Question about Craftsman Gas Mini - Tiller/Edger
Why will my tiller only run when the primer ball is pushed in. I replaced the ball and still have the same problem as soon as i let off the primer ball the tiller stops running.
  • Roy Cagle
    Roy Cagle May 25, 2011
    4 stroke or 2 stroke model here? If it is 4 stroke, the main jet is probably clogged and needs to be cleaned (brass bolt that holds float bowl on carb). If it is 2 stroke, then there are different fuel issues, like check valves in carb dirty, debris (flakes of old fuel line) in the fuel lines, bac gas tank vent and/or filter. Many causes for carb problems in the 2 stroke, much more so than the 4 stroke float-type carburetor. Post back. I would like to continue to help.
  • Craftsman Master
  • 7,482 Answers
Hi mjlqm....
Check/Clean/Replace your fuel filter if you have one.
Make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on May 26, 2011
Eager 1 manual
a screw driver fate tip and sharp you have to pry out the retainer clip once out pull out primer ball put new primer ball in put a new retainer ring on find a socket big enough to be put over primer ball and will sit on retainer ring push the ring in till seated
Aug 15, 2014 | Garden
My mantis tiller with a honda gx22 engine starts then shuts off after approx. 30 sec.
If your unit has a primer bulb, start your engine . When it starts to die push your primer, if the engine comes back to life you have a carb issue.
Aug 09, 2014 | Mantis Tiller 4-Cycle Engine Handy Item...
Where is the primer ball
It may not have a primer ball. If it does, it would be attached to the carberator. If it starts, but won't stay running, that could mean your carberator needs to be cleaned/serviced.
May 29, 2012 | Mtd 22" Yard Machine Push Mower
Ryobi RY60511A tiller wont start
when the primer buld is empty, when pushed it should push bubbles into the gas tank and when let go should draw fuel from the tank. the primer buld now when pressed pushes fuel into the carb and should not push back to the tank. when let go again it will draw more fuel from the tank. the inlet nipple on the carb should be the 3 oclock
Apr 11, 2012 | Ryobi Cultivator
Mantis tiller will not start. Cannot get primer bulb to draw fuel.I replaced all of the lines,primer bulb still won't work. Tiller will start by priming cylinder by removing spark plug. Help?
Make sure there are no leaks in the bulb. Did you reattach the fuel lijnes correctly? You should feel resistance after pushing 3 or 4 times to ensure fuel is getting to the carb. If necessary replace the bulb. Otherwise check with Mantis at www.mantis.com or give them a call for troubleshooting assistance.
May 22, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
How difficult is it to replace the primer bulb?
Its not hard it is held in by a metal plate that has 4 screws, remove those, pop out the old primer, push in the new one the reistall with the 4 screws and your done.
Nov 02, 2010 | Mantis 2-Cycle Tiller
Mantis tiller won't start,does not seem to be getting any fuel in
if the primer bulb isn't filling up with gas when you push it the the diphram in the carb. behind bulb is bad needs to be replaced then it should work unless fuel lines are crossed or has holes in them
Jun 08, 2009 | Mantis Tiller
Roto tiller won't start - primer bulb
Carburetor needs to be rebuilt or replaced. Replaced would be my choice.
May 23, 2009 | Craftsman Gas Mini - Tiller/Edger
Wont prime the gas
The problem is probably that the primer ball needs to be replaced. This is a very common problem.
Apr 28, 2009 | Craftsman Gas Mini - Tiller/Edger
Craftsman Gas Mini - Tiller/Edger Logo
245 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
