Question about Lexmark X4650 InkJet Printer
Can't reset ink level on a refilled 36XLA cartridge Lexmark X4650 Can't install Service Center software, Lexmark says it is no longer available.
  • 6 Answers
SOURCE: lexmark x5495
Lexmark advertises the cartridges supplied with this printer as cart. #28 and #29. They claim these are nonrefillable. The refillable cartridges are #28a,29a, 34 and 35, the last two being the high yield carts. Make sure you have one of these.
Posted on Aug 08, 2008
SOURCE: Reset Lexmark 36 Black cartridge?
BINGO just refill my 36 and printing :) just place tape (2) on the bottom the outside points
ONLY THE ONE OUTSIDE BOTH SIDES :) :) :)
HP his something like this too. 2nd try BINGO IT WORK drill right hole place tape back over refill hole LOL
Posted on Feb 09, 2009
sifon
  • 29 Answers
SOURCE: Lexmark x5470 all in one printer-low ink level
Fiend your solution direct from Lexmark. Here is your solution
http://www.lexmark.com/printer/prob676ijt65/solution
921
Posted on Mar 03, 2009
  • 15 Answers
To get your printer to recognize the new cartridge; go to start - printer and faxes -right click on printer - preferences (printing preferences) -settings -load factory settings. Print test page Ctrl+P
Posted on Jul 13, 2009
  • 6 Answers
SOURCE: refilling lexmark cartridges x2500
Hey....I solved the lexmark out of ink problem!!!HA!!! what you have to do if you want to refill these is "pop" off the top of the cartridge. It is not easy as it is glued down...using a small screwdriver preferably a small flat jewelers screw driver you can peel back the plastic that seperates the "lid" of the ink cartridge. you have to use a little force but you can get it off. Once you do this the cartridge will always read full!!!!!! just tape it or super glue it back on. You never have to take it off again! although I recomend cleaning the ink sponges inside every 3 refills. but this works great.....ha ha lexmark.....I got ya!!!!
Posted on Sep 29, 2009
Installed new ink cartridge and will not show that cartridge has been installed- tried 28A and didn't work - picked up 28 cartridge and installed same problem
Please note that if you have refilled your 28A cartridge, it can no longer register it's ink level. However, since you also tried a different cartridge which did not fix the problem, I would recommend you to contact Lexmark Technical Support Center for additional assistance.
Sep 02, 2011 | Lexmark X2500 All-In-One Printer
I've just installed both cartridges in my lexmark X4650 printer but they show as empty on the maintenance page
Note that a refilled cartridge will not be able to report its ink level. Check if correct ink level is displayed on your printer operator panel. Press Setup button > Maintenance > Ink Level - check your black and color ink levels. If ink levels are correct, then the problem could be on your computer.
The Print Spooler service on your computer may be disabled. To enable the Print Spooler service, follow the steps below:
  1. Browse to Start -> Run... and type in "NET STOP SPOOLER" (this will stop the print spooler service)
  2. Type in "NET START SPOOLER" (this will restart the print spooler service)
Try to check your ink levels again.
Jun 25, 2011 | Lexmark X4650 InkJet Printer
How do i change ink cartridges
Hello i hope u 'll be fine.... thanks for using fixya.
Probably
Lexmark X4650 InkJet Printer User Guide will be able to guide you. If you have already installed the Lexmark software on your system you can view the User Guide by going to the Start menu >> Programs >> Lexmark X4600 Series >> User Guide. Scroll to page 94 for instructions on how to install the ink cartridge. If not, you can download it for free from here
User Guide is in pdf format if you have no Adobe Reader software which support .pdf files then Download it from here Adobe Reader
Sometimes the ink cartridge carrier won't position automatically to the center even when the printer is on and the cover is open. Just unplug the printer from the power source.With the cover open,hold the solid white strip and gently slide the carrier to the middle of the printer.Remove the used cartridges. Load the new cartridges.Close the cover.Plug the printer back to power source.
I hope this solution will helpful 4 u. Best of luck
Please keep thumbs up in do rating
THANKS & Keep using fixya
Dec 30, 2010 | Lexmark X4650 InkJet Printer
How do I reset a refilled printer cartridge for a Lexmark X4650?
They are not resettable. This is one of the downsides to using refilled cartridges for this style cartridge. You should be able to tell the printer to ignore the ink levels and just print until it runs out of ink.
Jun 09, 2010 | Lexmark X4690 Wireless InkJet Printer
Lexmark Pro 705 won't let me print after refilled
If you refill the regular lexmark 100 ink cartridges, you will not be able to use it because there is a rfid chip that track the ink usage. you will need to buy the 100a type which will let you print if the ink level is empty. since you have refill the 100 ink cartridge, you can swap the 100a chip to your 100 cartridge.
Apr 19, 2010 | Lexmark X4650 InkJet Printer
Lexmark printer always want a new cartridge
What you need is to reset the ink level:
1) Goto the Lexmark Solution Center application.
2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
Hope this help.
YBC (/\)
May 28, 2009 | Lexmark X2500 All-In-One Printer
Hope this help.
YBC (/\)
Feb 18, 2009 | Lexmark X2500 All-In-One Printer
Lexmark x4650 how disable ink level ... won't print after refill
All printer mfgrs main business is selling ink and toner.
They couldn't care less about the printer itself.
Jan 08, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Printer cartridge is a refill and does not seem to be recognized
Maybe you can try to reset the black ink level 1st. To reset the ink level:
Hope this help.
YBC (/\)
Dec 23, 2008 | Lexmark X2500 All-In-One Printer
Lexmark X4650 InkJet Printer Logo
832 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
