Question about KitchenAid KBHC179JSS 900 Watts Convection / Microwave Oven
Door spring broke need replacement on KBHC 179jSS05
3 Suggested Answers
SOURCE: Microwave door tension spring
See answer here http://www.fixya.com/support/t265705-microwave_door
in different thread.. Basically have to pry plastic trim ring off inside of door with putty knife (careful, it cracks easily) to get to screws on bottom of door. See second pic. Top screws are easily accessible from inside of door. Spring can easily be replaced by hand once you get adequate access. You'll need a fairly stubby right angle screwdriver (I used a cut-down #2 Phillips bit and small Vice-Grips as a make-do) to get to the screws. Also need Torx (T10, I think) to detach the shock absorber doodads from the door where they attach above the hinges. If you're just starting to take the door apart, be careful when you take out the top 2 screws on the inside-- they hold the inside plastic piece on , but they also hold the whole outer stainless/ glass/ handle piece on. It just slips in at the bottom, so be ready to slide it out when you take these screws out.fea33aa.pngc391898.jpg
Posted on Jan 13, 2009
SOURCE: Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Posted on Mar 26, 2009
Door will not stay close
Not much data to go on here. The latch on the door has a spring that holds it down in the locked position. when you pull the handle the latch goes up and you pull the door open. You will have to take the door apart and see if the spring broke or the plastic tab that holds the end of the spring is broken.
Feb 25, 2015 | Maytag Appliances Over-the-Range Microwave...
Why will door not stay latched ?
Check the door latches that stick out from the door. Push them up. Is there any resistance? If not, then the spring that pulls them downward either broke or came of its catches. You will need to call a repairman who will have to take the door apart and either replace or re-fasten that spring.
Jun 22, 2014 | Kenmore Microwave Ovens
Door will not latch
Why will my Kenmore model 401.85053010 mocrowave door will not latch?
Jun 11, 2014 | Kenmore Microwave Ovens
Microve latch/spring assembly ... have a broken head on the latch which i can repair but cannot see where to attach other side of spring on Maytag MMV5207bas
Unfortunately, the exploded views do not show the innards of the door.
So as new latch head is not available separately, so if you cannot fix yours, a whole new door will be needed.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
There's probably a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
You can use use epoxy and some kind of hardware to fashion a new spring mount.
If you have to do any gluing, make sure the parts are squeaky clean and dry before you glue them, or it will not hold up.
Oct 30, 2009 | Microwave Ovens
Mar 26, 2009 | KitchenAid Microwave Ovens
We have an old Sharp Carousel R-1440 that works great, except for the door latch broke (i.e. doesn't work at all now). Can we replace just the door?
Actually, the door latch head (hooklike device) is pretty easy to replace or repair if that's the issue.
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
You can usually find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
We have critical safety & disassembly info at our site, linked here.
Sep 27, 2008 | Sharp Microwave Ovens
Door Latch Spring
The door latch head (hook) is easy to replace or repair if that's the issue.
You can usually find helpful exploded view diagrams and order parts by entering your full model number (RVM1425BA03) here: http://tinyurl.com/gv383
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 02, 2008 | Hotpoint RVM1425 Microwave Oven
KitchenAid KBHC179JSS 900 Watts Convection / Microwave Oven Logo
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
