Question about Kitchen Ranges
My door assembly glass is broken can't find my model # at online stores to find a replacement, are other models complatible?
    Master:
    Sergeant:
  • 385 Answers
Sorry but no.
Posted on May 25, 2011
How to clean between glass oven doors on whirlpool oven?
You need to remove the inner door panel, Usually a few screws holding it on. On some models the handle screws also need to be removed. Do it slowly and carefully as the door may want to swing up quickly, once the weight on it is removed. Pay close attention to each step so all screws etc go back in the same place. Make a diagram as you take them out to be sure.
Aug 10, 2014 | Whirlpool RBD305PD Electric Double Oven
My Bosch Dishwasher door sticks shut at the end of the cycle. I can open and close it with ease during the cycle, but once it finishes I have to pull really hard to open it.
see all this steps and fix it. God bless you
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Door wont shut
Door Hinge
Door Catch
Door Lock
Door Latch
Door Strike
Apr 05, 2013 | Miele Dishwashers
Broken door window was replaced now the door latch doesn't work properly.
could be a couple of thing on is the pieces of broken glass went into the lock assembly or a rod got bent replacing the glass
Jun 16, 2012 | Cars & Trucks
Kitchenaide gas range inner door part number 9781721 is cracked.
To replace the door glass do the following:
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Remove the inner screws. Keep all set of screws ordered, and take noteof the order you remove them. You will follow reverse order inreassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
Here the part Inner Door Glass
Mar 24, 2009 | KitchenAid KGST307 Gas Kitchen Range
Replace inner oven door glass on kitchenaid wall oven
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
Part here: Inner Door Glass
Mar 22, 2009 | KitchenAid KEBC101 Electric Single Oven
Broken inner glass on Model # NGSG3PZAQA
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
Broken glass on full sized microwave door
Unfortunately, you would have to replace the complete door assembly, you can find a replacement door assembly for this model at this link:
LG LRM1230W Replacement Part Complete Door Assembly
Jan 07, 2009 | LG LRM1230W Microwave Oven
Broken glass door
Depends on the model, check the link below to see if the glass alone is available, if it is not , that means that this is sealend inside the door.
In that case replace the whole door, or the oven wont bake evenly anymore.
See : Enter model number here to find assembly diagrams and parts.
Jan 01, 2009 | Zanussi ZBQ365 Electric Single Oven
Door Face needed (Glass broke, model discontinued, can't get part)
Linda, if you can't find a replacement door at local used appliance repair shops - check the Yellow Pages - look to see how the door comes apart.  It is probably held together with 6 or 8 Philips screws.  Get the door apart and take out the broken glass.  Call around to see if an appliance repair store has an oven they are discarding that has the same size glass or larger.  If the glass is too big, phone a few glass shops to see if they can 'cut' it down for you.  Some tempered glasses can be cut and sanded down to the precise size you need. Take your old broken glass to the shop to be used as a template. You should be able to get away with this type of repair for $50 if you compare prices. Cheers, Pavel
Oct 21, 2008 | Amana AOCS3040 Electric Single Oven
Kitchen Ranges Logo
32 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
