Question about Symbol LS3408 Barcode Scanner
How to find the serial number from a Symbol ls3408 scanner if the label is missing
Programming ls3408-fz
We recommend you contact Motorola Solutions
http://www.motorolasolutions.com/support
Mark
Motorola Support
Jan 29, 2014 | Symbol LS3408 Barcode Scanner
Serial number currently shows as out on another transaction. do you want to continue? yes / no
say no because the serial number has been taken out of you inventory on previous scan. you can change the default in the settings
Jan 28, 2013 | Symbol MC9090-G Barcode Scanner
Are the USB drivers for any Motorola/Symbol scanners the same? or do I have to have a specific driver for each device that I want to support?
there are no special USB drivers for those scanners. The scanner get installed like an Standard USB HID device (as a USB Keyboard) on a host computer.
Therefore you dont need an special driver for them.
Oct 11, 2010 | Symbol LS3408 Barcode Scanner
HOW TO PROGRAM A SCANNER USING BAR CODES
Here is the manual. Sample barcodes inside to turn on different barcode types. http://www.fesem.com/download/doc/symbol/LS3408_APG.pdf
May 29, 2010 | Symbol LS3408 Barcode Scanner
How to determine serial number when serial data on outside of unit is missing. Is there another number or electronic serial number stored within the unit?
you press on the keypad.....> *#06#
and then it should say 'serial number', which you then should have a 15 digit number, also kinown as an imei number! hope this helped! =]
Feb 27, 2010 | Symbol MC70
I have a Symbol LS2208 barcode scanner with an RS232 connection. My new computer only has USB. Can I simply buy a new cable for the scanner, or do I have to get a serial-usb adapter to make it work?
You can purchase a USB cable for the scanner. The cable comes out of the handle of the scanner. The part number of the USB cable is CBA-U01-S07ZAR.
Sep 05, 2009 | Symbol LS2208 Handheld
LS2208
Symbol has confirmed that there was a batch of scanners sent out with defective lasers. Call them at 800-653-5350 for a replacement. Have the scanner handy to give them the serial number. They were very helpful.
Oct 06, 2008 | Symbol LS2208 Handheld
Which of the multiple number sin this thing is the serial number??
Well....the serial number is under the battery on a white label...its at least 14 characters long and starts with a date like:
04334520200194 (date is the 334th day of 2004)
Nov 10, 2007 | Symbol MC50 Pocket PC
Symbol LS2208 barcode reader no data to screen
Just because it has a DB9 does not mean it is a direct connection. Many Bar code scanners have the DB9 connecting to a interface box and the interface box connects to the PC. If it is really a rs-232 scanner then you need to configure your serial port to the proper settings specified by symbol. But I am confident that this unit is missing the interface box.
Jun 27, 2007 | Symbol LS2208-7AZK0100S Handheld
Symbol LS3408 Barcode Scanner Logo
151 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
