Question about Kenmore Refrigerators
Every 3 weeks the freezer ices up on back wall and the fan isn't able to circulate the cool air. i defrost it and then the unit works perfectly for about three weeks and it happens again.
    Master:
    Sergeant:
  • 385 Answers
You have a problem with the automatic defrost system. It could be the defrost timer or defrost heater or termination theromstat. You woulld have to check them to see what part is bad. Hope this helped. I don't know if you have the knowledge or the tools to repair it yourself or if you need to call repair tech.
Posted on May 25, 2011
The freezer is not working... It has been slowly warming up for a few weeks. What could be wrong? Also, does this mean that the fridgerator is next to go? We have a GE Model # GSH25KGPA WW
Compressor is one reason why your freezer may not get cold. The compressor which is usually found at the back of the freezer helps to pump out gas/ cold air and the fan circulates this cold air in the freezer. If this compressor is knocked/defective, the freezer won't cool. Also, gas in the compressor sometimes get's finished and needs to be refilled. So, the compressor needs to be checked in a situation like this.
Fan problem is one of the most common reasons for the freezer to start failing, this is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food. You can usually check this by removing an access panel in the back of the freezer to inspect the coils. If ice is built up on the coils, a hairdryer can assist in defrosting them.
It's also possible that the fan is not running at all. If the fan is burned out or the motor isn't running, cold air can't circulate through the freezer and everything will melt. You can normally hear the fan motor switch on and off from time to time. Listen for it and if you can't hear it coming on for an extended period of time, the motor may need repair or replacement. The wires connecting to the fan may be the problem, preventing the fan from receiving electricity.
Several other problems could be keeping your freezer from freezing:
There could be leaks in one or several of the hoses in the refrigerator, which results in the cold air being lost instead of circulating properly throughout the fridge and freezer.
If you have the freezer so full that the cold air can't circulate, your food will thaw even though the freezer isn't malfunctioning. Always leave some space open in the freezer and try to not store food right up against the cooling vents.
The thermostat might have shorted out, which means the freezer can't accurately determine how cold it is. If this is the case, the refrigerator would probably not be working, either.
If your defrost drain becomes clogged, the water in the line will just refreeze over and over again, which could damage the lines as well as the fan. Always check the drain and make sure no sludge is building up in it if you have a self-defrosting refrigerator.
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster.
I hope the above helps.....
Good luck.
Sep 14, 2011 | Freezers
My freezer is no longer freezing
Regards.
Sep 14, 2011 | Hotpoint Freezers
Coolzone compact fridge freezer works for a while (a day) then totally defrosts and will not come back on. I turned it off and switched backed on later and it came back on again but keeps doing the same -...
Fan Problems
One of the most common reasons for the freezer to start failing is called "frost free failure." Ice can build up on the evaporator coils over time, and this ice builds up until it starts blocking the fan. The fan is responsible for circulating cold air throughout the freezer, so if it is blocked the freezer will not be able to freeze any food.
Other Causes
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food.
Hope this would help.
Have a nice day : )
Aug 17, 2011 | Refrigerators
Kenmore refrigerator(model 10653606202) freezer is cooling, can hear the circulation fan' noise, also see defrosted water in the bottom collection pan. but the refrege is not cooling.
If the freezers is freezing everything and you can hear the circulation fan, maybe it is a defrost problem. Sometime ice will build up behind the rear panel in the freezer section that blocks either the chilling tubes to the refrigerator section.
You will need to remove the food from the freezer, then remove the shelves and inside back panel of the freezer. If you see a lot of ice, that is probably your problem. DON'T use water to defrost, either unplug and let it set with the door open or hurry it up with a hair dryer.
It also means your defrost assembly has stopped working and will need replaced, but the unit will work without it for several weeks before the ice build up redevelops.
Jun 07, 2011 | Refrigerators
My kenmore refrigerator model # 363.9771611 runs but is not cooling and the freezer is not freezing
Fan Problems
Other Causes
Have a good day! : )
May 04, 2011 | Kenmore Refrigerators
Not cool enough to freeze the food
Let's start by diagnosing the freezer;
I hope this helps.
Regards.
May 02, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Wont freeze
Always try to keep the freezer door closed for long periods of time. The more the door is opened, the more warm air is let in and cold air is released. If the door is opened frequently, the freezer could be warming faster than the fridge can cool it, which will thaw your food........
Take care.
Apr 30, 2011 | Turbo Air Freezers
Imperial commercial upright. Top shelf is icing and frezzing bottom is not freezing.
I hope this helps........
Good luck.
Apr 12, 2011 | Freezers
Kenmore refrigerator will not cool. Freezer works
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 27, 2009 | Kenmore Refrigerators
Refrigerators Logo
51 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
