Question about Lands Phones
Why does my telephone ring back after a conversation?
  • 191 Answers
Set the phone to the factory settings once then it will not ring back, This can be a feature of you Epbax if it it connected to one.
Posted on Aug 16, 2008
  • 1,011 Answers
Dear sir/madam,
A method and system for outputting a call announcement based on presence information of a callee as a ringback tone is provided. The announcement system is provided with presence information of users. When the telephone system receives an indication of an incoming call from a caller, the telephone system identifies the callee. After the callee is identified, the announcement system retrieves the presence information for the callee and generates an announcement based on that presence information.
good luck
  • 763 Answers
Sir, you must be fooling by someone or check your phone settings. see the ring back tone settings or see the bottom of your phone. hope that helps sir!
Our telephone only rings twice and hangs up.
Possible short on the line.find the network interface on the back or side of the house(usually next to the power meter).open it up, disconnect the small cord and plug your phone in (phone should be corded) have someone call you.if the phone rings 2 times, chances are it is the telephone comany side. call the telephone co.if it rings normally, it is on your side.fix it yourself, call someone else or call the telephone co.(ex att installer 34 yrs)
Mar 02, 2015 | Lands Phones
My y ovan glass was broken wher it was change
The glass front of the microwave is not important, as long as the mesh behind it is intact.
You may replace it at your leisure, or just ignore it.
To check your microwave for leaks, simply place a mobile telephone inside (do not switch the microwave on unless you are tired of the mobile telephone) and close the door. Ensure the microwave is plugged in. This will create a Faraday cage if the microwave is leak-proof.
Now dial the mobile telephone number. If it rings, you have a leak. Conversely, if not, there is no leak.
Happy cooking!
Jan 28, 2015 | Microwave Ovens
Oil leak
excessive oil comming from breathers combined with the pipes being black could be blowby depending how long ago the conversion was done if it was just done someone didnt check ring clearance or put a ring in upside down if it wasnt just done proabley time to start saving for a top end job till then nothing you can do but ride it
Sep 09, 2009 | Harley Davidson Harley-Davidson Motorcycle...
PIXMA MP780 will not receive fax with Verizon DSL connection. Before unit was ok with comcast cable, Note: I'm able to send fax. RBRANT
Solution: Contact local phone company to check the telephone wall jack for low ring voltage.
Ring-in Voltage Facsimile equipment?(fax machines), like other telephone anwering devices, require ring voltage at a telephone jack to answer automatically.? The ring voltage is one of the services provided by the local phone company.
  • Low ring-in voltage can cause short bursts of ring tones at the phone jack.
  • Callers may hear one or two ring back tones and then ringing will stop and nothing else will be heard.
  • Inside the home, the called party will hear a brief ring and then nothing else will be heard. If the telephone handset is lifted, the caller may be on the other end.
To check if the fax will not answer due to low ring-in voltage, do the following:
  1. Disconnect the fax at the telephone wall jack.
  2. If an answering machine is available, connect it directly to the telephone jack. If an answering machine is not available, connect a telephone to the telephone jack.
  3. Dial the fax line and see if the answering machine answers the call, listen for uncommon ring tones inside the home or check for similar symptoms as described above. If any of the above symptoms occur, please contact your local telephone company.
May 05, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Recording a Phone Conversation
Olympus makes a device that allows you to record telephone conversations without having to hook up anything to the actual telephone. It is called a TP-7. It connects one end to the voice recorder in the mic jack and the other end is an ear bud microphone so that you are able to record the person who you are speaking to on the telephone so that the voice recorder captures both sides of the conversation.
go to click on the link for voice recorders select your voice recorder and then look for the TP-7.
Dec 16, 2008 | Olympus WS-100 Digital Voice Recorder
Uniden 6.0 with 2 handsets
Unplugged all telephones but one and still had trouble so I called Verizon. They discovered it was an incoming line that was malfunctioning. However, the Uniden telephone system still does not work and since it is still under warranty I will contact them.
To continue the solution of my telephone problem - It was discovered that the incoming line was indis repair. After it was repaired, I again set up my Uniden telephone system. It works with no problem. The word "searching"still appears on the face of the units, but it can be overcome with normal activity on the units.
Aug 02, 2008 | Uniden TRU9488 Phone
K80 all in one
our problem is similar and we've posted it....We have one land line with fax over facility. The fax is assigned a different phone number to the telephone line. The fax number rings different to the telephone ring but both are 'two rings' and the fax machine cannot differenciate between the two and keeps answering the telephone. The k80 has a maximum of 6 rings before it answers and this is too few to allow us to get to the phne in time. Also we have an answering machine on the telephone line. How do we get the fax to answer only the ring from the fax over line?
is it the same prob? Cowboy has posted some suggestions.
Good luck
Apr 24, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
Call Pickup Direct
Upon hearing ringing or voice
announcement at another
1. Lift the handset.
2. Dial the Call Pickup Direct
code 67.
3. Dial the station number of
the telephone to be
4. Converse.
Apr 09, 2008 | NEC Electra Elite 32D-1 Corded Phone
Strange telephone happenings
My guess, assuming nobody recorded the conversation, is that the answering machine picked up before the call could be answered. Check your answering machine for the number of rings before it turns on.
Or maybe your answering machine has a memo record on it that is malfunctioning that recorded a memo
Dec 10, 2007 | GE 21028GE3 Cordless Phone
Lands Phones Logo
167 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
