Question about Philips SA5125/37 MP3 Player
Philips gogear 2 gig memory corruption
Mine was plugged into a mac and after it says memory corrupted how do i fix it please help me!!
  • 1 more comment
  • bteraej Sep 20, 2008
    I get a memory corrupted screen as soon as I turn on my mp3 player and when I click repair, it says that it's been repaired and all content cleared. But from there, when I click okay, nothing happens and it just stays on that screen.
  • Anonymous Dec 03, 2008
    how do i fix my mp3 went it says memory corruption
  • Anonymous May 01, 2009
    my ipod have error memmory currpetd
  • 496 Answers
After it says memory corupt it should have a self repair utility on screen i know mine does and i just recently had to use it just hit the over button and it will repair itself but also it will erase all the music and pics on it
Posted on Oct 20, 2009
Go to the philips website and install the device manager. Reset your mp3 player on back with pin. Press and hold vol+ button on side while you plug it in on your computer. Go to device manager and repair.
It took me hours tonight to figure this out. This is a piece of **** mp3 player! It hasn't worked since 2 months after buying. Now it is like new. I would never buy another one!!
Good Luck :)
brenbren1969@gmail.com
Posted on Oct 21, 2009
  • 3 Answers
If it is showing this as you are starting up the player then you should probably get to a computer with that phillips device manager and see if you can 'restore' the files on it with that.
Other than that the only thing I can think of is to connect it to a comp, go into the files of it from my computer, make sure you have 'view hidden files' on, and delete all files on the darned thing.
Posted on Sep 05, 2008
I ran the battery on my MP3 player completely down and it shut off. I charged it and now all the songs are gone... is there a way to recover the lost songs?
Try this:
1)Perform a system reset, which won't erase your files, to attempt to correct playback. Locate a thin object, such as pen tip or unfolded paper clip and insert it into the small reset hole on the bottom of your GoGear. Hold the thin object in place until you see the unit shut down completely. Your system has been reset. Power the device back on to see if the corrupted files have been corrected. If the reset failed to correct the issue, perform a file recovery on your GoGear.
2)Initiate a file recovery by first connecting your GoGear to your computer. From your computer's "Start" menu, choose "Programs," "Philips Digital Audio Player," "Area Device Manager" and "Philips Device Manager." The Philips Device Manager software will be activated. Inspect your GoGear to confirm that it is turned off. Plug the small end of the supplied USB cord into the bottom of your GoGear while holding down the "Volume Up." Insert the larger end into a free USB port on your computer. Hold the key as the "Philips Device Manager" reads your GoGear and activates recovery mode. Click "Repair" and follow the onscreen prompts as given by the "Philips Device Manager" to complete the process of memory recovery. Disconnect your GoGear from your computer properly after the process is complete and restart your MP3 player.
3)Reload and replace the files onto your GoGear by first connecting your GoGear to your computer. Plug the supplied USB cord's small end into the bottom of your GoGear and the large end into your comptuer's USB port. Initiate Windows Media Player by clicking on its icon if it doesn't start upon connection with your GoGear. In the left pane of the WMP, click "Philips GoGear Aria." Click the arrow on the top left edge of the WMP window, followed by "Music." Highlight all files, and click "Delete." Click the "Sync" tab on WMP, and drag and drop the music files you would like to replace and reload into the "Sync List" panel. Click "Start Sync." The files will be freshly loaded onto your GoGear.
4)Properly disconnect your GoGear from your computer to avoid memory corruption by first closing all applications in use by the GoGear (WMP). Click the USB device icon in your system's tray (located on the bottom right corner of your screen). Follow the prompts in order to safely remove your GoGear from your computer. When your computer tells you it's safe to remove your GoGear, unplug the USB cord from your GoGear.
Hope this helps!
Apr 08, 2011 | Philips GoGear ViBE Digital Media Player
I 've got virusses on my philips, i've format it through linux but the message from philips is "file system error" so what should i do? thanks more
ok what you need to do is repair the firmware. The file system error has nothing to do with a virus. It means the firmware has become unstable or corrupted through any series of events.
by following this link http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=SA6045/37&scy=us&slg=en you can download the software/firmware needed to reflash the device and this should solve all of your problems with the file system error. Ensure that it is the correct model number and download the files and flash the device by following the instructions on phillips website.
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
Aug 19, 2010 | Philips GOGEAR SA6045 MP3 Player
Whenever I turn on my Philips GoGear SA5125 - it
when an Mp3 goes off like that, is means that the Mp3 is corrupted with virus from an application you installed or a data inside the Mp3 player and and has caused it to have memory loss.
To restore the memory of the Mp3 back to normal, you need to flash the Mp3. Flashing restores back memories that where lost.
After flashing it, it will start working properly again.
Take care.
Apr 13, 2010 | Philips SA5125/37 MP3 Player
All songs wont go on,then memory gets corrupted
i think the flash memory is defective. if you have still warranty on your device bring it to your dealer. if not, you could try to format the players memory. go to my computer, right click on the device and use the option format. data format should be fat32. you do this on your own risk.
Jul 23, 2009 | Philips GoGear SA3125/37 MP3 Player
Philips gogear sa145/02 4gb when i turn it on get message memory corruption repair now
go to magnovox.com and dowload root software delete all files on the gogear the add software to the root menu in the gogear this will reset it to default you will loose your songs but fix the problem
Apr 17, 2009 | Philips Audio Players & Recorders
I need software for my 2 gig philips gogear
the video player only accepts WMV format videos
please rated my solution...
Feb 06, 2009 | Philips GoGear HDD6330 MP3 Player
File system error
my mp3 have a file sistem error, please helpme.
Jan 10, 2009 | Philips GOGEAR SA6045 MP3 Player
Philips GoGear 2GB memory corruption
You have to do the "update" in the Philips Device Manager (make sure you are connected to the internet when you do) to repair the corruption: Recovery Mode for Philips' GoGear
Open the Philips Device Manager (Start à All Programs à Philips Digital Audio Player à SAXXX à Philips Device Manager) and click on the “Repair” tab.  Then click on the “Repair” button to start the repair process.  Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in.  If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
Philips GoGear Firmware Upgrade
You need to get the latest firmware upgrade from the Philips website:
1. Go to www.philips.com/support
2. Enter your country/language
3. Enter your model # SA6045 or whatever
4. Click on the link for your exact model # (the one w/o the "B" in it)
5. Click on "Software & Drivers"
6. Download the updated "Device/Firmware Manager"
7. Once installed, open the Philips Device Manager
8. Click on the "Update" tab, then the "Update" button (with your mp3 player connected to the computer, of course)
9. Your Mp3 players firmware will update automatically
If you do not have the latest version of the Philips Device Manager installed (the latest is the version from the Philips website), then clicking the "Update" button will give you a false positive saying "The firmware on your device is already up to date."
-Tha Mp3 Doctor
Sep 10, 2008 | Philips GoGear HDD6330 MP3 Player
Gogear 8gb
The HDD1830 is not Mac compatible. The database file has probably been deleted or corrupted. The player doesn't scan the hard disk on start-up, it only read the database file. Anything it doesn't read from the database file is ignored.
You will need to restore the player with the Philips Device Manager, and re-load your tracks.
Jun 20, 2008 | Philips GoGear HDD1830 MP3 Player
Memory corruption
My mp3 player Philip SA51xx 2gb says "memory corruption please repair it now" can I ask your hepl to fix the problem thank you
Dec 24, 2007 | Philips SA5125/37 MP3 Player
Philips SA5125/37 MP3 Player Logo
1,901 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
