I have a siemens front loader WM14S440AU am getting the F18 error message, have emptied the black hose in front but cant get the hose pump cover off, it only twists 45 degrees and wont go any further and it wont pull off either, how do I get this off
  • 1294 Answers
SOURCE: Zanussi front loader
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Height of exit hose should be approx 3 feet from ground level.
Rate me pl.....if helped.
Posted on Jan 02, 2008
  • 4 Answers
SOURCE: kenmore 43042 front loader, black boot (?) twisted and loose
the black gasget on the inside of the door is suppose to be loose and flexible for sealing purposes.
when your washer went thru it's spin cycle is it possible the throw pillow got cought between gasget and wetal tub?
also is this the only time you noticed this ?
Posted on Oct 01, 2009
SOURCE: I have f18 message and need bit of help with the solution
We had the same problem with opening the pump cover;
The solution was taking more of the washing machine apart because there was something blocking it from the inside and preventing it from opening.
Trying to force it may cause more damage so unplug everything and tip it backwards - no need to lie it flat, do it just enough so it is stable and doesn't fall over.
Take off the front bottom panel on the machine.
Undo the screw holding the filter housing to the front of the machine and lower it inside the machine, next unscrew the hoses and disconnect the wiring from it. This will allow you to pull the filter out completely and to open it up.
Clean the pump, check that there's nothing in the pipes/hoses and then put it all back together again in reverse order to which you took it apart in. (i.e. put together the last part you took apart and work backwards).
Posted on Oct 31, 2009
  • 6277 Answers
SOURCE: F18 error message siemens washing
For most models- you do not say which yours is- Bosch's 'F18' states 'drainage (filter) problem.
I advise you read through these guidance notes and check the filter AND the operation of the drain pump itself- it could be jammed.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 12, 2011
  • 6277 Answers
SOURCE: Siemens s14.36 f18 error message with slight
For Siemens washers 'F18' definitely states that there is a problem with the filter (which you don't mention, only 'pump')
Read through my guidance notes and check the state of the filter AND check that the pump is not jammed and actually working. It says how to do this near the end ;-0)
John C
Testimonial: "Very helpful. Will definitely contact again if another issue arises. "
Bosch exxcel f18 error. Machine runs cycle but will not drain water. Have emptied and unblocked pump on front and checked drainage hose.
according to what i find on google, it's a drainage fault, drain manually and check filter...ALSO CHECK OUTLET PIPES FOR ANYTHING BLOCKED IN IT
Dec 29, 2013 | Kenmore Washing Machines
Siemens s14.36 f18 error message with slight burning smell. Cleaned pump but still get error message.
John C
Sep 12, 2011 | Siemens Washing Machines
I have an lg front loader washing machine...it keeps stopping mid cycle and gives a troubleshoot code of oe...i cant find my owners manual and the lg site is awful....can you help me?
OE is drain error..Most likely problem is partially blocked pump filter...This is accessed via the small door at floor level...Unscrew the pump cover and clear the filter..Any water in the machine will flow from the pump cover...Empty the machine first...Leaning it back can help....Good luck....Nomess
May 14, 2010 | Washing Machines
My frigidaire front laod washer has an E20 error message.
E20 error is known for pump out issue.The first thing I recommend is to take off the front bottom cover(below the door) tilt the washer back some,remove the clamps and hoses from the drain pump.It should be on your right hand side.Check the pump and hose to remove the clogging.This tends to be a common problem with Frigidaire front loaders.Now when you all done with that put it back together and do a test run.
Apr 11, 2010 | Frigidaire ATF6000ES Front Load Washer
Sep 14, 2009 | Bosch Logixx WFT 2806 Front Load...
The front loader for lg washer won't drain
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 29, 2009 | Washing Machines
Siemens XLP 1400 stops with F12
The manual says that it means there's water in the base pan because the apliance is leaking and you should callCustomer Service.
I cleaned the filter and then put the machine onto its Empty cycle. After that it worked.
Oct 19, 2008 | Siemens WXLP1460 Front Load
F18 Error
the error is caused by a blockage in the pump you need to drain the washer using the black tube near the pump drain or by unscrewing the pump cover next to it on excel 8kg washer these are at bottom right of machine. when all water out remove pump cover that you loosened to get water out then check for blockages inside. the pump has a device inside that should move round freely remove all debris replace and try to drain using drain cycle this will finish and hey presto back to normal!!
Oct 05, 2008 | Siemens Washing Machines
Error code f 05
this worked for me and I made 25p for the trouble:
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Comment by pulmicort, posted on Feb 02, 2008 Further to my comments re clearing scrap from table tennis ball after code F4. Machine started ok but then F5 came up. Had to take the pump off and apart to reveal broken hairclip actually seized in pump. If you are handy at all this is simplicity itself.
Slide pump to left and lift and it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. Pump and hoses lift out easily. 3 screws open the pump. Clean any obstruction and reassemble. A 30 minute operation.
Mar 16, 2008 | Hotpoint Ultima WF860 Front Load Washer
Why is the fault F18 error code on my bosch washing machine flashing?
Open the small flap at the front bottom right of the machine. DONT unscrew the circular white knob yet!!! Use the small black hose to drain the machine into a tray, by removing the small cap on the end of the hose. You will have to use a tray, rather than a bowl because the hose is only short, and keep emptying the tray.(put a washing up bowl next to the machine, so you don't have to carry the tray.) If water does not come out of the hose, then gently unblock it with a piece of wire or fine knitting needle. When water finally stops coming out of the hose, it is time to gently unscrew the white knob anti-clockwise, and pull it forwards. Now you can clear the debris out of the pump rotor, which is behind the white knob. Check with your finger that it can rotate freely, then replace the white knob firmly. Make sure the small cap is replaced on the end of the hose, clip it back into place and put back the cover panel. If this doesn't work then there is a blockage deeper in the machine, and dismantling will be required. Good Luck!!
Feb 03, 2008 | Bosch Logixx WFT 2806 Front Load...
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
