Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Black smooth stove top frigidare
Have rental apartment and the stove top is horrible. Lighter on the element parts and built up baked on food around edges. How do I clean this?
  • 981 Answers
Regular citrus cleaner/degreaser stuff, and careful use of a spatula to haul off the loosened bits. Then soap & water. How does this relate to the dishwasher...did you think you could evert the stomach of the dishwasher over the stove or something, like a mechanical starfish attacking a metal ****?
Posted on Aug 16, 2008
I have an old Admiral stove, unknown model #. Black, smooth top- all else is white. Wording on the oven buttons have erased, i have no clue what degree i am setting to and or if baking/broiling. Help!
go on line and type in admiral stoves
there are pages of parts suppliers
on the back of the stove or inside the inspection plate at the back there will be a decal stating the model and serial number of the stove
Apr 23, 2015 | Ovens
My Kenmore stove, model #79095680301, was baking some food when it made a loud popping sound. Since then, the control panel doesn't work (and we can't turn on the oven without the control panel). The stove...
Joe,
Sounds like you need to contact a qualified Kenmore technician. It could have burned out an element, wires to the element, etc., but you'll need to be fairly skilled to check these components.
Try contacting Kenmore directly here:
Kenmore Customer Care Customer Service Information
Feb 08, 2018 | Kenmore Electric Smooth Top Stove
Oven will not light
here is most likely the problem...
check them out if you have questions they have a 800# and online chat too to confirm the correct part.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/11-6-632371-/new/Kenmore-Oven-not-heating-66575822002
Jan 28, 2018 | Kitchen Ranges
My Kenmore #79047153401 baking function is not working yet the broiler is functional as well as the warming drawer.
i looked up your model number and it comes up as a duel fuel,gas on top and electric in the stove,i would first unplug it and read out the bake element,check it for continuity,you have to pull off at least one of the wires,set the meter to say 20k,touch the leads together and make sure your meter reads it,then touch the meter leads to both sides of the element,if it stays on 1 the element is bad,if you get any other reading other than 1 then the element is good.if it's good now you have to check to see if you're getting 240 volts to the element,this will be easier if you pull out the stove and remove the back panel and you can check it this way because you have to do this with power going to the stove,if you are getting 240 volts to the element you could have a broken wire or a bad board but most likely it will be the element.also if i'm wrong and this has an ignitor check that out with a meter but like i say this comes up with electric in the stove and gas on top.the bake element part number is 318255401 and it's around 95 dollars,this is on the sears site,hope this helps,http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Range-Parts/Model-79047153401/0583/0122008/R0309147/00003?blt=06&prst=0&shdMod=79047153401 copy and paste for the sears parts site.
Oct 25, 2011 | Kitchen Ranges
Top oven bottom coil doesn't come on. Is it
Yes the lower element of a electric oven is the bake element,the upper on is broil element,
The most usual thing why it doesnt heat is a broken element. Does a part of it look smooth and a part real rough and ragged looking
If a part of it looks ragged and rough the element is bad,it should not be bulged out anywhere of it.
it should look smooth and uniform
If it does seem to be not uniform anywhere on it,replace bake element
Aug 22, 2011 | General Electric Kitchen Ranges
Stove smokes when i turn the oven on
on the oven's smooth surface you should use a razor blade and scrap off the plastic (when cooled).. if the plastic melted on the burner, you may need to replace that particular element from a local appliance part store. easy to do.
Apr 20, 2009 | GE JKS05 Electric Single Oven
Baking element
Pull the two screws out of the element (on the back wall) Turn the power off to the oven and then pull the two terminals off the element. Then check the ohms on the element. If no ohms change the element and your fixed. The element is usually always the problem. You can get the element at your local parts store, or at sears online via model number. If you go to your local parts store take the element with you and the model number.
Nov 17, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Baking element
Hey there. make sure the clock in on manual and not automatic is should show a little hand and not a 0 :)
Sep 05, 2008 | Kitchen Ranges
Preheat taking long time
If your oven has the hidden bake element then it is probably working properly. A standard oven with an exposed bake element will usually take about 12-15 minutes to preheat. The hidden element models take a little longer but they usually heat a little more evenly.
Post back if you have any more questions.
Oct 29, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
94 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
