Question about KLH ASW10-120 Subwoofer
I sent an earlier question regarding a 10 inch KLH sub in that it keeps blowing a fuse. I turn it on, it humms and then the fuse blows. Is there anything I can do to diagnose this problem and fix it?
  • KLH Master
  • 5,056 Answers
Fuses only blow like that when a semiconductor device is acting like a piece of wire causing an overload. An ohmmeter on the ohms setting will show any transistor with this condition as a short, just like you had touched the test leads together! Follow where the fuse leads to. And look out for signs of damage too. The most obvious parts to go are the ones that do the work, in the power supply or the main amp device, often an IC.
Posted on May 27, 2011
Klh subwoofer keeps blowing it's fuse.
Most likely the amp in the sub has blown. It will need repair or replacement. I'd take it to an expert in repairing amps, it's not a job for you unless you're experienced in troubleshooting these things.
Dec 31, 2014 | KLH Audio Players & Recorders
KLH ASW8 Powered subwoofer keeps blowing 3A-250V fuses
The transistors at the output stage of the sub amplifier circuit might be shorted so each time you power on, the circuit draws a very high amount of current which causes the fuse to blow. It's definitely a problem with the circuit so using a higher current rated fuse would probably just result in damaging the amp even more. You should ask a qualified electronics technician to take a look at it. I hope you can fix it.
Oct 17, 2012 | KLH ASW8100 Subwoofer
I've got the KLH 10 inch sub and it keeps blowing fuses. Essentially, as soon as I turn it one, it will humm and then blow th fuse. Is this fixable at a reasonable price?
This can be due to either the integrated power supply system or the amplifier itself. As a tecnician I can imagine the possible faulty components and I guess that the cost isn't too big. But since I don't know your area I suggest to ask from a technician at your area to check the subwoofer.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
May 25, 2011 | KLH ASW10-120 Subwoofer
My model 765S KLH powered subwoofer keeps blowing fuses (2 amp). Is it fixable and is it worth fixing?
I saw this post. I have the same problem with my 10-100.
http://www.fixya.com/support/t2753393-klh_subwoofer_about_6_yrs_old_keeps
Nov 13, 2010 | KLH ASW10-120 Subwoofer
KLH subwoofer Model BASSBite V. Has a bad 60Hz buzz
Before you go throwing money at this problem, try to eliminate any external influences like track lighting. I myself am trying to figure out why mine makes a buzz throughout my system when the lights are on. I already replaced the variable light control with no improvement.
Bad cable ground can let airborne electronic noise into the Sub's amp.
Jan 31, 2010 | KLH ASW10-120 Subwoofer
How do I fix a blown amp
big red
check usually the fuse just blows up just change it
Oct 22, 2009 | KLH ASW10-120 Subwoofer
It keeps blowing fuses - two 12 inch cls subs 1
sounds like the audio stage riving the channel has a short circuit on it.need to go through the amp stage
Jul 16, 2009 | Cerwin Vega CLSC-12S Subwoofer
Klh powered subwoofer keeps blowing fuses?
then the circuits took a hit and the fuse didn't do it's job in the 1st place. best is too get new circuit thats inside the sub woofer.
sorry to be the bearer of bad news
Apr 26, 2009 | KLH BB-II Subwoofer
Help my fuse is blow!
If the amp blows fuses only AFTER you send remote turn-on voltage to the amp, the amp probably has blown output transistors. To eliminate other possible causes, read through the following page.
Amp Troubleshooting
Let me know if you have any other questions.
Aug 25, 2008 | Eclipse Premium 34230 Car Audio Amplifier
Sub woofer keeps blowing fuses
NO dont try a 3 amp fuse.It is made to BLOW if there is a problem. That sub is not worth fixing, JUNK it. There are a lot of problems with it. Such as heating up and melting the board witch could cause fires. Thats what happened to mine. Like I said JUNK it and buy a different one.
Nov 19, 2007 | KLH ASW10-120 Subwoofer
KLH ASW10-120 Subwoofer Logo
93 people viewed this question
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
