Question about Sirius Hood Built-in Powerpack, SU900
The remore does not work and cannot find anyway to turn it off...battery appears to work as the red light is on
My son has the airhogs switchblade, it is fully charged (remore control button is green) but when he turns on the switchblade it doesnt work?
Blinking red means the Switchblade hasn't sync'd to the remote.
For almost all R/C you need to follow a specific sequence, whether its:
Remote on, vehicle on, (wiggle stick on remote).
Vehicle on, remote on, (wiggle stick)
There's usually an additional process for a vehicle that has built in gyros, etc.
Jan 02, 2017 | Cameras
Hi. my original remote for my onkyo tx ds575 all of a sudden is not working anymore. the red light on the remore still lights up when i press a button but the receiver is not picking it up. hopefully you...
The red light on the remote just means the battery is good and the remote is responding when you press a button. It doesn't mean the control is actually sending out a signal. Many retail stores have a tester that will tell you if the remote is transmitting. Another possibility is that the remote sensor in the receiver has gone bad, and that the remote is fine. A universal remote (One-4-All URC6131, for example) that can work home theater receivers can be used to test the receiver. It may not work all the functions, but if it turns the receiver on and off you'll know the remote is at fault and not the receiver. Then you'll be able to replace the remote or have the receiver serviced as needed.
Mar 21, 2011 | Onkyo TX-DS575 Receiver
My B&W Zeppelin has a flashing red light and will not play my IPod. The remore control also does not work.
the red light designates the known power supply problem, this is a known fault in all but the very latest z2 model. contact point of sale or b and w service and they should organise the fix and check you unit for the other known problems.
Jan 30, 2011 | B&W Bowers and Wilkins Zeppelin iPod Music...
Just want to program remote model # rcr311w for
ok dont know the remote you speak of but most are the same.
select TV and SET buttons in that order a red light appears and is steady. Enter the code eg 123 and the light should go out Pres SET again turn set off using power btn then turn on again. If you entered the right code both on/off will have worked. If your remore does not have a set btn then it is a pre programmed remote and is damaged if not working with new batteries Get a Universal remote and follow the instructions to control you TV.
Please rate our help to keep the service online
Aug 28, 2009 | Televison & Video
Need codes for a AKARI 14" color TV IC-1494RAK
1. Turn TV on
2. Press TV key on remote.
3, Press and Hold magic button until red light blinks twice, it will blink once and then twice.
4. enter 991 red light will blink twice
5. Hit the power button
6. Aim the remote at the TV and press the channel plus button until the TV turns off.
7. Hit the magic button as soon as the TV turns off to store the code.
Hope this works for you!
Jan 03, 2009 | One For All URC 7740 Remote Control
Sony KLV-S23A10 takes approx 30 minutes to warm up
OFF YOUR TV WITH POWER BOTTON, THEN PRESS IN REMORE CONTROL DISPLAY BOTTON # 5 BOTTONVOL + BOTTON AND POWER BOTTON.( DISPLAY--5--VOL+--POWER)
May 04, 2008 | Sony KLV-S23A10 23 in. LCD HDTV
Problems with my Apex CHKT2A remote
I've seen remote sensors that quit but it's rare, usually due to water getting dripped on them from cleaning. Pick up a cheap programmable remote and see if it will work. Long shot, check the menu, in some sets the remote can be programmed off.
Mar 28, 2008 | Apex Digital GB5108 51" Rear Projection...
Sirius Hood Built-in Powerpack, SU900 Logo
22 people viewed this question
Top Sirius Kitchen Ranges Experts
Thomas Perkins
Thomas Perkins
Zeagle
Level 1 Expert
ray gallant
Are you a Sirius Kitchen Range Expert? Answer questions, earn points and help others
