Question about Dryers
Taking a long time to dry. - Dryers
  • Dryers Master
  • 7,482 Answers
Hi dawansd
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
This is a Free answer, Please rate me.
Posted on May 26, 2011
It is taking far too long to dry, this has only recently started? what could be the problem?
Does it get hot? If it does, then the problem is reduced air flow, caused by a lint filter that hasn't been cleaned, masses of fluff in the exhaust pipe (usually on bends), or the external vent not opening properly. Birds can also nest in the vent pipe if the vent isn't protected or is broken.
If it doesn't get hot, you need a new element. Some dryers have two elements if the dryer has a high and low setting. just one element can fail.
Jan 20, 2016 | Zanussi TC7102W Electric Dryer
What setting for drying clothes takes the shorties time
make sure your filters and around your drum is clean that is a reason for clothes taking long to dry
Oct 13, 2014 | Dryers
My Kenmore 6.7 cu ft he2 Super capacity electric dryer is taking twice as long to dry. no error codes
It sounds like a connection problem with one of the heating elements, or perhaps only a clogged input or output hose from the dryer. Either of these could cause the problem...also, a burned out electric element.
Jan 15, 2013 | Kenmore Dryers
Dryer taking too long
Make sure the lint filter is clean and that the exhaust duct and outlet are not clogged. If the duct is clear check to see if air is being blown through. If not then the blower fan may be disconnected from the motor shaft.
Jan 17, 2010 | LG DLE2532W Electric Dryer
AUTO CYCLE TAKES A VERY LONG TIME, HEAT IS OK, GAS DRYER
First thing I would check is the vent. If you have good heat but it is still taking too long, usually it is caused by a vent that is either too long , kinked or clogged. if the dryer is auto dry and not electronic dry then you will need to gauge weather the load needs more or less dry. If it is just taking a long time for the clothes to dry, more than likely the vent. If the clothes are dry before it is done running then it is more than likely a setting issue. Way out of the box .... are your clothes spinning out dry enough in your washer? do they dry in the normal time on timed dry?
Dec 18, 2009 | Dryers
Fisher Paykel Dryer is taking 3 hours to dry(DeIX2)
Check your cvent going outside. also check to see if the vent is smashed. try using the time dry cycle and see how your clothes turn out. if they are still wet or damp. you have a heating problem. try those solutions.
Oct 19, 2009 | Dryers
Dryer is hot, but not drying clothes. taking a
You have a plugged or resrticted exhaust flow. Remove the dryer and clean out the vent hose from the dryer all the way out of the house.
Jun 30, 2009 | Whirlpool Dryers
Kenmore Dryer taking long time to dry
Check your hose that leads to ouside to see if clogged, 2) sounds like your thermostat is going bad, or you have a clog behind the holes in your drum air is not getting out
Jun 11, 2009 | Dryers
Long time to dry
first check the vent to see if its clogged with lint.
Mar 30, 2009 | Magic Chef CYE2000 Electric Commercial...
Heating but taking a long time for clothes to dry
most of the time if it takes to long to dry it is your wall vent hole or dryer vent hole that has gotten clogged,clean both and you should be ok,let me know how you do.-mike
Mar 18, 2009 | Kenmore Dryers
Dryers Logo
99 people viewed this question
Top Dryers Experts
