Question about Frigidaire Electric Dryer
My Frigidaire Affinity dryer (model AEQ 800FGO) needs to be reset I think. The problem is that the dryer stops when is being used and then I cant tourn it off. I have to disconnect it. Thank you.
    President:
  • 3,074 Answers
Push to start switch is bad
Posted on May 25, 2011
Cant open the front door seems like its locked
My frigidaire affinity dryer displays LOC - Fixya
www.fixya.com/support/t4561247-frigidaire_affinity_dryer_displays_loc
my frigidaire affinity dryer displays LOC and will not allow me to press any buttons what does that mean? please - Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer question. ... Hi i have a front load frigidare dryer and it displays the cycle time when you press start but it blinks back & fourth to loc & whatever cycle its ... Open Questions:.
Nov 23, 2015 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
MY FRIGIDAIRE AFFINITY MODEL # AEQ6000ESO WILL NOT HEAT. IT STARTS FINE.
There is a reset on some models by unplugging the appliance and waiting a couple minutes then plug back in make sure timer is on off position and pulled out. You can also open and close the door just alil bit 6 times within 12 seconds while machine is plugged in. But I think you should test ur thermostats and heating element with a multi meter for continuity? A worse case may be that the motor has burned a winding and or ur ur power outlet is only giving half the current as the dryer uses 120 to run and the other 120 to operate the heating? thus if u only get 120 instead of 240 volts you will get an appliance that runs but does not heat.
Feb 06, 2015 | Frigidaire AEQ6000ES Affinity 5.8 Cu. Ft....
How do you open the Frigidaire affinity dryer bc i think the belt is broken
If the belt is broken dryer will not tumble, you can turn drum and should be resistance to turn, if turns easy then belt is broken. This is a difficult repair. If you can't see how to open dryer you won't be able to replace belt.
Aug 30, 2014 | Frigidaire AEQ6000ES Affinity 5.8 Cu. Ft....
When push start it makes a click but does not start. got power. belt good.
Sounds like a bad thermal shut off maybe? or the push start swtich is gone bad? can check these with a multimeter. for continuity may also want to check the door switch as this can also shut off the cycle and all u will get is a click or nothing
May 19, 2014 | Frigidaire AEQ6000ES Affinity 5.8 Cu. Ft....
My affinity frigidaire gas dryer wont stop running
Hello Kenneth Joynt - Often when a dryer will not stop running, it is because the unit may have a potential wiring failure, faulty timer, or a communication error with the main control board. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If issue persists, I would suggest contacting an experienced service technician to determine the precise cause.
Apr 12, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Frigidaire Affinity gas dryer problem
I would bet you need new door lock switch
Jul 13, 2017 | Frigidaire Dryers
(2007) Frigidaire Affinity Gas Dryer won't shut off
mybe the star button stay stuck and the dryer tinks some one is puching the star button and it will continio to run. try to open the door and it will stop and then clouse the door if the dryer star whitout pushing the star then you now the star switch is stuck. goo lock
Feb 21, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Frigidaire  Electric Dryer Logo
119 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
