable from the computer. Shut down your computer and disconnect the data cable. Start your computer and then reconnect the data cable. This is assuming you have a usb data connector.
What you want to do is to try to get the printer back to its default settings. The amber light flashing is trying to tell you something. You should also unload any pending documents to try to get the printer back to its default state, but disconnecting data cables and or power connection is going to be required.
Respectfully,
Terry
Jun 10, 2008 | Canon BubleJet i965 InkJet Printer
Printer will not print
Below are instructions for resetting the printer. However, if they don't work, you may have to have the unit serviced - if it's still under Canon's 1 yr warranty, go through them... if it's not, I would weigh the cost of repair to what it would cost to replace the unit altogether.
By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, power down your computer as well -- and unplug the USB cable (from the printer) from your computer,.and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer and computer back on.
Good Luck!
Maggie B
Feb 24, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
Canon ImageCLASS MF4350d Laser All-in-One  Printer Logo
320 people viewed this question
old marine
old marine
