2006 VW Jetta, the drivers side tail light is staying on when you turn the car off and is now killing the battery.
  • 2 more comments
  • bharris281 May 25, 2011
    The last 6 digits of the VIN are neither. The last 6 digits are: 720125. Also, is this easy to install yourself or do I need to take it to a machanic?
  • bharris281 May 29, 2011
    Changed the stoplight switch, however, it did not solve the problem, the drivers side light is still on. I think it is the "turn signal/running light" instead of the break light?
    Dont German cars have a switch that allows the drivers side rear running light/turn signal to stay on when parked on the street at night? The main lights switch that has 2 positions, lights on or lights off, turning clockwise for on, counter clockwise for off. This switch also pushes in, and pops back out., but there is not feel of a click to indicate its doing anything.
    Replacing this switch didnt help, Thanks anyway. It turns out that the bulb that is staying on is the turn signal, runnuing light. Dont German cars have a switch that allows this dirvers side rear turn signal, running light to stay on when the car is parked on the street on night. The main lights switch has 2 posistions on or off. Clockwise on or counter clockwise off. This switch also pushs in and pops back out. You dont feel any click like its doing anything when pushing in or when its popping out.
  • 11,800 Answers
There is a short in the lights switch, located on the steering shaft.
The steering shaft will have to be dismantled to have the switch inspected and replaced. Since for that you must disable and remove the airbag it means that - for security reasons - only a repair shop should do it. And do it as soon as possible, if the problem is left for too long the wires inside the steering column might be aged prematurely by the heat generated by the current flowing thru them so they might short causing a lot more damage - you might end up even with an airbag exploding out of the blue in your face, and that can hurt badly.
Posted on May 26, 2011
  • Azrael SRL May 29, 2011
    You must find out precisely which, they have completely separate systems: the turn light has a special relay powering it thru the lever on the steering shaft while the running/position light gets powered by a simple relay that gets activated by another switch situated on the dash. Once you find that out start checking the wiring (at the faulty lights block first), and only then the button.
    It used to be like that with VW in the 80's, and only in the US versions, no longer the case - all VW have now the same EU style wiring. The push in is for high beams flashing.
  • 1,940 Answers
This means your Brake Light Switch, or Stoplight Switch has gone bad.
There are 2 different stoplight switches for the 2006 VW Jetta, depending on the last 6 digits of your VIN #.
If the last 6 digits of your VIN# are 603251, you need the following switch:
http://www.autozone.com/autozone/parts/Duralast-Stoplight-Switch/2006-Volkswagen-Jetta/_/N-jnoxjZ9cias?counter=0&itemIdentifier=201634_0_0_93171
If the last 6 digits of your VIN# are 603250, you need the following switch:
http://www.autozone.com/autozone/parts/Duralast-Stoplight-Switch/2006-Volkswagen-Jetta/_/N-jnoxjZ9cias?counter=1&itemIdentifier=535846_0_0_93172
Posted on May 25, 2011
  • Jeremy Moore
    Jeremy Moore May 28, 2011
    The Stoplight Switch is very simple to remove and replace. What size engine do you have in your 2006 Jetta?
2006 vw jetta will not accelerate and tail pipes shakes and puffs
remove forward o2 sensor and start car if it seems ok have somebody
check back pressure or partial plugged catalytic converter
Dec 20, 2013 | 2006 Volkswagen Jetta
I have a 2006 vw jetta 2.0t and the fans stay on even after the ignition is off and key is out, will run until the battery is dead. I have replaced the coolant sensor and the computer sensor on the...
The fans are run by rad temperature, not engine temp on a VW.Somewhere on the rad you should see a wire harness plugged into it.That is a thermo-switch which turns the fans on and off based on coolant temp in the rad. My car is a lot older than yours but this switch is virtually hidden on the bottom driver's side of the rad. It has 3 wires going into it.There could also be another sensor attached to the engine block or head to monitor engine compartment temps after engine shut off. This will turn the fans on or off as well based on air temp in the engine compartment.
Nov 29, 2013 | 2006 Volkswagen Jetta
2006 vw jetta side view mirrors
Pretty sure the mirror switch is the culprit(I'm assuming the joystick and selector switch are all one piece).
Oct 26, 2012 | 2006 Volkswagen Jetta
How do I replace a tail light bulb for 2006 VW jetta
pull away the carpet from the inside corner of the boot(trunk) and you will see the lamp cluster,the bulbs are held in with clips.do not pull wires.....
Jun 02, 2010 | 2006 Volkswagen Jetta
Looking for the fuse box for lights on a VW Jetta
all the fuses on an mk3 vw such as yours, are under the dash on the drivers side. they are kind of a pain to get to, but if you look under the steering wheel, above the gas and brake pedals, there is a little door that opens, the door has a diagram showing which fuses are which. usually the fuses dont go though, have you checked the bulbs?
Jul 25, 2009 | 1995 Volkswagen Jetta
2006 Jetta TDI Electrical!!!
There is a known issue with the wiring harness in the doors. It's possible that the passenger door also has a bad harness (assuming they swapped out the one in the driver's door) Is that a correct assumption? It may still be related to your original problem too. I've heard of disconnecting the battery for 20 minutes to reset the electrical (door switches). You should def give that a try - it's free.
Also check out the forums at www.tdiclub.com - those guys know their VW TDI's...
Jul 13, 2009 | 2006 Volkswagen Jetta
2006 vw jetta tdi service engine light reset
With the key in the ignition (but not turned), press and hold the Odometer Reset Button on the right hand side of the panel. While still holding that button, turn the key (although not far enough to start the engine) and then press and hold the Minute button on the left side of the instrument pane(if pressing doesnt work try turning the knob clockwise until service light has gone off and skip the pressing)l. Release both buttons at the same time.
May 06, 2009 | 2006 Volkswagen Jetta
TURN SIGNAL STAYS ON IF NOT CANCELLED
IT IS SUPPOSED TO DO THAT, THEY CALL IT A EUROPEAN PARKING LIGHT, THE CAR GIVES YOU A WARNING ALARM AFTER YOU TURN THE KEY OFF, REQUESTING YOU TO CANCEL TURN SWITCH.
Feb 05, 2009 | 2006 Volkswagen Jetta
 Grubhead
Grubhead
