Question about Cameras
How to disassemble and clean a Manfrotto 327rc2 ball head grip.
3 Suggested Answers
SOURCE: Need a user guide for a Manfrotto Bogen 3265 grip action ball hea
Hi, This should get you to what your looking for, Go to this web site : http://www.manfrotto.com/Jahia/spareparts/site/manfrotto/cache/offonce
Posted on Feb 25, 2009
Tri3mast
  • 747 Answers
SOURCE: HI, I have a Bogen/Manfrotto
Hi, extend the extension and look under the mounting head. You will see three set screws requiring a slotted type screw driver. Loosen these off so the head is just protruding from the flange. Have the ball head locked in position and unscrew it from the center mounting stud Left to loosen Right to tighten.
Posted on Dec 12, 2010
How do I tighten my Manfrotto 3265 ? After 15 years of use, it is slipping and not supporting my camera.
Check out the videos at http://bogentripodparts.com/repairs.htm the second on the leftside deals with this problem. They also do reapirs.
Oct 19, 2013 | Bogen Communication Bogen Manfrotto 3265...
Ball slipping
Check out this page and see if there are any parts here that might be what you're looking for:
http://www.bogentripodparts.com/parts/head322RC2.htm
However, I'm not sure there's a way to fix a ball head tripod due to how the tension works for the ball that it rests on. You can also order a new head from the same website. If you have any questions, shoot us an email at email@spartanphotocenter.com
Nov 21, 2012 | Bogen Communication Bogen Manfrotto 322RC2...
Tripod & Head attachment
You weed the 520 Ball also called the 3284 Bowl with 75mm Knob
that can be found at the bottom of this page: http://www.bogentripodparts.com/heads.htm
May 02, 2010 | Manfrotto (Distributed by Bogen) 055XPROB...
My 322RC2 Grip Action Ball Quick Release has lost
I had the same problem and found the solution after much looking online. Use rubbing alcohol to clean the ball! This works even with the ball in place as long as you rotate the head around to reach all surfaces of the ball. Note that many suggestions to tighten the Allen screw at the base of grip clamp or to roll the wheel to its tightest position do not work because they affect the amount of effort you need to squeeze the clamp, and not specifically the amount of friction between the ball itself and the head. Over time the ball loses it's grip but rubbing alcohol removes finger oils, dust, airborne pollution, etc. After wiping with rubbing alcohol, my ten year old head is now as tight as the day I bought it! Hope this works for you.
Apr 03, 2010 | Manfrotto (Distributed by Bogen) 190XPROB...
I have a Manfrotto 3265 tripod head. The quick
You can get the quick release lever seperately. Check the website for the part needed.
http://bogentripodparts.com/parts/head3265.htm
Hope this helps,
Andrew
Feb 17, 2010 | Bogen Communication Bogen Manfrotto 3265...
Feb 25, 2009 | Nikon TRIPOD, BOGEN PRO WITH PISTOL GRIP
Manfrotto 322rc2 tripod ball head
here is manfrotto's "How To" site, they have illustrated how to use almost all of their products.
http://www.manfrotto.com/Jahia/site/manfrotto/cache/offonce/pid/2475
hope this helps out. if you have other questions please lemme know
Nov 04, 2008 | Bogen Communication Bogen Manfrotto 322RC2...
322RC2
I just had this same problem and came across your post.  In frustration I held the grip and then let it go very quickly where the grip 'snapped' back.
Now it works.  Go figure.  I will mention a very small piece of plastic fell out of it, but it does not appear to hinder the functionality.
Jul 01, 2008 | Bogen Communication Bogen Manfrotto 322RC2...
Manfrotto Tripod Ball-grip Head 322RC2
If you look on the ring that goes around the ball, on the side by the red tension gauge, you'll see an indentation. It is just barely visible on the product shot above.
In the hole, you'll find what looks like an odd shaped bolt. It is actually a threaded post inside a nut.
Use an Allen wrench (hex key) to tighten this post.
Be careful though, a little tension here goes a long way. You should probably turn it no more than 1/8 to 1/4 turn and then test it. If it still isn't tight enough, repeat until you are satisfied.
You should probably also talk to a trained technician at somepoint to see if the loosening is indicative of a larger problem. I really wouldn't know one way or the other. I just discovered the calibration post by taking mine apart.
Sep 29, 2007 | Bogen Communication Bogen Manfrotto 322RC2...
Cameras Logo
134 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
