I have a whirlpool washer GVXW9959KQ2. It is giving me a SR error code.
    Top Expert:
  • Washing Mach... Master
  • 76,630 Answers
Sr Stuck Relay Sr signifies a failure of the relay in the closed position. With this failure, power to the motor controller cannot be turned off by the machine controller.
The machine control board may have a bad relay and may need to be replaced. Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller. This should have AC line voltage when the motor controller is powered.
Press STOP/CANCEL to clear the display.
Posted on May 25, 2011
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Fh error code wirpool duet washer
    Display shows F20 or FH - Front-load washer ' Whirlpool ...
    https://www.whirlpool.com/...fh-front-load-...
    Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
    whirlpool duet error code FH - Appliance Repair Forum
    forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
    Jan 5, 2009 - 10 posts - ‎1 author
    ... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
    1 post
    Dec 5, 2014
    Whirlpool Duet Washer HF Error Code
    Jun 10, 2013
    FH Error Code on Whirlpool Duet Washer
    Mar 11, 2013
    FH error code
    Sep 13, 2008
    More results from forum.appliancepartspros.com
    Stumped on error code FH for Whirlpool Duet front load washer .
    Jan 08, 2016 | Washing Machines
    My tandem 7300 is giving me the e1f1 code how can I fix this
    F1 E1 error fault code - Appliance Repair Forum
    Mar 20, 2012 - 6 posts - ‎1 author
    I also cleared all error codes and the F9E1 error has disappeared but ... to send out a technician and I would prefer to make that my last resort.
    Questions and Answers for Whirlpool W10253483 Latch ...
    www.appliancepartspros.com/questions-for-whirlpool-latch-w10253483-...
    how do I run diagnostic on my washer # wfw8300sw05? Joe M .... Answer Irene, The door lock could very well be the issue with the unit giving the f22 error code.
    Maytag , Whirlpool Washer Repair - Drain pump error, no ...
    ? 4:29
    https://www.youtube.com/watch?v=QMRIPmrlAkI
    Jul 2, 2013 - Uploaded by ApplianceVideo.com
    Service a Maytag Washer suffering from this following dilemmas: Drain pump error f9e1. ... Front Load Washer ...
    Amana Fault Codes - Appliance Help Online
    Jan 05, 2016 | Washing Machines
    Fault saying no, press start for 5 seconds to clear, then it goes to nrO, press and hold again it goes back to no. Please help.
    Whirlpool Calypso Washing Machine diagnostics & Error ...
    applianceassistant.com/Washer-Repair/Calypso/Calypso-Diagnostics.php
    Whirlpool,Calypso,washing machines,repair,troubleshooting,PF,FL,Er,LF,CE,Ld,CA,CI,ob,Sr,LS,SL,error code,problem ... within five seconds while the machine is in Standby Mode. ... The washer does not flash"PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost -OR-
    Washing Machine Fault Codes « Tips, Tricks & Recipes
    www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
    Feb 20, 2010 - Drain pump error, Water level does not decrease to reset point .... If after 30 seconds the control does not detect water entering .... Press START to continue the cycle from the moment that power was lost ... Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller.
    [PDF]Fault Code Bible v1.2.pdf - ResearchGate
    Dec 02, 2015 | Washing Machines
    What is the F20 code on the whirlpool duet front load washer?
    Whirlpool WasherDuet Repair F20 Error Code - YouTube
    www.youtube.com/watch?v=kYuRQNbR9Nc
    • By Mike Murphy ·
    • 110,010 views ·
    • Added May 11, 2011
    How to Fix A Whirlpool Washer Model:Duet that gives you an F20 Error Code.
    Mar 08, 2015 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Calypso washer with Sr error code. Water sound will begin and sound like it is coming in, and then shut off. It tries this a couple of times. I cleaned the strainer on the back at the hose...
    Hello, Thank You for using FixYa. I will be helping you today.
    "Sr" signifies a failure of the relay in the closed position. With this failure, power to the motor controller cannot be turned off by the machine controller.
    The machine control board may have a bad relay and may need to be replaced. Check pins 1 and 5 of P16 of the machine controller and pins 1 and 2 of P1 of the motor controller. This should have AC line voltage when the motor controller is powered.Chances are it needs a machine control.
    Thank You and please rate my answer if it was helpful..
    Jun 12, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
    Getting sr error code
    The Sr error code means that there is a stuck relay on your main board. Would request you to replace your pc board.
    Let us know if you want any further clarification.
    Thanks for contacting fixya.com
    Dec 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
    Error Code SH
    SR = Stuck Relay.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Mar 17, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Error code "sr"
    Sr is a stuck relay on your main board.Replace your pc board.
    Dec 30, 2007 | Maytag MAH8700A Front Load Washer
    Washing Machines Logo
    19 people viewed this question
    Top Washing Machines Experts
