Question about Sony Playstation 3 (PS3) Console
The PS3 system powers on for a few seconds, will go through the normal process and get to the main screen. After roughly 10 seconds it beeps three times and powers off, with the red light on the front blinking. Touch the power button again and it goes into normal standby without the light blinking, touch it again to power it on and then it goes to the 'Did Not Power Down Properly' screen and eventually into the main screen to start the process again.
    Problem Solver:
  • 16 Answers
I had the same problem and it was fixed hwen i took apart the playstation and cleaned it there was some dust inside and i guess that fixed the problem for me good luck!
Posted on May 25, 2011
Hi my name is mike and have a serious problem with my playstation 3 well my system froze up in the middle of a game so i turned it off to reset it and now a red screen comes up and says a serious error has...
Try to start to the system in safe mode to check if this will resolve the problem.Safe mode is available to PS3 system software version 2.60 or later. To do the safe mode follow these steps:
  1. Verify that the power indicator on the PS3 system is solid red, and then turn off the MAIN POWER switch.
  2. Turn on the MAIN POWER switch, then touch and hold the power button.
  3. Keep touching the power button even after you hear a short beep after 5 seconds.
  4. After 10 seconds, you will hear another short beep and the system will shut down (release the button at this point).
  5. Touch and hold the power button again.
  6. Continue touching the power button even after you hear a short beep after 5 seconds.
  7. Release the button when two short beeps are emitted after 7 seconds.
  8. As instructed by the on-screen message, press the PS button to start up in safe mode
Mar 30, 2011 | Sony Playstation 3 (PS3) Console
It says improper shut down then freezes up and turns itself off
First make sure your PS3 is powered off and unplugged.
1. Plug your PS3 in.
2. Now hold you power button on the ps3 down, you will hear one beep, followed by another 5 seconds later, and a third one 5 seconds after that. After that the PS3 power light will turn red. You can now let go of the button.
3. Hold your power button down again, you will hear one beap, followed by another beep 5 seconds later, and then you will hear a double beep 5 seconds after that. After you hear the double beep, let go of the power button.
4. Now some words will come up on the screen saying to connect your controller.
5. You must connect your USB cord to your ps3 and connect the other end to your controller.
6. A selection menu will now appear.
7. Select the option "3. Restore File System" and press X.
8. Now follow the on screen dialog and once the restoration has completed your PS3 will be back to normal.
Please note: Following this guide will leave your Game Data and Save Files intact, you do not need to worry about this process deleting your Save Files or any other data. Your ps3 will be just like it was before it messed up.
Feb 27, 2011 | Sony Playstation 3 (PS3) Console
My ps3 isn't showing a menu, just the wavy line and star screen?
turn your ps3 off then when you touch the power butter hold it iuntil you hear two beeps on the second beep let go and the main system ovveride scree will show up click on restore settings to default and it should go back to normal
Apr 30, 2010 | Sony Playstation 3 (PS3) Console
PS3 not showing up on tv no matter what i do
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings.
I use this method to revert from HDMI 1080p to Composite 576p, without having to swap cables and change settings.
Jan 23, 2010 | Sony Playstation 3 (PS3) Console
I downloaded PS3 system software update 3.15 last night. Now when i turn it on the green and blue lights come on and it starts to boot up but stops and there is nothing on the screen and my controller...
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. i had the same issue and this fixed it.
Jan 22, 2010 | Sony Playstation 3 (PS3) Console
My ps3 had a serious problem red screen appears on my tv
Lines on my screen
PS3 help
sounds like the video board needs to be re-set it is locked into what ever setting it was in. i have seen a few ways to do the power button trick and this seem to work best!!!
follow theses instructions to a "t" and it should work for you.
1. Turn Off in back (wait few seconds for it to re-set)
2. Turn on in back
3. Turn on in front and hold your finger on it 'till it turns off again -
(you get the beep on then the three beeps for reset and it will eventually beep again and turn off)
4. Turn off in back (wait few seconds for it to re-set)
5. Turn on in back
6. Turn on in front hold finger for three beeps
also have you been to the default screen after doing a power button push for three beeps from stand by mode?
As all of these solutions sounds good I can tell you that about 50% of them will be getting to the restore menu and restoring the default settings, however; the other 50% is yet to be figured out at least on our end. Reflowing is not the answer as I have a reflow machine and it will not fix a no video/audio issue. I have had several no video/ No audio and have reflowed the entire board and nothing. Now on the YLOD reflowing in about 60-70% of the cases will work the other 30-40% is component failure and in that case you are almost certainly better off to just get another board.
Sep 11, 2009 | Sony Playstation 3 (PS3) Console
Ps3
ok heres what you do when you flip the switch on the ps3
wait for the red light to come on
then hold the power button for like 15 seconds until u hear a beep twice
the system will reset itself like a cpu
and the screen will turn back to normal
this happens when you go from one sd tv to an HD tv all the time
hope this helps
Oct 19, 2008 | Sony Playstation 3 (PS3) Console
My ps3 display
to all those who cannot see any display..hold down the on/off button until it beeps once, then wait a few seconds until it beeps again, the ps3 will have reset itself and will adjust the visual settings to fit your tv
Mar 08, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
48 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
