Question about Asko D1876 Dishwasher
Thermostat location on a ASKO D1876 dishwasher. How to test it and or remove and replace it.
Nzero
  • 78 Answers
SOURCE: Asko dishwasher D1876
unblock your filter. unplug all hoses and electrical cords. tip unit up and clean the filter out. should stop all your problems
Posted on Sep 01, 2008
  • 3 Answers
SOURCE: asko d1876 dishwasher
The F2 lights blink due to a water senser in the compartment where the motors are located. Remove the bottom kick panel and other covers to access this area of the unit. Unplug the unit before working in this area as wires are abundant. Check the pan to see if water is present. Dry out the pan with a towel and then maybe a hairdryer to clear the F2 alarm. The real questions is what caused the water to be there. Start a cycle and watch to see if there are any leaks on the inlet water line. If not, let the unit run and see when water enters the pan. If it enters during the washing cycle, a gasket leak is likely. If it enters during the drain cycle, perhaps a drain hose is leaking.
Posted on Feb 28, 2009
SOURCE: asko d1876
I'm not sure about that model, but on an older one, just under the drain area there is a piece os styrofoam attached to a switch. I guess if it rises it activates the circuit. Problem is if it drys it sticks, so push it down with your hand gently. This involves taking off that bottom kickplate area, but that's the only way in there.
Posted on Apr 29, 2009
  • 2976 Answers
SOURCE: Asko 1475 dishwasher - won't wash. Circulation pump?
Check your drain. It is dual purpose. It not only drains but, it also recirculates the water doring the cycles.
Posted on Aug 10, 2009
SOURCE: my asko d1876 is half way through it's cycle and
My husband unclogged the drainage pipe so the water level could go back to normal.
Posted on Jan 30, 2010
D1876 Asko dishwasher doesn't fill. It runs fine if I manually fill the unit with a couple of pitchers of water. Likely culprits seem to be a faulty water level sensor or water fill valve. Any...
Welcome to FixYa.
Based on your description and provided the dishwasher is indeed 1) an Asko D1876 and 2) not filling with water...It sounds like a faulty fill valve/water valve unfortunately.
First though, you can perform a diagnostic/fault trace program by following the steps below. You should hear the valve starting once the unit has started filling with water.
You'll need to be familiar with the control layout for the test to begin. This is how the buttons/display is identified in the diagnostic...
Now you can enter the fault trace by way of the following sequence....
Obviously based on the instructions if you push S3 the valve should open and allow water into the tub, this image below indicates the normal water level to look for when filling in the normal cycle NOT FAULT TRACING...Fault trace will fill until you stop it.
This unfortunately is common with Asko built dishwasher`s, but it can be fairly easily repaired with a little direction/know-how.
**First turn off the water and the power to the dishwasher...safety first**
You should only need to remove the toe panel/kick plate at the bottom and of course turn your water and power off, undo the water line at the valve,
i.e.
...remove the two torx screws ( large arrow ) and then the delivery hose at the back of the valve ( small arrow ) and install the new one.
The new valve is part # 8801351 and available at on-line parts depot "repairclinic.com" for about $170USD last time I looked.
Let me know what you find and I'll try and help you move forward from there...you may opt to call in a pro but that's up to you.
I'll watch for your reply.
Regards,
Macmarkus :)
Jan 30, 2011 | Asko D1876 Dishwasher
Asko d1876 dishwasher
Feb 05, 2009 | Asko D1876 Dishwasher
Asko d1876
Jan 25, 2009 | Asko D1876 Dishwasher
Sep 01, 2008 | Asko D1876 Dishwasher
Need to increase water level in D1876
If you're not getting enough water, your water inlet valve is most likely the culprit.
Apr 23, 2008 | Asko D1876 Dishwasher
Asko D1876 dishwasher
the dishwasher remembers how long the last wash took.was it intterupted? try using again, or the board could be faulty it should be about 2hrs 10 min approx.hope this helps
Mar 16, 2008 | Asko D1876 Dishwasher
Asko d1876 (black)- despenser problems
it sound like you need a new pcb,if the dispenser is making a buzzing sound,then thats it remove the control panel and see if the tracking is burnt anywhere,also replace the wax motor on the drying vent.
Feb 22, 2008 | Asko D1876 Dishwasher
Open Questions:
See all Asko D1876 Dishwasher Questions
Asko D1876 Dishwasher Logo
41 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
