Question about Samsung RS2556 Side by Side Refrigerator
Replace door handle on refrigerators model number rs2556sh
4 Suggested Answers
SOURCE: Samsung model RS2556SH, refrigerator
Refrigerator temperaure gauge keeps blinking and fridge is only cooling to 35 degrees
Posted on Feb 17, 2010
  • 17 Answers
SOURCE: How to manually trigger the
simple switch off for 4 hrs
Posted on Dec 31, 2010
I have a Samsung fridge model no. RS2556sh. We lost power and when the power came back on the fridge did not. The LED is blinking in the top right corner and the lights or on inside the fridge but not cooling in either side. It doesn't sound like the compresser or any of the fans are coming on. So, what's wrong?
Posted on Sep 02, 2011
How do I tighten door handle on frigidaire model jsi-26
Good Morning Chris, thank you for your inquiry!
From my understanding you need to tighten the door handles on your Frigidaire refrigerator. I was unable to locate any information on your model JSI-26. Without the model number I would be unable to provide you with proper instructions on how to tighten your door handle. Could you please provide me with your model number? You can locate your serial tag (which lists your model number) on the right hand wall of your refrigerator. With that information I would be able to assist you further. -Matt
Aug 01, 2015 | Frigidaire Refrigerators
I have the Frigidaire Model BFHS2611LMO Side by Side and the handle on the right side is very loose. I took off the rubber seal on inside of door but dont see any screws to tighten. How do I tighten
The model number is actually BFHS2611LM0. The handles have keyhole openings that fit over the pair of screws (near the top and bottom of the handle) on the outside of the doors. Try pushing the right side handle forward and down to lock it back onto those screws. If that doesn't solve the problem, push the handle up and then lift it off the screws. Then tighten the screws a bit (or replace them if they have stripped threads). Then replace the handle over the screws and push the handle down. Do not overtighten the screws; that can damage the door components. The manuals is available from Frigidaire's support site: http://b2b.frigidaire.com/support/manuals.asp . The support page for your refrigerator is here: http://b2b.frigidaire.com/support/ResultsPage.asp?strModel=BFHS2611LM0&User=&Search=Search . The parts diagram shows how the handles are attached; it's the last link on the support page.
I hope this helps.
(please replace the door seal properly to ensure that your refrigerator maintains it's efficiency. http://www.searspartsdirect.com/frigidaire-refrigerator-parts/model-BFHS2611LM0/1428/0165000.html has another copy of the parts diagrams with the parts for sale.)
Jul 28, 2015 | Frigidaire Refrigerators
GB2FHGXB01
Are you sure of the model number? I don't see a Whirlpool GB2FHGXB01 ; I do see a model GB2FHDXWB01.
For this model, there are several different door handles. One has a Philips head screw hidden under a trim piece. To expose the screw firmly push the trim away from the center of the handle. (This is for a standard Whirlpool fridge door handle.)
The French door style refrigerators have slightly different door handles. One uses Allen screws as set screws to secure the handle. (This screw needs a 3/32" Allen screw (hex key) and you can access it through a small hole in the underside of the handle on the loose side.) Be careful not to overtighten the screw or you may strip the threads and have to replace parts.
The other option has the handle mounted on brackets on the door. To access the bracket, grasp the freezer handle and pull it to the left. Then pull the handle away from the refrigerator.
For pictures of the handles, see pages 9 and 10 of the manual. It's available here: https://www.whirlpool.com/digitalassets/MLPDF/User%20Instructions%20-%20W10366204.pdf .
I hope this helps. If you do have the GB2FHGXB01, check if any of these directions help. Most refrigerators use one of the above door handle designs.
Apr 28, 2012 | Whirlpool GB2SHDXP Bottom Freezer...
The handle broke on the door. Model ET20NKXDW02
Go online to Whirlpools web site with model number. You should be able to purchase a new one, and if you dont have a manual, you should be able to download one to show you how to replace the handle. Usually you unbolt the handle from the top of the door/handle and the same with the bottom.
Oct 04, 2009 | Whirlpool Refrigerators
Broken door handle
The fresh food door handle is part number is 218668401 and the freezer dor handel is part number is 218668401 same number. Visit my web page and enter your refrigerator model number WRS6R3EW1 or mthe door handel number
218668401 in the model or part search feature. Below is the like to my web page. (Click on link below)
http://servicepartstec.blogspot.com/
Thanks, Sea Breeze
Mar 26, 2009 | Refrigerators
Mar 13, 2009 | Samsung RS2556 Side by Side Refrigerator
Broken door handle needs replacing
I assume you need a paert number for the handle. according to the model number you gave I need to know the color of the refrig in order to get you the correct part number or you can go here input your model number then find youre part yourself. just remeber your looking for your color handle to be sure and get correct one. peyton
Jan 27, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
ISO refrigerator door handle
Your original repairman must have looked up a similar model without the snack door. The handle of couse would have also been listed, but this is difficult since A. You do not give your model number and B. (maybe not as bad) we don't know what model number he used when he ordered your door(s). Please list the complete model number of your refrig. (from sticker inside fresh food compartment) and I'll try to help.
Aug 25, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Replace door
The fridge should have come with a card that looks like a credit card to remove the handles.  There are directions in the manual on how to do this.  If you don't have the card then use a sturdy card like a drivers license.
Oct 26, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Samsung RS2556 Side by Side Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
