Question about iLO V27DMBX Television
Ilo-32hd tv only 1 chanel
My Ilo-32HD LCD T.V. will only get one chanel. I have no control of volume or chanel selection. The remote will turn the T.V. on and off, and so will the control button but one chanel is really dull. Please help with any info that you can offer.
  • 3 more comments
  • Anonymous Sep 03, 2008
    I have the exact same problem with my ilo-32hd tv. I have had it about a year.
  • rhuston Sep 03, 2008
    Cabel is connected and I have programmed the TV but channels are not clear.
  • Anonymous Sep 29, 2008
    It just happened to mine today.  im never buying one ever again
  • Anonymous Jan 08, 2009
    My Ilo TV will not let me get into the mode operation to adjust the screen size, it almost like it is the Demo or hospital type freeze mode. I can't change channels or use the volume. Any solutions?
  • Anonymous Mar 28, 2014
    Remote will turn tv on and off volume up and down but wont change chanels
Dude it just happened to mine it sucks!
Posted on Sep 29, 2008
SOURCE:
Cracked lcd trying to buy a ilo-32 hd lcd
You do know that the LCD display will be a few dollars short of a new set ? If your still interested in it then let me know.
May 20, 2009 | iLO 3200 32 in. LCD Television
No function control at all just only on/off
Intial Tech Corporate office: 909-392-5583
i hope this number works
i got it from walmart
Oct 25, 2008 | iLO 3200 32 in. LCD Television
Ilo 32hd tv from InitialTech
I own an ILO TV that is still under the extended warranty. I've had it repaired twice since May 08 and it has failed again. Since it is still under warranty, I will send it back in to be repaired.... again. If I were you, I'd cut my losses and buy a new TV from any store except Walmart.
Sep 19, 2008 | iLO 3200 32 in. LCD Television
Ilotv 32HD
The only way that I know of to eliminate this problem is to buy a new TV. My ILO TV has been repaired twice since May 08 and it went out again for the third time. The problem starts out as an intermittent problem.... You turn the TV on, the audio is fine but there's no picture, you will be unable to change the channel or volume whether you're using the remote control or the buttons on the TV.
This TV should have been recalled. Don't throw good money after bad and don't reward the manufacturer and retailer for their bad behavior, buy your next TV from a different retailer.
Sep 17, 2008 | iLO 3200 32 in. LCD Television
ILO-32HD
Normally this is a good indication of a stuck button on the set. With the set off, try working each of the control buttons. You should be able to feel teh button engage. If one feels like it does not work, that is the likely culprit and it should be replaced.
Let me know your results.
Dan
Sep 07, 2008 | Televison & Video
Ilo-32hd
I'm having the same problem. And yes, it's probably from static shock because I shocked the tv when I went to turn it on the other day. Now nothing, it goes on but none of the button work. Is there anything we can do about this? Help!
Feb 29, 2008 | iLO 3200 32 in. LCD Television
Ilo-32HD
Check the menu to make sure it is not in a lock mode. If that is OK, it probably needs a control board. On some brands that might be called a digital or tuner board.
Jan 22, 2008 | iLO 3200 32 in. LCD Television
Lcd tv black but green power light on
If you're using a cable box , connect box to tv using component cable .
Jan 04, 2008 | iLO 3200 32 in. LCD Television
Cannot change channels
Hi! I have been through this situation on a 26" model of ILO LCD TV. I think the problem you have is the same, but could you clarify one thing for me? Is your model an ILO-3200, or is it an ILO-32HD? I suspect 32HD, because I know the problem exists on the 26HD models which are basically very similar in design and say manufactured by Initial Technologies on the back of the set. Does your unit list this manufacturer on the back? Let me know. Thanks!
Sep 30, 2007 | iLO 3200 32 in. LCD Television
iLO V27DMBX Television Logo
336 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
