Question about Car Audio & Video
Where do i run wiring from battey to trunk for amp
  • 23 Answers
Usually through the fire wall under carpet and down through the door sill. That would be the bottom of door opening when you open door. It also depends on what kind of vehicle. Make sure you put fuse in line on the main power wire
Posted on May 25, 2011
Where is the factory amp located ?
In the trunk up next to wheel wells. Start peeling carpet out of the trunk walls and you will find it. The rear speaker wires run right to it.
Please beware that only the 10 speaker systems have a factory amp. The stock 6 speaker systems run straight off of the factory radio. You can buy a factory amp bypass harness for this model at any good car audio shop.
Sep 08, 2014 | 1997 BMW 318
Subs Won't work when wired
Based on your post/description, pls try:
1. running the amp's power without the capacitor;
2. manually trigger the amp with the head unit off. Run it an determine if the backfiring still will occur (even with the head unit off);
3. temporarily interchange the left/right wiring;
4. temporarily interchange the + and - speaker wires;
5. run the amp normally trioggered by the headunit but remove the RCA connectors towards the amp.
If your concern has not been corrected or diagnosed which is at fault (wiring, amp, source) after completion of the above procedures, the amp may require an internal look and see.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 15, 2008 | Lanzar VIBE266 Car Audio Amplifier
Camry radio
that is the trunk monkey. (youtube him, LOL)(
he is evil
1:stock radio. end to end, we cant guess this ever.
my wild guess is the rear speaker wires are shorting out and
the smart amp, is detecting it and not blowing self up but shuts it down. (some radios do other smoke)
if it's like my son in laws,car , all the audio is custom and wired
by the same trunk monkey, wiring from H3LL does that.
lots of flapping about , electrician tape and silly wire nuts lost.
and abomination.
https://www.youtube.com/watch?v=8avOiTUcD4Y
if you see him, run, run for shelter.
Aug 23, 2014 | 2007 Toyota Camry 2.3
Needto get in the trunk battey down how can I use back seat
Connect battery to the alternator wire on the back(red)and the black lead to the engine this should power everything up in the car. Press and hold the fuel door button down for 10 seconds to pop the trunk
Feb 01, 2014 | 2006 Pontiac G6
Found your profile in yahoo.answers, hope you don't mind me asking you a question. I have a 2010 Altima 3.5SR with the Bose audio "premium" sound package. There's a Bose amp mounted on the rear...
  • Don't tap into any wire going to the amp. Run the desired new amp strait to the battery. Ground it to a bolt in the trunk. Get into the dash and find a wire to use for your remote wire for the new amp (power when key is on and no power when key is off.) Then run the new amp to an AV output in the back of your deck. If your just gonna add some bump to your trunk and not do a complete system overhaul then leave the current as is and just add on to it as I explained. Will definitely be loud.
Tony
Apr 29, 2011 | Car Audio & Video
I have a 73 buick century and i cant get the button for the trunk to work there is only one pink wire coming off of it and i cant find any loose wires i was wondering if you have any advice
have you test your trunk acuator, it may be bad, take a cordles battey from a drill and test it directly to de actuator if it wors then back trace your wiring to a relay beacuse your switch seems to be a ground signal to it.
Oct 02, 2010 | Buick Century Cars & Trucks
How to run a power cable from my 2000 300m batterie to the trunk for my amp
You normally have to drill a 1/2" hole depending on the size of your wire though the firewall and down the pillar then under the rocker panel by the bottom of the door (where you step in/out) and then on the side of the back seat to the trunk. Expect about 20-30min to run the wire. make sure you use a rubber/plastic gormmet on the firewall to keep the wire from shorting out and you need to fuse this wire off the battery. use the same amp fuse as your amp. (if 60 then use 60 at the battery)
Nov 05, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Alpine v12 amp no power
its your fuse box. i would bypass the fuse box and wire this amp directly to the battery via monster cable. make sure you attach a 30wieght fuse to the monster cable that is running from the battery to your amp. ground the amp against the trunk. scrape the paint of a section and drill a hole in the trunk. use this for the ground for you amp. this will fix the no power issue.
Feb 12, 2009 | Alpine MRV-T707 Car Audio Amplifier
Speaker issues
You have to run wires and antenna wire to trunk from head unit pull down the flap where the amp is and unplug the factory plug from the stereo think box is what i call it its the unit in front of the amp you will need to unplug the larger of the plugs it has like 10 wires in it and then unplug the antenna wire and you will connect it to the antenna wire you you ran back to the trunk do not splice any wires if you get a wiring kit for it it should have evrything you need
Oct 20, 2008 | 1995 Lincoln Continental
Dub2502 amp installatition
well to check if the amp is working hook up the ground to the battey and on the positive hook that up to the battery and jump the positive wire to the remote wire slot hook up it should spark the amp should turn on or run the power srtight on the remote slot
Apr 03, 2008 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
